2002 4.7 valve seal job?
Discussion in 'Sequoia 1st Gen (2001-2007)' started by Pzabrah2, Aug 11, 2024.
  1. Aug 11, 2024 at 11:16 PM
    Pzabrah2
    Pzabrah2 [OP] New Member
    Pete
    2002 Tundra
    None
    Hello everyone,
    my name is Pete and I’m new to Toyota. The last forum I was on was when I bought my first mustang 15 years ago.
    I’d like to thank you all in advance for taking the time to read my post.
    I have a 2002 4.7 that I bought to fix up because I thought the issue was just fuel injectors but when the white smoke cleared, then came the blue. I’ve done a lot of reading and have come to believe it’s a bad valve seal in cylinder 8. I have a flashing cel with a p0308. When I bought it, it was misfiring on three cylinders and a random misfire but they all cleared after the new injectors except for p0308.
    The spark plug is oil crusted so I’m 99% sure it’s a valve seal.
    With that being said, is there a good way to change the valve seals with the motor in the car? Would it be easier to take the head off the block? What puts me off doing this job the most is my fear of screwing up the timing (timing belt and water pump were done 50k ago). Does anyone have any good tips on how to do this? I have seen the post of lextreme.com and that helped quite a bit.
    Any help will be greatly appreciated. I’m very happy to be here, I have wanted to be a Yota dude for a long time!
  2. Aug 18, 2024 at 1:16 PM
    BeardedTundra
    BeardedTundra Shr3k
    Justin
    2006 Sequoia Limited 4x4
    Big mods are coming soon, but not too soon.
  3. Nov 4, 2024 at 10:28 AM
    NateB04
    NateB04 New Member
    Nathan
    04 Sequoia 2wd
    Electric radio fan After market radio and speakers.
    I have taken the heads off my truck a couple of times and looking to do so here in the future that might be easier and it wouldn't hurt to have both heads gone through by a professional if you loosen the retainers for the valves they can possibly fall in to the cylinder. Also valve adjustment is done by shims so sending your head to a professional to redo the seals you'll have all new seals and he'll have your valves adjusted but that's just my vote
