2001 Tundra Cab swap 5vz to 2uz
Discussion in '1st Gen Tundras (2000-2006)' started by cob, Aug 15, 2020.
keep roll up windows or swap in the power
  1. roll up
    5 vote(s)
    26.3%
  2. power up
    14 vote(s)
    73.7%
  1. Dec 2, 2020 at 11:30 AM
    #91
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Long tubes ultimately will make more power. But shorties will provide a bit more than long in the bottom end
  2. Dec 2, 2020 at 1:50 PM
    #92
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    Gibson GP603 .... would this be a good fit for me ?
  3. Dec 2, 2020 at 2:14 PM
    #93
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My google fu seems to indicate those will work. You'll want to buy new gaskets. Tagging a few people that have done the job to see which gaskets they went with. @imDementeD @Darkness @Thrussn
    Stuck in the '00s and Darkness like this.
  4. Dec 2, 2020 at 2:25 PM
    #94
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Percy's header gaskets for the manifolds. Looks like they are also going by Taylor Cable as a name. You can look for Percy's 66080
    https://www.summitracing.com/parts/php-66080
    Remflex #8015 I believe is this one for the collector
    https://www.summitracing.com/parts/rfl-8015
    Also you'll want 22 new locking nuts from Toyota, a few spare studs wouldn't hurt in case yours break. You need 8 nuts per manifold and 3 nuts per collector. Might need 3 bolts per collector too, I can't remember.
    Stuck in the '00s and Thrussn like this.
  5. Dec 2, 2020 at 7:10 PM
    #95
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I used remflex for the header gasket and it did fantastic. I'm going to use them again when I reinstall another header this weekend because I keep breaking my JBA shorty. I would recommend them for the collector gasket too. I'm ordering some as I type this lol.
    Darkness[QUOTED] likes this.
  6. Dec 4, 2020 at 6:49 AM
    #96
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    i almost ordered the gibson set but seen it was only for 2wd. Thrussn why do u keep breaking the jba headers ?
  7. Dec 4, 2020 at 7:42 AM
    #97
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Are those Percy's/Taylor Cable gaskets better than OEM Toyota or just cheaper? I bought OEM gaskets for about $55 for the Doug Thorley headers.
  8. Dec 4, 2020 at 8:29 AM
    #98
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've never used oem ones but when I did my headers and compared the two, the oem were pretty flimsy compared to Percy's. I think the Percy's have a little more room to compensate for any gaps between the head and flange.
    I haven't heard any complaints on oem gaskets either, they should work.
    Mustanley[QUOTED] likes this.
  9. Dec 4, 2020 at 4:20 PM
    #99
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Went OEM gaskets. Originally OEM at the header and JBA at the collector that leaked and replaced with OEM.
  10. Dec 5, 2020 at 4:38 AM
    #100
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    I ordered new body mounts from the dealership. also changed the fuel filter i was stressing over that one. Because we have the v6 gas tank we needed to swap fuel pumps
  11. Dec 5, 2020 at 6:27 AM
    #101
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That is no small amount of work. Congrats on some quality work so far! I just spent an arm a leg and several months on an Outback XT manual trans rebuild. Every time I turned around there was a “While I’m in here I might as well ...” project. That line of thinking will double your time to finish but in the end you have a vision and you should see it through! I can’t wait to see your finished product, good luck!
    Tundra2, Stuck in the '00s and N84434 like this.
  12. Dec 5, 2020 at 6:39 AM
    #102
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    how did that go? I'm wondering how difficult the fuel line fittings were to break loose?
    Fantastic work so far..
  13. Dec 5, 2020 at 7:47 AM
    #103
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    used vice grips instead of wrenches but its on :)
    N84434 and Stuck in the '00s like this.
  14. Dec 5, 2020 at 7:50 AM
    #104
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    funny with the suby man i have that same car
  15. Dec 5, 2020 at 7:53 AM
    #105
    Professional Hand Model
    Hand Protectors
    How’d the gasket on the Fuel Pump to Tank Lid look?
  16. Dec 5, 2020 at 8:13 AM
    #106
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Ha! Yep same model as well. Are you on legacygt.com? I had a 2005 lgt and now an 06 OBXT.
    Great minds and all that.
    Tundra2 likes this.
  17. Dec 5, 2020 at 8:55 AM
    #107
    N84434
    Milwaukee WI.
    2001 Limited TRD
    good to know. Thats on my list for next spring.
  18. Dec 5, 2020 at 10:32 AM
    #108
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    not really my car has a ej20x i was asking about that on one of them sites
  19. Dec 5, 2020 at 10:34 AM
    #109
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    thats actually supposed to be the next project on the list i have it running but i need to learn some tuning so she doesnt pop
  20. Dec 5, 2020 at 10:35 AM
    #110
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    the fuel pump gasket was reuseable i have 2 options for alot of parts so that does help
  21. Dec 5, 2020 at 5:59 PM
    #111
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
  22. Dec 6, 2020 at 3:23 PM
    #112
    Mustanley
    Hendersonville, NC
    Same place I ordered mine from :spending:
  23. May 15, 2021 at 10:26 AM
    #113
    Sunnier
    Sunny
    San Diego, CA
    Dan, do you have quick tips to where I can find all the unhooking places for the dash... maybe a link to instructions-? I don’t have a proper manual for my 2002 that covers this.
  24. May 15, 2021 at 11:24 AM
    #114
    empty_lord
    05 rollover special
    I’ll check when I’m home. I’m at work currently
    Sunnier[QUOTED] likes this.
  25. May 15, 2021 at 11:57 AM
    #115
    Sunnier
    Sunny
    San Diego, CA
    Back to no hurry, ran into a problem I can’t fix immediately, so this can wait.
    FrenchToasty likes this.
  26. May 17, 2021 at 5:20 PM
    #116
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    Well guys life got in the way of progress on my old pickup truck. It was a huge mess dealing with the manifolds. I broken studs mangled treads in the heads u name it lol :( ..... that stuff gets me super worked up half the reason for avoiding it lol
  27. May 17, 2021 at 5:28 PM
    #117
    Hand Protectors
    Yeah. That Driver Side will break your Spirit if you let it. Spent 18 hours tucked up in the wheel well last week. Two Mangled Studs and one stuck stud (left it on and it came back to haunt me on Manifold put back but prevailed over it again with Hand Mojo). No broken Studs on mine.
    How did you get your broken studs off? That had to be disheartening.
  28. May 17, 2021 at 5:28 PM
    #118
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I feel your pain. Just remember there are guys that have rebuilt engines with lots of go fast parts and left a block plug out and roasted the whole thing while doing cam break in.
    Just some perspective. I need the reminder sometimes too. I have an awesome track record of making a level 5 project cost as much and take as much time as a solid 10.
    bmf4069 likes this.
  29. May 17, 2021 at 5:29 PM
    #119
    empty_lord
    05 rollover special
    I just can’t finish a project :anonymous:
    bmf4069 likes this.
  30. May 17, 2021 at 5:30 PM
    #120
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    new nuts...... boy i guess i am doing something wrong lol. The local toyota dealer wanted over 600 dollars for 16 studs and 22 nuts I about fell over. I ended up doing an online order from dealership that was not price gouging was about 230 or so i believe. i honestly dont understand how these dealerships can charge over double the listed msrp prices but i guess it happens everyday.
    bmf4069, FirstGenVol and KarmaKannon like this.
