2001 Tundra AC SR5 V8 Part-Out!
Discussion in '1st Gen Tundra Parts Marketplace (2000-2006)' started by lsaami, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 14, 2020 at 10:38 AM
    #61
    lsaami
    lsaami [OP] Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    front door panels are gone, rears are still available. as far as I know, the airbag control module works just fine. The truck did not have any airbag errors when It was parked.
    Thanks!
  2. Sep 14, 2020 at 10:40 AM
    #62
    lsaami
    Minnesota
    I think someone on here was looking for the drip rails. See attached photos. They're a bit sun-baked, but still flexible and came off without damage.
  3. Sep 14, 2020 at 11:35 AM
    #63
    035VZFE
    035VZFE Restored a Tundra top to bottom
    James
    Vero Beach, Florida
    2009 Passat B6 2.0 Turbo
    ECS Tuning DV Spacer ECS Tuning Turbo Muffler Delete ECS Tuning Luft-Technik CAI System A-Spec 60mm Charge Pipe Straight piped from resonator back, stock cat and downpipe
    Thanks for your response. After some research, I found out that airbag control modules must be part-number matched and I have an '03 with a different part number. Thank you for your time though!!
    lsaami[QUOTED][OP] and Tundra2 like this.
  4. Sep 15, 2020 at 3:05 AM
    #64
    tvpierce
    tvpierce Formerly New Member
    Maine
    That was me.
    I'll take the one for the passenger side. Did you also grab a 31mm body plug for the rear of the cab?
    lsaami[QUOTED][OP] likes this.
  5. Sep 15, 2020 at 11:40 AM
    #65
    lsaami
    Minnesota
    I completely forgot about the body plug. I’ll be over there tomorrow after work and I’ll grab it for you. PM me your shipping info.
  6. Sep 22, 2020 at 5:03 PM
    #66
    tvpierce
    Maine
    Parts arrived as promised.
    Great prices, great service.
    Thanks @lsaami :thumbsup:
  7. Sep 23, 2020 at 1:02 PM
    #67
    BmBlB
    BmBlB New Member
    2006 White DC Limited
    Do you have the woodgrain climate control/entertainment piece and is it similar to this:
  8. Sep 23, 2020 at 3:15 PM
    #68
    lsaami
    Minnesota
    climate control is black, and has been sold already.
    Sorry!
  9. Sep 23, 2020 at 4:11 PM
    #69
    BmBlB
    BmBlB New Member
    No worries. Thanks for letting me know.
  10. Sep 23, 2020 at 4:57 PM
    #70
    Professional Hand Model
    Hand Protectors
    I’ll second this. Stoked on all the parts so far.
  11. Sep 29, 2020 at 9:33 AM
    #71
    Eedming
    Eedming New Member
    Eric
    01 tundra tdr
    I'm wondering what you would want for the rear differential?
  12. Sep 29, 2020 at 10:57 AM
    #72
    lsaami
    Minnesota
    Send me a PM - you looking for shipped or local pickup?
  13. Oct 14, 2020 at 8:53 AM
    #73
    two2cal
    two2cal New Member
    Do the seatbelt retractors work well? Mine currently don’t retract without help and get caught in the door
  14. Oct 27, 2020 at 1:23 PM
    #74
    two2cal
    two2cal New Member
    Any word on those seatbelts? Thanks
  15. Nov 9, 2020 at 11:22 AM
    #75
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @lsaami this is the plug for the backing plate on the rear drum. It's the one you pop up to access the star adjuster. Can I buy your old ones? I lost one. Also, if your bleeder valve caps are not dry rotted I'll take those. Figured you can drop them in an envelope and ship with a stamp.
  16. Nov 9, 2020 at 5:47 PM
    #76
    lsaami
    Minnesota
    I’ll give a look. I think @Professional Hand Model might have swiped them already.
    Tundra2 likes this.
  17. Nov 9, 2020 at 9:43 PM
    #77
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    if he doesnt have them theyre cheap enough from the dealer FYI
    Tundra2 likes this.
  18. Nov 10, 2020 at 3:57 AM
    #78
    Hand Protectors
    Yep. They have been working nicely since goofy axle mangler and then stealership goofy mechanic both forgot to put them back.
    Stoked on all your parts thus far.
    Tundra2 and lsaami[QUOTED][OP] like this.
  19. Nov 10, 2020 at 5:41 AM
    #79
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    So you've got parts from your donor truck in "Somewhere, a state of mind," Western Ky, and many more states I'm sure.
  20. Nov 24, 2020 at 11:18 PM
    #80
    C_Rent17
    C_Rent17 New Member
    Colin
    2001 Limited 2WD Tundra V8
    I’ve been searching for the wiring harness for both of the license plate lamps with no luck. Any chance you still have these? I basically need 6 inches or so of the wiring that leads to the plug/socket (which I need). I have the lamp housing already and plan to buy LED bulbs so I’m good there. Am I in luck?
  21. Nov 25, 2020 at 4:58 AM
    #81
    lsaami
    Minnesota
    Still available! shoot me a PM. I'll be able to pull them over this weekend, and shipped out early next week.
    C_Rent17[QUOTED] and Tundra2 like this.
  22. Nov 25, 2020 at 6:41 AM
    #82
    C_Rent17
    C_Rent17 New Member
    Colin
    PMed you my man!
  23. Nov 27, 2020 at 4:04 PM
    #83
    MeangreenTRD
    MeangreenTRD New Member
    Orlando
    2002 Green Tundra TRD
    Stock
    Do you still have the radio for sale?
  24. Nov 29, 2020 at 9:37 AM
    #84
    lsaami
    Minnesota
    Yup! Send me a PM.
  25. Nov 29, 2020 at 9:58 AM
    #85
    MeangreenTRD
    Orlando
    Stock
    PM sent
  26. Dec 7, 2020 at 2:02 AM
    #86
    Sandy01
    Sandy01 New Member
    New Mexico
    2001 Ext cab 4x4
    Very soon
    Still have truck for parts?
    Tundra2 likes this.
  27. Dec 7, 2020 at 5:24 AM
    #87
    lsaami
    Minnesota
    yup! send me a PM with what you're looking for.
  28. Dec 20, 2020 at 11:51 PM
    #88
    YOUNGBUCK34
    YOUNGBUCK34 New Member
    Rico
    2005 Double Cab 4x4 SR5 V8
    Do you happen to have the rack and pinon mounting bracket that is attached to the frame and the horse shoe piece that goes along with it? SR.jpg
  29. Mar 31, 2021 at 7:56 PM
    #89
    kenadavis
    kenadavis New Member
    Ken
    South Florida
    2006 Tundra Limited Access Cab
    Looking for headlights, tail lights, rear bumper and ash tray
  30. Apr 1, 2021 at 6:59 AM
    #90
    lsaami
    Minnesota
    PM me. I have headlights, but they're a bit faded and the adusters are gone. i'l snag some photos of the taillights, I should have the Ash tray as well.
Thread Status:
