2001 Tundra A/T temp light stays on
Discussion in '1st Gen Tundras (2000-2006)' started by JR69FASTBACK, Mar 30, 2020.
  1. Mar 30, 2020 at 7:48 PM
    JR69FASTBACK
    JR69FASTBACK [OP] MinneSorta Nice
    Minnesota
    2008 Tundra CrewMax 4x4 Limited TRD Off-road
    No need for mods
    I have a 2001 Tundra SR5 4.7 with towing package. My issue is with the A/T temp light staying on even upon initial start up I have changed the radiator (due to coolant leak) changed out trans fluid and even added another trans cooler to be safe. Everything runs and drives as it should with no lag or skip in shifting. The weird thing is, sometimes the light doesn't come on at all. Any help is appreciated.
  2. Mar 30, 2020 at 8:11 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I'm kinda confused
    Is the light on or not??
    FrenchToasty likes this.
  3. Mar 30, 2020 at 8:12 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    It is shorting out....
    JR69FASTBACK[OP] likes this.
  4. Mar 30, 2020 at 8:23 PM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    Secondly is it the 08, or the 01 he’s talking about. Not the 01 if he’s stating the 4.6 right?
    TX-TRD1stGEN[QUOTED] likes this.
  5. Mar 30, 2020 at 8:48 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    You need a scanner so you can see A/T fluid temp that will tell you the problem if it’s showing a crazy reading with key on your a/t temp sensor or wiring could be bad my experience a broken wire will show -Degree reading, with the KOEO cold engine you should be somewhere very near to ambient temp
  6. Mar 30, 2020 at 9:37 PM
    JR69FASTBACK
    Minnesota
    No need for mods
    The light is not shorting out (I chased the wires, which was a pain). I have 2 Tundras. This post is for the 2001. I will ask around and see if someone has a good scanner I could use.
  7. Mar 30, 2020 at 9:46 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    according to this pic your ATF Fluid temp sensor is on the passenger side of the trans take a look at the harness and see if it’s corroded or broken wire
