2001 Toyota Tundra 4.7L 4wd jerky hard acceleration
Discussion in 'Performance and Tuning' started by First Tundra, Nov 11, 2017.
  1. Nov 11, 2017 at 9:25 PM
    First Tundra
    First Tundra [OP] New Member
    Just picked up this Tundra from a relative that has been neglected severely. Runs good at normal or mid throttle but at hard acceleration engine jerks as if you’re pumping throttle hard. Ran diagnostics with obd2 scan tool and got the following codes P0141 P0155 P0161 P0440 P0441 P0446
    Advice on best route to start and what to check in abc order would be greatly appreciated...
  2. Nov 11, 2017 at 11:44 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    First thing I would do is go straight to the dealer with your vin number and buy a brand new, slightly over priced (maybe) gas cap.
    Then hard reset the ecu. And post up any new codes that pop up from there.
    If I don’t respond in a timely fashion give a call. 760-877-4234.
    T-Rex266 and First Tundra[OP] like this.
  3. Nov 12, 2017 at 7:29 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Maybe take a peek at the air filter as well.
  4. Nov 12, 2017 at 1:27 PM
    First Tundra
    I’ll check em out ASAP
  5. Nov 12, 2017 at 8:16 PM
    First Tundra
    Cleaned MAF and throttle body and checked air filter which didn’t appear dirty visually but I’ll replace it anyway. Also changed the gas cap. Drove it just a few minutes and no codes came up yet but the hard acceleration is still jerking like someone pumping the throttle
  6. Nov 14, 2017 at 3:41 PM
    First Tundra
    After driving the truck to work and back home I ran a code scan again to find the following errors P0141 P0155 P0161
  7. Nov 14, 2017 at 4:47 PM
    First Tundra
    How can I test to see which one it is?
  8. Nov 14, 2017 at 4:50 PM
    First Tundra
    Rebuilt engine with about 90,000 on it
  9. Nov 14, 2017 at 6:03 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I suspect that those may be O2 sensor codes. How did the code reader define them?
    GNTundra likes this.
  10. Nov 14, 2017 at 6:11 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    How long ago? Recent, like very recent?
  11. Nov 14, 2017 at 6:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Misfires are usually P030X codes. I wonder if the timing belt jumped.
  12. Nov 15, 2017 at 5:06 AM
    First Tundra
    Correction... motor was replaced and currently has 90000 on it.
    Changed all the plugs and one coil that appeared to be misfiring also replaced air filter. Runs a lot smoother but still jerking at hard throttle. I’ll run a code scan after driving home from work to see what shows up and post the results
  13. Nov 16, 2017 at 6:38 PM
    First Tundra
    Ran a codescan specific for Toyota Tacoma 4.7 with ActronCP9185 and got this list:
    P0141
    P0155
    P0161
    P1305
    P1310
    P1315
    P1320
    P1325
    P1330
    P1340
    It seems as though the more I do to try to help the more errors are come up with
  14. Nov 16, 2017 at 7:02 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    O2 sensor codes
    Igniter circuit malfunction codes for multiple cylinders
    Cam sensor code
    Did this just begin happening out of the blue one day? Was the engine run especially hard one day and then it started running like this? Was the engine over-revved hard?
    I'm still wondering if this is symptomatic of the timing belt being off a tooth but honestly, I've never been involved with this engine. The only way to check if it's off entails a reasonable amount of disassembly if I'm guessing even reasonably accurately. You'd have to remove the timing cover(s) and crank pulley, and likely a bunch of other shit just to get that far.
    The other thought is that it could be a wiring issue where rodents got in there and snacked away on the ignition system. That may actually be the easier initial search. Look for nests and poop. But you've already been working on it, you woulda noticed I'm sure. Dang man.
  15. Nov 17, 2017 at 4:57 AM
    First Tundra
    I’ll take it to the shop first chance I get and have em run timing check on it to be sure
  16. Nov 18, 2017 at 9:00 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    your due for a timing belt change at 90K on the 4.7L anyway
