2001 Blew a belt on highway
Discussion in '1st Gen Tundras (2000-2006)' started by MNtundra, Mar 3, 2021.
  1. Mar 4, 2021 at 11:43 AM
    MNtundra
    MNtundra [OP] New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Conclusion: my serpentine idler pulley (16603-0W030) bearing seized. This friction caused my belt to heat up and snap. The End.
    Sandy01, Lil Steve, landphil and 3 others like this.
  2. Mar 4, 2021 at 11:56 AM
    Toyota did. Should be in the FSM and the owners manual. Some items that are frequently brought up here are higher incidence of failure, or catastrophic failure points. LBJ's and Timing belts come to mind. Investigate your owner's manual or search the FSM available on this site.
  3. Mar 4, 2021 at 2:26 PM
    MNtundra
    Tony
    Minnesnowta
    just did LBJ’s & Checked Timing Belt. All Good against CATASTROPHIC FAILUREs, just the pesky little failures to worry about... (IE idler pulley bearings)
