2000W Power Inverter
Discussion in 'General Tundra Discussion' started by nk1794, Apr 15, 2018.
  1. Apr 16, 2018 at 7:33 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I doubt you'd need a HO alternator. Get a big battery up front and keep a jumper pack in the truck when you think you are going to be using the inverter.
    nk1794[QUOTED][OP] likes this.
  2. Apr 16, 2018 at 7:42 AM
    nk1794
    nk1794 [OP] Always torque to spec
    San Jose, CA
    Cool. I saw some discussions on them..thanks
  3. Apr 16, 2018 at 7:44 AM
    nk1794
    San Jose, CA
    What's the amperage rating on stock alt?
  4. Apr 16, 2018 at 6:45 PM
    nk1794
    San Jose, CA
    My truck has 150A alternator :militarypress:I think I need more power :benchpress:
  5. Apr 16, 2018 at 6:48 PM
    nk1794
    San Jose, CA
    I can choose color for an alternator. LOL
    NewImprovedRon and Areith762 like this.
  6. Apr 16, 2018 at 8:29 PM
    Danimal86
    Daniel
    Sacramento, CA
    man, you are going down the rabbit hole on this one
    nk1794[OP] and Skippy like this.
  7. Apr 16, 2018 at 8:34 PM
    nk1794
    San Jose, CA
  8. Apr 17, 2018 at 3:54 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Skippy likes this.
  9. Apr 17, 2018 at 7:32 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    ^^^ AND, probably an easier install, but then we wouldn't get the "how to vid"
    :boink::D
    nk1794[OP] likes this.
  10. Apr 17, 2018 at 8:17 AM
    nk1794
    San Jose, CA
    Thank you, sir. You just confirmed what I've been reading. I not planning to use the inverter for long extended time nor putting full load on it but I would like to get a better alternator. I'd probably have the engine running if I have to run it for 10-15 minutes. Another option I'm looking at also is to add a deep-cycle battery to provide longer run time. This is going to be a multi phase project.
    Thanks for the link to DC Power. 270A is definitely better than 150. :)
    :rofl: Which part of this install is easy? Are you talking about just buying a generator? It's been on my list for awhile as part of an emergency preparedness. That's a topic for another thread. :D
    Skippy[QUOTED] likes this.
  11. Apr 17, 2018 at 8:44 AM
    Danimal86
    Daniel
    Sacramento, CA
    You could run a second battery with an switch (similar to how boats/Rv's use dual batteries).
  12. Apr 17, 2018 at 8:49 AM
    nk1794
    San Jose, CA
    Yes, that's the plan for a 2nd battery. Thanks :cheers:
  13. Apr 17, 2018 at 8:53 AM
    Danimal86
    Daniel
    Sacramento, CA
    What are you planning on running off the inverter?
    Go Ham and put 2 northstars/odyssey's up front, with an aux in the rear and a HO alternator:benchpress:
  14. Apr 17, 2018 at 9:33 AM
    nk1794
    San Jose, CA
    I figured with 2000W I could run anything from a small microwave, coffee maker or power tools. It's one of those "it's there when I need it" type of setup.
    That's a lot of batteries you are suggesting. I don't think I need to go that extreme. :D
  15. Apr 17, 2018 at 10:34 AM
    My biggest issue with that inverter and quite frankly a lot of them is that the output is a modified sinewave. What you want is an inverter with True RMS volts out. Much cleaner output and zero chance of fooking something up. TRMS inverters cost more for good reason...
  16. Apr 17, 2018 at 10:41 AM
    nk1794
    San Jose, CA
    Thanks for the advice. I’ll have to look into that.
  17. Apr 17, 2018 at 6:42 PM
    nk1794
    San Jose, CA
    Something like this?
    https://www.amazon.com/dp/B0131NFWX...9499-df087bbc5c7f&ie=UTF8&qid=1524015636&sr=1
  18. Apr 17, 2018 at 8:04 PM
    nk1794
    San Jose, CA
    OMG! This is a BEAST. 370 Amp. It's wayyyyyyyy overkill for what I need.
    I think this one pack plenty of punch at 270Amp
  19. Apr 17, 2018 at 8:36 PM
    #49
    Danimal86
    Daniel
    Sacramento, CA
    go big or go home
  20. Apr 17, 2018 at 8:39 PM
    #50
    nk1794
    San Jose, CA
    :rofl::lalala:
