2000 Tundra V8: Horn Relay Location
Discussion in '1st Gen Tundras (2000-2006)' started by steelgtr, May 3, 2023.
  1. May 6, 2023 at 10:15 AM
    steelgtr
    steelgtr [OP] New Member
    Bob
    Since the horn can be activated on multiple points on the pad, and only certain points on the pad work when it works, has anyone ever seen the contact points inside the pad?
  2. May 6, 2023 at 10:16 AM
    steelgtr
    Bob
    Also, ao another forum, people had mentioned that the horn actually grounds through a bearing on the column and that it can get corroded. Any merit to that?
  3. May 6, 2023 at 10:19 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Perhaps he misunderstand given the difference from each other
    Anyway, perhaps you could call him back and ask him about unplugging black connector from clock spring and applying a gnd to the proper pin of the black connector causing horn to work.
    Toyota would need to update all their 1st Gen FSM and EWD’s where they show clock spring/spiral cable/comb switch in all their drawings including trubleshooting where they state if horn don’t work, one possible item is clock spring :notsure:
    steelgtr[OP] likes this.
  4. May 10, 2023 at 8:59 AM
    steelgtr
    Bob
    So I can't check that wire for continuity any way?
    thx
    bob
  5. Jun 15, 2023 at 5:09 PM
    steelgtr
    Bob
    Any thoughts on the shaft bearing being the horn ground and possible issue?
  6. Jun 16, 2023 at 7:15 AM
    shifty` Goons of Hazzard
    I personally haven't dug into things enough to be able to comment. This seems like one of those issues you'd need to dig into a bit deeper in-person to get a grasp on. I rarely ever use my horn, so any attempt to fix the issue would be purely cosmetic for me.
  7. Jul 31, 2023 at 4:11 PM
    dward394
    dward394 New Member
    David
    I just bought a 2001 Tundra about a month ago and just noticed the horn doesn't work. I checked both horns by disconnecting the wiring harness plug from the horn and jumpering the horn straight to the positive battery post which both worked fine when jumpered. The 20amp fuse is good, and the hazard lights work. I just changed the clock spring out, but the horn still isn't working. When I press down on the horn I can hear a click sound from the relay. Any ideals?
  8. Jul 31, 2023 at 5:20 PM
    steelgtr
    Bob
    Still trying to figure out my 2000 intermittent horn problem :)
  9. Feb 13, 2024 at 3:59 PM
    steelgtr
    Bob
    Update: Stumbled on the fact that if I pull the bottom of the steering wheel up and out towards me, the horn works perfectly as long as I maintain pressure. Release it and back to no or rarely horn working. Clock spring or ?
  10. Feb 13, 2024 at 5:26 PM
    Assembly.
  11. Feb 13, 2024 at 5:38 PM
    steelgtr
    Bob
    Sorry, Complete clock spring assembly is what you are recommending?
    bob
  12. Feb 13, 2024 at 6:17 PM
    I think it’s probably the horn mechanism that I believe is integrated with the airbag assembly.
  13. Feb 13, 2024 at 7:08 PM
    steelgtr
    Bob
    Thanks again. Do you have pic or a link. I have no idea where to start!
    bob
