2000 tundra transmission went up
Discussion in '1st Gen Tundras (2000-2006)' started by Austincolby, Jan 21, 2018.
  1. Jan 21, 2018 at 7:28 PM
    Austincolby
    Austincolby [OP] New Member
    Austin
    2000 Tundra 4x4
    Got on this thread for some insight. My mom recently bought a 2000 tundra 4.7 v8 4x4 from a guy that got it from a Toyota dealership that used it to tow cars around. Little over 120k on the motor, drove it 3hrs from picking it up and around town for about a month with zero problems and then all sudden driving to a buddy's house the transmission just went out without any warning or clunk or anything. From what I've read the early first gen tundras had poorly designed gears. But on to my original question, I've been looking around for a 03, 04 tranny with no luck, as far as putting an 05 in it what's involved and is it possible? Would also like to know if anyone has put an older 4runner transmission in there's and if it's a good swap? Any advice would be appreciated, thanks!
  2. Jan 21, 2018 at 7:57 PM
    WhiskeyPapa
    WhiskeyPapa New Member
    I have an 04 4x4 tranny that might work
  3. Jan 21, 2018 at 8:00 PM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    I'm not a tranny guy so can't help....but good idea...a Toyota engine with only 120K still has a lot left in her!
  4. Jan 21, 2018 at 8:18 PM
    Austincolby
    Austin
    2000 Tundra 4x4
    What is it out of and how much?
  5. Jan 22, 2018 at 2:17 AM
    WhiskeyPapa
    It came out of a 2004 tundra double cab with 151,000 miles. It includes the torque converter, shift cable and crossmember if you need it.
    I'd like to get $450.00 for it. If you're interested I also have the transfer case.
  6. Jan 22, 2018 at 2:19 AM
    WhiskeyPapa
    FYI, the truck also had the 4.7l I force V-8
  7. Jan 22, 2018 at 2:45 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    03-04 V8 4x4 is a direct swap except that they use a different fluid than the 00-02. 05-06 is a completely different transmission.
    The one Whiskey is selling is good with a reasonable price.
    Pearl-snap likes this.
  8. Feb 11, 2018 at 5:32 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Can you shed more light on the transmission issue....just went out? So I'm sure you made sure it was full of fluid on the dipstick, when running of course. Shift cable didn't snap? Not one of those drive by wire models and you push on the gas and nothing happens? That's very low mileage for a Jap transmission to go, but anything is possible. Did these have issues, I would like to find out myself, and what years swap over. Are the 4x4 and 2 wheel drive transmissions the same by just adding or removing the tail shaft? < Might open up some options if you need one.
  9. Apr 13, 2018 at 12:35 AM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Never heard of one simply "going out". If the old owner towed a lot in OD it will take out the gear. When mine went out it just started making a noise when shifting (sounded just like putting an old car in gear with bad U-joints). Drop the pan and see if you have stuff in there that doesn't belong (mine had lots of nice metal chunks). Other wise, I'd say get it checked out before simply assuming it needs to be replaced.
  10. Apr 10, 2021 at 3:41 PM
    ApocTheEnd
    ApocTheEnd New Member
    Where are you located whiskey? Did he end up buying your transmission? I am shopping for one, I have an 02 tundra with the same engine.
  11. Apr 10, 2021 at 3:59 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    WhiskeyPapa was last seen: Feb 16, 2018
