2000 Tundra trailer lights
Discussion in '1st Gen Tundras (2000-2006)' started by txagg, Jan 14, 2022.
  1. Jan 14, 2022 at 6:04 PM
    txagg
    txagg [OP] New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    My truck does not have the towing package from what I can tell. It does have a tow hitch installed, and I assume it's aftermarket. I don't see any trailer light connections under it. From some reading on here it seems like some of the early ones were not equipped at all. My question is- is there a preference on kit for this? Do they have one that is plug and play, or do I have to splice into some factory harness? I would be happy with a 4 flat plug in right now. But I also have a trailer brake controller and if it was not too much trouble would like to go 7 pin and put it to use.
  2. Jan 14, 2022 at 6:07 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    I had a 7 pin setup installed at an RV shop that a friend worked at. There is a plug and play adapter for the 4 flat. Have to have it since the wiring is funky back there. Think I have the CURT one.
    https://www.etrailer.com/t1-2000_Toyota_Tundra.htm
    tvpierce and txagg[OP] like this.
  3. Jan 14, 2022 at 6:20 PM
    txagg
    Central Texas
    Stone cold stock
    Awesome! Curt makes good stuff. Looks like I can use that one for now, and always run a couple of wires from the cab later on to do a 7 pin and trailer brakes.
  4. Jan 16, 2022 at 6:27 AM
    daveeasa
    David
    For upgrading to 7 later on, you could employ this kit:
    https://www.etrailer.com/p-ETBC7.html
    I'm very slowly working through plans for a custom 7 pin tow harness as close to OEM as possible. I'll try to remember to tag you if I get it all done.
    txagg[OP] likes this.
  5. Jan 16, 2022 at 7:35 AM
    txagg
    Central Texas
    Stone cold stock
    I ordered the curt kit you first suggested, as well as a 4 to 7 and 4 with mounting kit. Figure I can run the two trailer brake wires later when I get to it and not have to undo anything. I am a little concerned the curt kit might not work, as my truck doesn't have the factory tow packaged. They denote that on that on website. We will see soon enough.
    tvpierce likes this.
  6. Jan 16, 2022 at 7:41 AM
    daveeasa
    David
    Per my sticker I also do not have the tow package. But I did have the grey connectors.
    txagg[QUOTED][OP] likes this.
  7. Jan 16, 2022 at 2:16 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My 2000 came with 4 pin on a bracket under bumper left of hitch. It has a harness to the grey connectors
