2000 Tundra Limited with MAF codes and EFI #2 blown fuse....Help!
Discussion in '1st Gen Tundras (2000-2006)' started by Frankenauger, Dec 4, 2022.
  1. Dec 4, 2022 at 7:39 AM
    Frankenauger
    Frankenauger [OP] New Member
    2000 tundra limited
    Hi guys, this is a great site! Thanks for including me. I'm hoping someone can help me out. My truck starts and kills instantly. Then starts and stays running. I get a MAF fault code and my EFI #2 circuit blows a fuse. I replace the fuse and it runs good for a while. I'm able to erase the code and the CEL light goes out. Couple days later, it does it again. I can tell when that fuse blows because the engine starts to surge or cut in and out. I'm not sure really what it's doing. I installed a new MAF sensor when this started but I couldn't get the code to erase. I can only erase the code if I change out that blown fuse. I'm stumped! If anybody has had these same issues or has any ideas for me I appreciate any help you can give me. Thanks.
  2. Dec 4, 2022 at 10:51 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If you're blowing the fuse there is a short in the system somewhere. Either a bad part or something in the wiring.
    The wiring diagrams can be found here, you'll need to go through the circuit and find the cause.
  3. Dec 4, 2022 at 12:30 PM
    chrisf111
    chrisf111 New Member
    Had a similar issue. Ended up being a short that only shorted when the truck bounced just right.
