2000 Tundra Frame Recall
Discussion in 'General Tundra Discussion' started by PdiddyV, Jul 9, 2018.
  1. Jul 9, 2018 at 6:34 PM
    PdiddyV
    PdiddyV [OP] New Member
    All,
    I've search numerous threads looking for this topic but none were exactly like mine so I'm just throwing this out there hoping someone has solid information.
    I have a 2000 Tundra, SR5 with 100k on it. It runs great. I had both recalls done(2009 and 2012 at my Toyota dealership). The 2012 recall, they noted severe rust and even replaced the gas tank brackets but otherwise nothing was done. I now have a hole the size of a softball in the frame that is rusted through in two locations. The sway bar link even ripped out from it and can't be reconnected because of the rust/hole. My question is, since the recall was completed on time at a Toyota dealership, is the recall itself warrantied? Meaning, if the recall ended in 2012 and I found a hole in it in 2013, am I out of luck? I've seen threads that say the "recall warranty" is 10 years from the recall date or a total of 15 years from your date of purchase, but I can't find that in writing from Toyota. I called Toyota Customer Care and she didn't give me the answer outright but said that I should take it to my Toyota dealership immediately to have it "sprayed" because that is still under recall. Not sure what to think. I guess I probably have a hunk of junk now but I don't want to lose her, she's so nice otherwise!!! Thanks
  2. Jul 9, 2018 at 7:06 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Take it to the dealer, worst case you're no better off, best case you get a new frame.
    I still see posts around where people are still getting them replaced.
  3. Jul 13, 2018 at 2:07 PM
    PdiddyV
    Update: Ok, so the Toyota dealership has authorization to replace my entire truck frame under the recall. The issue is that when they take some of the 18 year old parts off of the frame, they won't be able to put them back on due to wear/tear/ rust etc... They estimate it will cost me 3-5k out of my pocket to get the recalled frame replaced now because of the cost to replace worn parts. The parts they are speaking of are not broken and are in working order as of now. Anyone else have this issue when they replaced a frame?
  4. Dec 19, 2018 at 2:01 PM
    2000Toy
    2000Toy New Member
    2000 silver Toyota Tundra
    stock
    PdiddyV where did you go Holland Michigan Toyota will not help me out at all. I would pay for the extra parts as needed if I could get the frame replaced.
    john.hoogeveen@vistaspringsliving.com
  5. Dec 19, 2018 at 2:46 PM
    larry2007
    larry2007 New Member
    Larry
    2007 Tundra
    Hi, I have a 2007 Tundra and received a notice to have it inspected for frame rust. Took it in and dealer said the rust wasn't bad enough to have the frame replaced. Three weeks later, I filled her with gas, pulled out of a gas station and the gas tank fell out of the truck. Has anyone else had this experience? Welding shop said the straps didn't rust out. The frame the tank is attached to rusted out. I have been waiting two weeks now for a new frame part from Toyota.
