2000 AC 4x4 2UZ 5spd re-build
Discussion in '1st Gen Tundras (2000-2006)' started by Nuclear_w0rm, Mar 24, 2022.
  1. Mar 26, 2022 at 5:42 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Too kind.... too kind...
  2. Mar 27, 2022 at 6:10 AM
    Chuck4x4
    Chuck4x4 New Member
    Kentucky
    2002 rebuilt tundra
    JDM engine swap, dog house swap
    Newer guy here just surfing the page trying to figure out what I need for my 3.4 a/t to m/t swap with a R150. Do you have pictures of your pedal assembly? I was given a clutch pedal from a 88 Tacoma but it looks as if it’s going to be a direct bolt in to where the brake pedal assembly is currently.
  3. Mar 27, 2022 at 6:32 AM
    Nuclear_w0rm
    Nuclear_w0rm [OP] New Member
    Sid
    ON
    2000 AC V8 5SPD 4X4
    I don't have pictures of it outside but will take some of it installed. The clutch pedal should bolt it easily, it's the brake pedal that's different. The Tacoma brake assembly does not bolt in. You have to use the tundra mount/tundra Mt brake pedal.
    Also the parking brake pedal will have to be removed and swapped to a pull style handle if you want to keep it stock looking.
  4. Aug 13, 2022 at 8:36 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    So what was involved with the bellhousing swap. (Sorry if it was posted here already. I’m at work and skimmed) I need to figure this out for a potential 3UZ swap into a taco
    5N0W808 likes this.
  5. Aug 15, 2022 at 10:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    @empty_lord
    5N0W808 likes this.
  6. Aug 15, 2022 at 10:43 AM
    OK, @Nuclear_w0rm, what's the story on the bellhousing? :D
    I checked your thread creation history and I don't see a separate thread.
    bmf4069 likes this.
  7. Aug 16, 2022 at 5:04 PM
    Nuclear_w0rm
    Sid
    ON
    2000 AC V8 5SPD 4X4
    Been meaning to write that up, life got in the way lol.
    The Thailand housing is meant for the shorter input shaft version of the r150 for a plug n play install. I had to machine 5mm off mine and re-machine the pilot seat.
    And the slave mount is extra tall and needs to be trimmed down as needed and re-tapped. Other than that it should just work.
    I used a stock flywheel and clutch from a 3vz and it's holding up great so far after 5000kms.
  8. Aug 18, 2022 at 6:27 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Nope
  9. Aug 18, 2022 at 7:37 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    RIP :(
    5N0W808 and bmf4069 like this.
  10. Aug 19, 2022 at 12:11 AM
    empty_lord
    05 rollover special
    Well damn. I was hoping it was more bolt on ish. I’ve got a wrecked 01 taco with a r150f that may end up under the tundra if the auto pisses me off enough
    Good to know the pedal bracketry from said wreck is useable to me too
    bmf4069 and 5N0W808 like this.
  11. Aug 19, 2022 at 4:14 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Has it pissed you off yet?
    5N0W808 likes this.
  12. Aug 19, 2022 at 6:06 AM
    empty_lord
    05 rollover special
    Nein
  13. Sep 1, 2022 at 6:50 AM
    Nuclear_w0rm
    Sid
    ON
    2000 AC V8 5SPD 4X4
    If you decide to to pull parts off the wreck, I would suggest taking the T handle ebrake and equalizer off the frame if you want to keep the parking brake working on the Tundra.
    empty_lord[QUOTED] likes this.
  14. May 30, 2023 at 10:05 AM
    PseudoKirby
    PseudoKirby New Member
    00 tundra
    yeah I cant find that separate thread either, just picked up an R150F from an 03 tacoma, trying to plan this for my 00 2UZ tundra
    those shift solenoid CELs, were you able to get rid of them at all? does cruise control still work?
    and I figured I would need tundra manual pedals, but did I see yall say tacoma pedals will work?
    also also also, how hard was it for you to find driveshafts lol
  15. May 30, 2023 at 11:03 AM
    Nuclear_w0rm
    Sid
    ON
    2000 AC V8 5SPD 4X4
    Been lazy lol didn't make another thread. Gonna get to it when I update the clutch to an LCE unit. The OEM 3vz is tired already after 12k km and 34s - drives like a CVT sometimes lol.
    Shift solenoid CELs are defeat-able with some resistors (plenty of threads on how to do that/ill dig up the value). Getting the trans vss signal is another story for Cruise and will be the only CEL. IMHO the 99-02 2uz ECU's are the best for this swap as they don't really care what gear the nonexistent trans is in for the engine to run properly. I didnt pursue cruise it as I swapped my steering wheel to one from a '18 Highlander for wheel heat and the controls added more complexity - maybe one day!
    Pedal wise if you want an easy swap manual tundra is the way to go. If not then a taco clutch with the auto Tundra brake can work - need to flip the mount and re-weld to change the angle of the pedal so it clears the clutch. Also, try to get the taco E-brake and equalizer off the frame as the foot operated unit will have to be deleted.
    shifty` likes this.
  16. May 30, 2023 at 11:32 AM
    PseudoKirby
    00 tundra
    really? I was looking at the VSS on the auto and the VSS on my 5 speed and they look the same, at the very least it looks like another 3 pin connector on the tail shaft, what year is your trans? edit, I see it, 98, my 5 speed is an 03 and my truck is an 00
    I wish toyotas parts website didnt nerf itself so I can check compatibility
  17. May 30, 2023 at 11:40 AM
    Nuclear_w0rm
    Sid
    ON
    2000 AC V8 5SPD 4X4
    The vss off the transfer case is pnp and drives the speedo. There's a second vss on the trans that the ecu uses for cruise and shift points. Now that I think of it, I would pull all the sensors off the auto and plug them into the tundras harness along with the range switch and tcase motor to simplify life. Maybe remote mount the range switch to "change" gears and attempt cruise...hmm now my gears are turning lol
  18. May 30, 2023 at 11:51 AM
    PseudoKirby
    00 tundra
    in order to realistically do this swap in california I need to be able to get rid of all CELs, I can live without the cruise control, but if it throws a MIL on the gauge cluster then I cant pass smog
  19. May 30, 2023 at 11:55 AM
    #49
    importxpresions
    importxpresions New Member
    2001 SR5 AC Imp Jade Mica 2WD
    Cheese and crackers that's awesome. Well done
    FrenchToasty likes this.
  20. May 30, 2023 at 12:31 PM
    #50
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    bmf4069 likes this.
  21. May 30, 2023 at 2:03 PM
    #51
    Nuclear_w0rm
    Sid
    ON
    2000 AC V8 5SPD 4X4
    Pretty sure that's a R155F (4cyl) since he took the BH off. RA60s are integrated.
    TX-TRD1stGEN[QUOTED] likes this.
  22. May 30, 2023 at 2:09 PM
    #52
    Nuclear_w0rm
    Sid
    ON
    2000 AC V8 5SPD 4X4
    Ahh should've led with California. Here in Ontario, Canada we abolished smog ;). Do they allow non emissions related CELs? Or none at all? Before scrapping smog here, they switched to OBD based testing. As long as the emissions monitors were ready you'd pass.
    Only other option may be finding the unobtainable UAE 2uz MT ecu or getting a standalone (Haltech etc). At that point the cost of the swap makes it less appealing.
    I'm going to check out the sensors on the spare a340 I have and see how the ecu can be tricked in a few weeks time. Thanks for waking me up!
  23. May 30, 2023 at 2:13 PM
    #53
    Hey hey! Speaking of Canadians, it's Ian from Xtreme 4x4 bitd. I suspect if you ping him, he'll probably answer. I used to watch he and Jessi every weekend, like, 20 years ago or something.
    bmf4069 and TX-TRD1stGEN[QUOTED] like this.
  24. May 30, 2023 at 2:17 PM
    #54
    PseudoKirby
    00 tundra
    Non emissions ones sure, but it can't illuminate the little engine light on the gauge cluster (MIL)
    People have been flashing codes out, which can work for me since it won't be BARd
  25. Jun 1, 2023 at 9:16 PM
    #55
    dmamrenko
    dmamrenko New Member
    Dennis
    Salvage Tundra Rebuild
    Minor
    Great work!
    What a gem
  26. Jun 2, 2023 at 5:40 PM
    #56
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Great build
