2000-2006 Tundra big brake upgrade kit (14WA calipers)
Discussion in '1st Gen Tundras (2000-2006)' started by googlydoodle, Jan 30, 2020.
  1. Dec 9, 2020 at 10:47 AM
    #121
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    BTW, Rock Auto accepted my 13WE calipers as core returns. Here is a breakdown of what this job has cost me so far. I was going to need new pads and rotors either way so one could argue that's a requirement no matter which brake upgrade you choose. The pads I pulled off were almost gone. Even if I have to replace the MC (it sounds like it was on it's way out anyways) that's only gonna bring me up to $615-700. After the core refund the calipers only cost $110.
  2. Dec 9, 2020 at 12:41 PM
    #122
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Based on the description in the picture I'd say that's a clutch master cylinder, not a brake master cylinder.
  3. Dec 9, 2020 at 12:47 PM
    #123
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's what it seems. Based on what I'm finding the master has in fact been discontinued but a few places still claim to be able to order them. They are not cheap.
    I'm considering trying the $35 rebuild kit that @speedtre mentioned. There really isn't much to it.
  4. Dec 9, 2020 at 12:58 PM
    #124
    Lil Steve
    Gilbert, AZ
    Definitely worth a shot. I used to own a 97 Honda that the pedal would sink/feel mushy like you've described. An aftermarket replacement from Rock Auto got the pedal nice and firm again. I hope the rebuild kit does the trick! Don't forget to bench bleed it!
  5. Dec 9, 2020 at 1:18 PM
    #125
    speedtre
    speedtre New Member
    Inland Northwest
    I would try the rebuild kit...if that doesn't work I'd try the T100 MC....it's not that expensive.
  6. Dec 9, 2020 at 1:41 PM
    #126
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    Okay...
    But I've used them and I know how they work. I don't know how the other person has used theirs and how well those work. There are certain parts I'm willing to buy used but they don't affect how the truck stops or turns. The only exception to that is a good set of used wheels and those can be check for bends or cracks.
    Again, I understand the budget issue but given a new (or even rebuilt) part like this lasts years or decades I think the investment is worth it for my safety, especially if I'm towing 5,500 lbs.
    Tundra2 likes this.
  7. Dec 9, 2020 at 2:26 PM
    #127
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I understand the sentiment. Have you've ever bought a used truck, would you tow with it? Its made from used parts.
    I'm not saying buy a crappy used part, aybe if you live in the rust belt its a bad idea. Inspect the part and be sure its in good condition. I wouldn't buy used wearable items like pads, but a master cylinder or caliper for sure. The only reason I don't with my truck is there aren't many Tundras in pick a part near me.
    Around 2004 my brothers beloved Honda CR-X was stolen and completely stripped. They even took the carpet, it was unbelievable. We rebuilt it completely from parts at pick a part, even the motor. Those parts were all genuine Honda and the car lived happily ever after. The next year we dropped a turbo in that car and it runs like hell, probably low 12 second quarter miles.
    noahrexion, theblurry1 and speedtre like this.
  8. Dec 9, 2020 at 2:26 PM
    #128
    Professional Hand Model
    Hand Protectors
    I’d be open to a MC Rebuild just because. Also, I’d even consider the T100 MC instead just because. This would be on WL13 Remanufactured Calipers.
    If the Cylinder Pressure is better on the rebuild or upgrade T100 MC, will it make the truck brake better compared to the OEM MC equipment?
    Basically, instead of going bigger brakes calipers one would instead be optimizing the MC and/or Booster to maximize pressure at the existing brake calipers (regardless of size).
    theblurry1 likes this.
  9. Dec 9, 2020 at 2:30 PM
    #129
    Hand Protectors
    My WE13 Calipers were seized on the inboards pistons. I can only imagine a caliper thats been sitting on an unused truck for a year or two without having pressure working the Mojo every so often. I’ve heard of Calipers seizing after a week of no use sitting in the driveway.
    Tundra2 likes this.
  10. Dec 9, 2020 at 2:33 PM
    #130
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Rebuild kits are cheap and these brakes can be found on 2020 models, I bet those are in better shape than my 2 year old reman calipers.
  11. Dec 9, 2020 at 2:37 PM
    #131
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My junkyard WE calipers have been on my sequoia for 4 months now and work great. I understand your concern, but decent junkyard test things. Before I got them the guy checked the pistons to make sure they were in good shape.
  12. Dec 9, 2020 at 2:50 PM
    #132
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It isn't for everybody, but neither is removing Toyota designed brake system and molesting another Toyota designed brake system to fit on our trucks. Then again, Tacoma guys do it with our calipers too.
    :D
    theblurry1 and Tundra2 like this.
  13. Dec 9, 2020 at 9:12 PM
    #133
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    No. The overall braking ability is determined by the pads/rotors/tires. The size of pistons vs the master determines how much effort it takes you to apply the aforementioned parts.
    Going to a larger master will stiffen the pedal but not increase your braking capabilities.
    But will increase your leg gains lol.
  14. Dec 25, 2020 at 6:11 PM
    #134
    toyoboyo
    toyoboyo New Member
    Been away for a while, but someone asked if I ever solved the mushy pedal.. So a recap:
    2005 Sequoia stock 13WL brakes with new OEM rotors/pads... Crappy brakes. Mushy, scary. Bled brakes a dozen times to no avail (no exaggeration).
    Upgraded to 14WA with Brembo rotors and Hawk LTS pads... Vastly improved braking power. They are easily able to lock up and skid 285 BFG tires. Brake pedal still mushy, but not scary to drive. Bled brakes at least 6 times all around, properly. No avail.
    Installed brand new master cylinder from O Reilly. One of their better brands, forgot the name... Brake pedal feel improved. Still mushy, but half as mushy as before therefore an improvement... I no longer have any complaints about my brakes.
    If the Sequoia didn't have ABS, I would have swapped and tried the T-100 MC.
    Weagle, theblurry1, Tundra2 and 3 others like this.
  15. Dec 25, 2020 at 6:58 PM
    #135
    speedtre
    speedtre New Member
    Inland Northwest
    Just an FYI, there is a T100 MC that is ABS compatible...ABS was optional on T100s.
  16. Dec 25, 2020 at 7:31 PM
    #136
    toyoboyo
    toyoboyo New Member
    I saw that but the position of ABS hardlines didn't line up among another difference. Just didn't want to complicate things.
    The bore on the T-100 MC is definitely larger though... Some of you non ABS guys need to try this mod.
    Tundra2 likes this.
  17. Dec 27, 2020 at 6:24 AM
    #137
    Hand Protectors
    I wonder if there is a way to bore our original Master Cylinder and use some larger rubber plungers inside?
    In effect, you’d be going from 13/16” up to a 1” Bore keeping all other things the same.
    Sounds risky and impossible without precision tools.
    Tundra2 likes this.
  18. Dec 30, 2020 at 9:19 AM
    #138
    TundraDCCO
    TundraDCCO New Member
    2006 Tundra DC 4x4
    I have a 2006 DC with 4WD with ABS. I purchased all new OEM parts from OEMPartssource.com (calipers, pads and rotors) and new steel braided brake lines from Crown. With machining and postage I am in for 776.27.
    I went the extra step and tried to purchase a used T100 brake booster ($94) and master cylinder ($57) from a 1998 T100 with ABS on Ebay. I later found out that there are two separate part numbers for the brake boosters 44610-34010 (2WD) and 44610-34020 (4WD) both unavailable new and I really don't know what the difference is? MC part numbers were the same for 2WD an 4WD. If you are looking for a quick and convenient bolt on similar to what works on earlier first gen Tundra's without ABS, think again. This was beyond my skill set. Included are pictures of the T100 BB and MC (with ABS). If someone can provide some simple logic and instructions on how to make this an easy application please let me know.
  19. Dec 30, 2020 at 9:25 AM
    #139
    speedtre
    speedtre New Member
    Inland Northwest
    You will find some good info here...
  20. Dec 30, 2020 at 9:26 AM
    #140
    TundraDCCO
    2006 Tundra DC 4x4
  21. Dec 30, 2020 at 9:36 AM
    #141
    TundraDCCO
    2006 Tundra DC 4x4
    Speedtre. Thank you for the link. I had read that a few weeks ago. I might be missing something but this seems to be for non-ABS applications.
  22. Dec 30, 2020 at 9:58 AM
    #142
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @TundraDCCO you unfortunately have the bastardly over complicated 2006 master cylinder. I believe those come on some 05 and 06 double cab models, possibly other models of the same years.
    03 access cab with abs, I replaced the booster and mc last year but did not try the T100. Note how mine doesn't have that extra manifold between booster and cylinder.
    FirstGenVol and TundraDCCO like this.
  23. Dec 30, 2020 at 10:05 AM
    #143
    speedtre
    speedtre New Member
    Inland Northwest
    Isn't that the setup for VSC equipped trucks....? If so, I expect that throws a whole other variable in there for all this....
    des2mtn likes this.
  24. Dec 30, 2020 at 10:20 AM
    #144
    TundraDCCO
    2006 Tundra DC 4x4
    It does have the VSC setup.
    I think I will see how the truck does with just the brake upgrade and see how the pedal responds. If too squishy, I may look to other BB/MC options.
    Geoffrey Beers (FB Tundra 1st Gen Page) was kind enough to suggest a work around and provide the following image: "
    "So if I remember correctly. Your factory style master cylinder is what’s called a quick take up valve. It means it has a larger bore piston that is meant for the rear that quickly engages the rear brakes. It’s a drum brake thing.
    The other thing I think you have is a three port master cylinder.
    The two front ports are for the front and rear brakes. The 3rd port near the brake booster is most likely a brake fluid return from the LSPV valve.
    I Believe all you need to do is cap off that return LSPV return and convert to a manual prop valve for the rear."
    speedtre likes this.
  25. Dec 30, 2020 at 10:35 AM
    #145
    TundraDCCO
    2006 Tundra DC 4x4
    Thanks Darkness for showing me AC with ABS application. That looks like a much simpler and cleaner install.
  26. Dec 30, 2020 at 10:38 AM
    #146
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, and its ungodly expensive and hard to find when a replacement is needed.
    speedtre[QUOTED] likes this.
  27. Dec 30, 2020 at 4:26 PM
    #147
    toyoboyo
    toyoboyo New Member
    What about this MC merits an "upgrade"? Looks interesting but I need specs. Bigger bore? If one can confirm, I'd buy that and try it but my brakes are fine at this point.
    I apologize for the lazy response, but I have exhausted myself looking for answers in regard to the ABS T-100 swap... Basically, if you've got a newer tuck with ABS... You're SOL unless you are a master tech who can fab something up.. There's no plug and play.
    I spent a couple hours for a few nights referencing photo after photo, spec after spec. Everything from bore size, brake booster mounting points, resevoir plugs, ABS hardlines.. If one or two things line up, something else doesn't. I don't ever want to go through that again... Maybe one day when I'm bored and my OCD kicks in randomly.
    My truck is a 2005 Sequoia with ABS, VSC, and all that mumbo jumbo.
  28. Dec 30, 2020 at 11:56 PM
    #148
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Darkness, speedtre and evilrb like this.
  29. Dec 31, 2020 at 6:10 AM
    #149
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I really don't see the T100 swap being that realistic for me. I read that Tundra Solutions link multiple times and never got a clear answer as to how I would do it.
  30. Jan 5, 2021 at 8:42 PM
    #150
    Kcrusher62
    Kcrusher62 New Member
    Does anyone who has done this conversion have the part number for the 14wa calipers, my research and checking with toyota parts keeps leading me to the 14wb calipers, after reading up on the 14wb they do not work for this conversion? help plz
