2000-2006 Tundra big brake upgrade kit (14WA calipers)
Discussion in '1st Gen Tundras (2000-2006)' started by googlydoodle, Jan 30, 2020.
  1. Mar 14, 2020 at 5:06 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    SOS performance makes an adapter to make use of the sequoia master as well
  2. Mar 14, 2020 at 10:24 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I understand that your main dig is FB. But this forum is more of a knowledge base than FB will ever attempt to be. How many more times do you wanna hear about which LBJ to buy? Or max tire size? FB is for the dumbasses. This forum is where you can find educated dumbasses who post educated guesses to peoples problems. Just hang out here a but and see how much better it is than FB.
    As a note, I asked about how to loosen my UBJ on FB seeing as how I was banned from here. I received about 0 helpful posts, 10 telling me to hit it harder with my purse, and 300 about how not to use moog. I'm just saying, there's a reason most of us don't co-mingle. The FB page is shit. If you come over here you can get all your knowledge to people who will actually use it, not posers with purses.
  3. Mar 15, 2020 at 5:25 AM
    Professional Hand Model
    Hand Protectors
    Wooo weeeee! Sounds like a high dolla upgrade with lots of peripheral work outside of just replacing the calipers and rotors.
    Looks to be $1000+ for new: rebuilt calipers, pads, rotors, double diaphragm, remote LSBP Valve.
    Stoked for whoever does this. I’d love to be able to compare the upgrade coming from 13WL having just upgraded from seized 13WE.
    dadjazz, Sunnier and bmf4069 like this.
  4. Mar 15, 2020 at 7:41 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'd like to see some 60-0 numbers too. Even if they dont go down much, I'm betting the fade resistance improves greatly.
  5. Mar 15, 2020 at 7:45 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Request you work on your 30 day vacations so you can better share your knowledge :)
    Sunnier, Darkness and bmf4069[QUOTED] like this.
  6. Mar 15, 2020 at 10:09 AM
    empty_lord
    05 rollover special
    You don’t really “need” the portioning valve upgrade. The remote setup just allows you to control brake pressure instead of weight in the bed.
    I do believe I’m going all in though. The rear disc conversion, coupled with this front brake setup and a sequoia master.
    Should make the truck stop like no other and even better, no more drums. I hate them. Seriously. They work well. But that damn squeak unless you blow $100 a drum for new Toyota ones
    Weagle, Thrussn, speedtre and 2 others like this.
  7. Jun 8, 2020 at 1:34 PM
    toyoboyo
    toyoboyo New Member
    Bumping this thread.
    Has anybody purchased these calipers or gotten a hold of the OP? I rang the phone number and left a voicemail about a week ago and have not heard back.
    Anyone find a mill shop to get these milled out? Really want to do this upgrade.
  8. Jun 9, 2020 at 12:01 AM
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Looks like he sells them already machined: "I sell either Silver Zinc coated or Red Powder coated machined Calipers for $350.00 a set with no core charge. Shipping usually ranges from $30-$40."
    speedtre likes this.
  9. Jun 9, 2020 at 8:59 AM
    speedtre
    speedtre New Member
    Inland Northwest
    On FB he saids he's between moving shops, so he may be busy with that.... "Due to recent events I am in transition between shops and I have significantly reduced intake of customer vehicles until I can get back to a position where I can be up at full operation once again.
    "If you have reached out in the past and tried to call me or even schedule an appointment I am sorry for not being able to get back to you at this time.
    "I have an overwhelming amount of people reaching out to me everyday and it simply has become too much for me to maintain interacting with each person. If I accepted each and every phone call or text message I’d be on the phone 12 hours a day. Which translates to zero vehicles getting fixed in the shop.
    "Soon I will be back up at full operation when I get into my new shop location. Until then I hope you will understand my situation and I will anounce when I am ready to be back at 100%.
    " Thank you and have a nice day."
    Darkness and FirstGenVol like this.
  10. Jun 9, 2020 at 3:41 PM
    toyoboyo
    toyoboyo New Member
    Thanks speedtre.
  11. Jun 9, 2020 at 5:40 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I found a local shop to mill mine it was only 30 bucks a piece
  12. Jun 9, 2020 at 7:38 PM
    empty_lord
    05 rollover special
    3 mill off the ears correct?
  13. Jun 10, 2020 at 1:11 AM
    imDementeD
    3.5mm
  14. Jun 10, 2020 at 11:16 PM
    toyoboyo
    toyoboyo New Member
    Anything we should know before buying/installing?
  15. Jun 11, 2020 at 4:34 AM
    imDementeD
    I've seen some talk about people having to trim their dust shield but I didn't need to.
    It was straight forward swap. Brake lines were a pain and needed a little adjusting but I used the stock lines and got everything bolted up as it was, just bigger.
    theblurry1, Darkness and FirstGenVol like this.
  16. Jun 11, 2020 at 7:53 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Did you have the WL or WE calipers originally? I learned that the brake lines are actually different depending on the caliper.
  17. Jun 11, 2020 at 7:59 AM
    imDementeD
  18. Jun 11, 2020 at 11:55 PM
    toyoboyo
    toyoboyo New Member
    Nice, how much of a difference did you notice? I've got the WL but they're not enough for me.
  19. Jun 12, 2020 at 7:11 AM
    #49
    imDementeD
    At first, I didn't think it was that much because I did a quick drive of about a mile but after doing a hundred plus miles of normal driving I can tell a significant difference. The brakes were terrible and I was nervous anytime I had to suddenly brake. Now, I still get a quick panic but as soon as I hit them they work and the panic goes away immediately.
    Not sure if that makes sense but that's the best way I can describe it without scientific data to show the improvement.
  20. Jun 12, 2020 at 7:40 AM
    #50
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I need to upgrade because I still have a ton of brake fade. Normal driving is fine but if I ever have to do any heavy braking it's horrible. I have zero faith that I can stop.
  21. Jun 12, 2020 at 8:52 AM
    #51
    empty_lord
    05 rollover special
    I’ve found that towing, my brakes are going to kill me.
  22. Jun 12, 2020 at 2:48 PM
    #52
    Hand Protectors
    Reason why I recco towing under 4k lbs. with our trucks. The 5900lb spec limit is scary larry.
  23. Jun 12, 2020 at 2:49 PM
    #53
    Hand Protectors
    When you going to do your brakes?
  24. Jun 12, 2020 at 3:06 PM
    #54
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Probably not until this fall or maybe even next year. My pads still have a ton of life left. Why?
  25. Jun 12, 2020 at 3:28 PM
    #55
    Hand Protectors
    Was just curious.
  26. Jun 12, 2020 at 3:55 PM
    #56
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Was it the powerstop kit you went with?
  27. Jun 12, 2020 at 4:01 PM
    #57
    Hand Protectors
    I bought their Calipers individually off Big Gurrl. Also, bought their Pads individually. Bought some High Dolla Sham Wow Shims from the Stealer ($40). @bmf4069
    Shoulda just bought the Toy Shoes from Stealer as the come with the High Dolla Shims. Realized that after the fact. My overall cost would have been the same with better OEM Toy Pads $90. :annoyed:
    bmf4069 likes this.
  28. Jun 12, 2020 at 4:03 PM
    #58
    Hand Protectors
    My no name rotors, installed 2 years ago, are holding up fine.
  29. Jun 12, 2020 at 4:18 PM
    #59
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yup. I'm pretty worthless lately. They're still chilling waiting for me to quit being lazy.
    RhinoSB likes this.
  30. Jun 12, 2020 at 4:40 PM
    #60
    Hand Protectors
    You have lots of parts stock piled. Get to work!
    My offer is still open on you paying me $6k to snap Iron Man back into shape. All expenses paid. :D
    Sunnier and bmf4069[QUOTED] like this.
