2000-2006 Tundra big brake upgrade kit (14WA calipers)
Discussion in '1st Gen Tundras (2000-2006)' started by googlydoodle, Jan 30, 2020.
  1. Feb 1, 2023 at 12:51 PM
    #271
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That is exactly how mine looked after milling. It actually looks like they took more metal off the left ear than the right.
  2. Feb 1, 2023 at 12:56 PM
    #272
    Tundra Noob
    Tundra Noob New Member
    Ryan
    2005 Toyota Tacoma DC
    Kenwood Radio, Morel Maximo 602 MKII Speakers, Ebay Backup Camera, More to come!
    The machine shop sent me the picture, so I'm not sure. I hope it is just the reflection.
  3. Feb 1, 2023 at 1:01 PM
    #273
    Tundra Noob
    Ryan
    Need advice on Pads and Rotors... What is the popular combination? EBC, Powerstop, OEM... I just need good brakes.
  4. Feb 1, 2023 at 1:59 PM
    #274
    Might just be the lighting.
  5. Feb 20, 2023 at 12:19 PM
    #275
    S-Man
    S-Man New Member
    2002 Tundra
    I went with Lexus GX460 OEM pads and rotors from LexusPartsNow dot com.
    Don't forget squeal shims and retainer springs if you want to replace those.
    All in it ended up being around $300 for all that.
    edit: FYI I also had to trim my brake dust shield on the edges. NBD.
  6. Feb 20, 2023 at 12:45 PM
    #276
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    Nice. I assume that was just the front disc brakes? Would you mind telling us which exact parts you ordered with numbers?
  7. Feb 20, 2023 at 12:52 PM
    #277
    S-Man
    S-Man New Member
    2002 Tundra
    Should be able to find what you need on the website by setting your vehicle as a 2010 GX460. Pretty easy.
    Front Discs: Part No.: 43512-60190
    DISC, FR
    [GX460 | 2010]
    Replaced by: 43512-60191 (IDK what this means)
    Front pads: Part No.: 04465-60320
    PAD KIT, DISC BRAKE
    [GX460 | 2010]
    Squeal Shims: Part No.: 04945-60090
    SHIM KIT, ANTI SQUEA
    Retainer Springs: Part No.: 04947-35050
    FITTING KIT, DISC BR
    JustJake and JasonC.[QUOTED] like this.
  8. Mar 2, 2023 at 5:20 PM
    #278
    Egghead857
    Egghead857 New Member
    2006 Tundra DC
    The start of the 14wa upgrade... 3.5ish mm removed making the ears right at 1/2 inch thickPXL_20230302_233859461.jpg PXL_20230302_225530208.jpg
    S-Man, JasonC. and WaTrout88 like this.
  9. Mar 25, 2023 at 11:12 AM
    #279
    Egghead857
    2006 Tundra DC
    Well there installed adjusted the drums as tight as possible for best feel... And welcome to the rust belt..
    4Runner rims and brakes.. sequoia master and fj rear disk is in the future
    S-Man likes this.
  10. May 2, 2023 at 5:05 PM
    #280
    alltracman78
    alltracman78 New Member
    Nice upgrade! I'm going to have to look into this.
    I have an 01 V8 access cab. No ABS and the larger calipers. My brakes aren't soft at all but they do fade on hard braking and consistently warp the rotors.
    So larger front brakes should definitely help.
    One note on what calipers you buy, I have a pair of bought brand new rear calipers on my Sequoia from rock auto (don't remember the brand). They didn't even last 2 years before one of the rear pistons is frozen rock solid. And it's constantly driven. Doesn't sit.
    I should have know when I had to tap out the bolt holes for the slide bolts because the machining wasn't fully completed at the factory.
    For those of you putting aluminum or copper bushings around the bolts holding the caliper to the steering knuckle; you're risking the bolts attaching themselves to the caliper. It's called galvanic corrosion. Won't necessarily happen overnight, but enough time it will happen.
    Quick link
    https://www.appmfg.com/blog/4-facts-on-dissimilar-metal-corrosion
    If you're using aluminum the steel bolts and holes will steal electrons from the aluminum.
    If you use copper the copper steals electrons from the steel.
    If it gets bad enough it can completely seize the bolt to the caliper or knuckle.
    This is how the anodes in your water heater work, or the zinc blocks on boats.
    If you live in Arizona it probably won't be much of a problem because it's so dry, but if you live in the Pacific Northwest, or even worse the salt belt it can be a big problem.
    Just to clarify here because "weak brakes" can mean a lot of things; weak (or too small) brake booster won't cause soft brakes. It will actually cause a overly stiff pedal. Your truck won't stop as fast, because less effort is going to the brakes. But it can't cause a soft pedal.
    Also, the booster doesn't make (or kick out) vacuum. The engine makes the vacuum, the vacuum pulls against one side of the diaphragm in the booster, helping you push the pedal down.
    The more surface area the vacuum has to work against the more it helps you push the pedal down.
    A smaller brake booster doesn't necessarily mean less help though, if the booster has a dual diaphragm it can have more combined (2 diaphragms to work with) area than a larger single diaphragm booster.
    Same way a multi disc clutch can be smaller in diameter than a single disc, but has more clamping power because it has more total surface area.
    I don't know if the booster referenced has a dual diaphragm, they usually have a smaller diameter but a greater "depth", so they'll look more like a can.
  11. May 2, 2023 at 5:26 PM
    #281
    "Kick out" was maybe a bad term to use, and "amplify" (which is simply kicking something out louder IMO) is maybe more apropos to my original intent and easier to understand. I'd say semantics (or your interpretation) is the problem here, not me throwing out an invalid point. It's called a booster for a reason. But I appreciate the lecture, it may help others.
  12. May 3, 2023 at 4:57 AM
    #282
    alltracman78
    The brake booster doesn't amplify the vacuum either. It uses the vacuum to amplify (or boost) the pressure on the brake master cylinder.
    If you had said the booster kicked out the brake master cylinder I wouldn't have said a word.
    You said the brake booster kicks out (or amplifies, or any other synonym) the vacuum. Boosting the vacuum and boosting the brake pressure (via the pressure on the master cylinder) are two completely different things. Which is why I explained in detail. I'm not trying to quibble with you, just make sure the correct meaning is there. :)
    Mr.bee likes this.
  13. May 3, 2023 at 9:16 AM
    #283
    Please stop with the semantics argument. I understand what you're saying, and I'm telling you, we're saying the same thing. Whether it's phrased in the manner which you prefer it is another story, it is what it is.
  14. May 3, 2023 at 3:21 PM
    #284
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Want to mention two things,
    It’s been mentioned a couple times already, if your drum shoes are not adjusted close enough your pedal travel will increase. This will cause a squishy pedal with lots of travel.
    I think many people may be damaging their brake booster when bleeding their brakes. Your brake pedal is not designed to go the the floor. Sometimes this happens while bleeding. Place something under your pedal while bleeding brakes to prevent this.
  15. May 3, 2023 at 3:38 PM
    #285
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Damaging the booster or master cylinder?
  16. May 3, 2023 at 6:27 PM
    #286
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Both can be damaged while manually bleeding brake systems by pedal traveling beyond the normal range.
    FirstGenVol[QUOTED] and shifty` like this.
  17. May 3, 2023 at 6:30 PM
    #287
    General rule of thumb: Seals and diaphragms don't love being pushed to their limits. (Nor beyond)
  18. Jun 16, 2023 at 7:27 PM
    #288
    Animus313
    Animus313 New Member
    Looking to do the big brake upgrade on my 06 DC. Instead of starting another thread thought I'd just post here on asking for a double check on what I'm ordering. Going from rockauto: Listed as parts for the 2015 4Runner:
    Calipers: New right ULTRA-POWER 196278, new left ULTRA-POWER 196279
    https://www.rockauto.com/en/moreinfo.php?pk=11884573&cc=1445180&pt=1704&jsn=2856
    https://www.rockauto.com/en/moreinfo.php?pk=11884577&cc=1445180&pt=1704&jsn=2854
    Rotor & brake pad kit: POWER STOP CRK5873
    https://www.rockauto.com/en/moreinfo.php?pk=10184924&cc=1445180&pt=13824&jsn=2857
    I am likely going to get stainless steel break lines as well. Can someone recommend a good source for those?
    Next question with the break lines. I 90% sure I do not have VSC as I do not have a dash VSC light when just turn to ACC or a VSC off when in 4hi/lo. Is there a better way to verify this?
    Last questions is I see a varied range on mill depth of 3mm-3.5mm it seems. Not sure it's that noticeable of a difference but what really has everyone tired?
    Let me know if I'm missing anything parts wise or general thoughts on it. Thanks.
  19. Jun 16, 2023 at 9:33 PM
    #289
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I recommend the Stoptech lines. Part number 950.44007. Just replace the rubber line. For the hard line that goes into the caliper, I recommend just reusing it, or buying an OEM replacement.
    Do you have an "Auto-LSD" button next to your 4WD buttons? That's the quick way to tell. That button isn't for VSC, but trucks with this button have VSC.
    Otherwise, pop your hood and look at the brake booster and master cylinder in the driver's side of the engine bay at the firewall. If it looks like this with a typical vacuum booster, you do not have VSC.
    The trucks with a hydroboost master cylinder should have VSC and an auto-LSD. That master cylinder looks like this:
    Hoferkill and Jack McCarthy like this.
  20. Jun 19, 2023 at 8:06 PM
    #290
    Animus313
    @des2mtn Thanks for the recommendation. I did find the Stop Tech break lines but wasn't sure because the price comparisons to others. I'll likely go with them then.
    100% sure now VSC do not have No Auto-LSD button and my master cylinder is not the VSC one.
  21. Jul 16, 2023 at 8:28 PM
    #291
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    Just wrapped up installing the front GX460 big brakes, as well as SOS Performance rear disc conversion kit using FJ Cruiser rotors and calipers. Installed on my 2006 Tundra DoubleCab 4x4. Non-VSC. I am absolutely BLOWN AWAY how well this thing stops now.
    I was a bit nervous going for it given the mixed results folks have had, but it seemed like the ones having the most success are the later DoubleCabs with the non-VSC like I have. So I went for it. I also actually bought the replacement master cylinder from SOS, just in case, but I decided to do it at a later date if necessary, after doing the discs all around. I also left the stock rear LSPV in place with the same reasoning--swap it out later, if nessary. But this thing is stopping so well right now with just the GX460 fronts and FJC rears, I'll just be leaving it and running it for now.
    Pedal feels absolutely awesome too. No excessive travel or anything. Brakes start to grab quick (but not too quick) and amount of travel feels awesome. Way better than before. Maybe is mostly the front GX460 stuff, but I cant really say for sure, but I absolutely HATE drum brakes. No.debate on "they just need to be adjusted properly" blah, blah. They're bullsh!t to work on regardless, and if they're so damn great, why the hell aren't they still on the fronts of every vehicle like in the old days? LOL. Ya, cause they suck. IMO, this is how the 1G Tundra should have been from the factory. --able to stop well.
    Specific parts:
    -OEM Toyota GX460 calipers, machined by Jim Smola (I think he does 3.5mm shaved off)
    -Advics GX460 calipers and OEM pads
    -SOS rear kit using centric pads and rotors and whatever calipers SOS sends
    Overall, on the SOS kit, it seems like a decent kit, time will tell. One thing I am not stoked about, is that the calipers brake lines do not line up anywhere near the OEM hard lines on the axle. I had to bend them up and around in a terribly ugly loop. I'll def be replacing the hard lines with some new custom hard lines, asap.
    20230713_162304.jpg 20230713_123007.jpg 20230713_192934.jpg 20230716_204317.jpg
    JasonC., Mr.bee, shifty` and 2 others like this.
  22. Jul 17, 2023 at 6:54 AM
    #292
    Side Q for you, since I expect my garage to look about like yours this coming weekend.
    What are you using for lighting in your wells? Is that some kind of battery-based magnetic LED or something?
    digitalferg[QUOTED] likes this.
  23. Jul 17, 2023 at 12:15 PM
    #293
    Casper421
    In the woods
    06 DC
    Harbor Freight magnetic work lights. Rechargeable and will fit most places. Or Scamazon.
  24. Jul 17, 2023 at 1:27 PM
    #294
    digitalferg
    Yep. Cheapy rechargeable magnetic work light from Amazon in the rear in that pic. Light on the front well is from an external de-walt-battery-compatible cordless work light.
    The rechargeable magnetic one has been instrumental in my endeavors. Can attach about anywhere using the magnet and no cord in the way ever.
    MAXXEON MXN00810 WorkStar Cyclops, USB-C Rechargeable LED Inspection Light, Red, (Pack of 1) https://www.amazon.com/dp/B07NGHPBXM
    Cordless LED Work Light for Dewalt 18v 20v Battery, 34W 3400Lumens Underhood Work Light with USB & Type-C Charging Port, LED Flood Light for Dewalt 20v Tools, Workshop, Camping, Outdoor, Emergencies https://www.amazon.com/dp/B0BDDY4C6Y
    shifty`[QUOTED] and w666 like this.
  25. Aug 3, 2023 at 11:21 AM
    #295
    SPB05DC
    SPB05DC New Member
    Sam
    2005 Black Tundra DC
    New member here. Preparing to do this upgrade on my 05 DC. What is the best way to get ahold of Jim Smola for the caliper machining?
  26. Aug 3, 2023 at 11:27 AM
    #296
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Instagram or Facebook
  27. Aug 3, 2023 at 2:11 PM
    #297
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Jim Smola (864) 205-6175
    Instagram @jimsmola
  28. Aug 3, 2023 at 2:23 PM
    #298
    SPB05DC
    SPB05DC New Member
    Sam
    Thank you both! I sent him a message on IG.
    2006Tundra[QUOTED] likes this.
  29. Aug 3, 2023 at 2:24 PM
    #299
    2006Tundra
    Lou
    Long Beach, CA
    You're welcome.
  30. Oct 4, 2023 at 8:37 AM
    #300
    Hard_Knox_Blount
    Hard_Knox_Blount New Member
    East Tennessee
    2005 Tundra SR5 4.7 DC 4x4
    None yet, but big plans
    Bringing this back from the dead, do you have the original dust shields installed here or did you use different dust shields? I'll be doing the big brakes soon and my dust shields are all rotted out. I'm debating whether to replace them or just remove them. Thanks.
