200 Watt fixed solar panel installed
Discussion in '2.5 Gen Builds (2014-2021)' started by jpbewley, Oct 15, 2019.
  1. Oct 15, 2019 at 10:38 AM
    jpbewley
    jpbewley [OP] New Member
    Installed the 200 Watt fixed solar panel on the ARE MX HD Camper shell... It's hard to see and hard to take a good picture of... but that's really the point. My goal was that you wouldn't really even know that it is there.
    I used a flexible 200 Watt panel. It's attached with 3M VHB TAPE. I've used this on several other builds and it holds up great. I routed the wires down through one of the existing screw holds for the roof rails and RTV siliconed in the cable route.
    The whole cable run is about 6 feet. 200 Watts @ ~12 Volts is around 15 AMPS. Given this, I used 14 AWG wire.
    I used the Victron Energy MPPT 75 15 BlueSolar charge controller. On the load output side, I used the Blue Sea below deck panel which has 12 volt power port, 2 USB ports and a Voltmeter.
  2. Oct 15, 2019 at 10:41 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Very cool.
  3. Oct 15, 2019 at 10:43 AM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    Do you have a second battery or does it charge the truck? What is the use case you have for this?
    Rex Kramer likes this.
  4. Oct 15, 2019 at 10:49 AM
    P-Factor
    P-Factor New Member
    Outstanding! Great job with fit and finish! :thumbsup:
  5. Oct 15, 2019 at 10:51 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Thats sweet. I like how you cant realy tell its there.
  6. Oct 15, 2019 at 10:56 AM
    jpbewley
    It's tied into the truck battery at this point. I use the shell for camping and expeditions. It will offset the usage of my fridge, charging drone batteries, camp lights ect. I did a longer post on the shell in my build post here:
    https://www.tundras.com/threads/2019-tundra-trd-pro-overland-build.53431/
    lewi3069[QUOTED] likes this.
  7. Oct 15, 2019 at 10:58 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    If you have to remove it for some reason, how hard is it to get the VHB tape off???
  8. Oct 15, 2019 at 10:59 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    which panel is it??
  9. Oct 15, 2019 at 11:04 AM
    jpbewley
    It's a pressure sensitive tape so if you need to take it off, you can. The way I have done it in the past is to take a flat tool, slide it under the panel and give it a twist. Without that... I've been driving MY FJ for years and 1,000's of miles and the panels stay put.
  10. Oct 15, 2019 at 11:05 AM
    jpbewley
  11. Oct 15, 2019 at 11:08 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thanks man. Yeah I wasn't worried about it coming off, I was more worried about it leaving glue everywhere if you have to remove it. What about hot sun?? You think it'll last and not dry up??? I really want to add solar to my roof but I've been hesitant
  12. Oct 15, 2019 at 11:08 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Did you use the 3m VHB primer? I put 2 Renogy 100w flex panels on my parents Airstream. Used the primer.
    Tested a one square inch piece of tape with and without primer. Difference was very big. The piece with primer ended up getting cut down with a razor blade and covered by the panel. The piece without primer came off by rolling the edge back.
  13. Oct 15, 2019 at 11:37 AM
    jpbewley
    I'm two years in on my motor home and 1 year in on my FJ... so far no problems. I give them a little test "tug" every time I'm up there cleaning the panels.. and no issues. They have both seen very hot (Arizona summer 110+) and colder temps (20's). My experience has been that it comes off pretty clean if you need it to come off.
    osidepunker[QUOTED] likes this.
  14. Oct 15, 2019 at 11:38 AM
    jpbewley
    I didn't. I just cleaned the fiber glass shell and back of the panel with alcohol. That's the approach I used on the motorhome and FJ and haven't had any problems. I do test "tug" them from time to time when I clean the panels.
    Windsor[QUOTED] likes this.
  15. Oct 15, 2019 at 11:46 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Damn that's nice!
  16. Oct 15, 2019 at 11:54 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    That is awesome.
