  1. Jun 14, 2019 at 10:04 AM
    DexterL
    DexterL [OP] New Member
    16 crewmax platinum
    Inquiringone likes this.
  2. Jun 14, 2019 at 10:12 AM
    Inquiringone
    Inquiringone Play Things, What's Your Tundra Used For...
    Ter
    NorCal
    Super White 1794 CrewMax.
    To many to list
    Grab a 12 volt test light and start checking:notsure:
  3. Jun 14, 2019 at 10:31 AM
    NewImprovedRon
    NewImprovedRon "220, 221- WHATEVER IT TAKES" - Michael Keaton
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    Here is a fuse box diagram for my 2015. Your 2016 may be similar:
  4. Jun 14, 2019 at 10:42 AM
    DexterL
    16 crewmax platinum
    This one is a 2019
  5. Jun 14, 2019 at 3:10 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    Grab a test light and make sure your light illuminates on each side of the fuse.
    Have you checked if the owner's manual calls out fuse location?
  6. Jun 14, 2019 at 3:46 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Ok, not sure how applicable my fuse box diagram is then. I agree with @mojo , a test light is the easiest way to check fuses. It keeps you from having to remove each one and check it. Just be aware that some fuses are continuously powered, so you can check them without the key being in the ignition, and others are ignition powered and will need the key to be in the "on" position when checking them.
  7. Jun 14, 2019 at 7:18 PM
    Twinky
    07 double cab work horse
    Custom speed dent. Saving up for matching driver side speed dent.
    Did you check with the ignition on while probing with the test light?
    Just have to ask cause its one of those simple things that we all over look sometimes.
    mojojo likes this.
  8. Jun 14, 2019 at 8:25 PM
    Twinky
    Relay possibly went bad?
    Constant power and switch power reversed?
    A missing fuse?
    Wish I could offer some better suggestions, but maybe one of those things will remind you of something else that your not thinking about.
  9. Jun 15, 2019 at 5:47 AM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    Sounds like you should revisit the installation of your accessories.
    Twinky likes this.
  10. Jun 15, 2019 at 6:10 PM
    panicman
    panicman New Member
    Eric
    2018 SR5 TRDoffroad MGM
  11. Jun 15, 2019 at 6:21 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    This is weird.
    ...4...
    JMB and 2ndgenny like this.
  12. Jun 15, 2019 at 8:39 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    5?
    2ndgenny likes this.
  13. Jun 15, 2019 at 8:43 PM
    2ndgenny
    2ndgenny RENOVATING MY BASEMENT :(
    Hinton Alberta, Canada
    Oh8 Limited DC Bush Beater!
    OME 3.5” 613’s & Dakar leafs, SPC UCA’s Daystar bag cups and bags. Arb bumper/2” rigid led fogs. Debadged. Smoked tailights/3rdbrake. Magnaflow catback. aFe Magnum stage 2 intake. Official Dirty Seven Club Member!
  14. Jun 15, 2019 at 8:45 PM
    T-Rex266 Moderator Staff Member
  15. Jun 15, 2019 at 8:59 PM
    JMB
    Chesapeake, VA
  16. Jun 15, 2019 at 9:00 PM
    Twinky
    Pinay, JMB and jewsNbrews like this.
  17. Jun 15, 2019 at 9:12 PM
    SR5 AZUL
    SR5 AZUL TRD
    2015 Blue Ribbon Tundra SR5 Trd off road crewmax 4x4
    7
  18. Jun 16, 2019 at 2:23 AM
    panicman
    panicman New Member
    Eric
  19. Jun 16, 2019 at 2:57 AM
    OR18TRD
    OR18TRD Pândâ Crëw
    Pândâ
    PDX
    2018 Panda Crewmax
    Suspension: front- Bilsein 6112 set at 1.9”; Rear- bilstein 5160 with maxtrac 1” shackel. Wheels: Method MR308 roost wheels 18x9” +18 offset. Tires: 275/70/18 Goodyear wrangler DuraTrac’s Removed front mudflaps and moved front wheel well liner forward. Bakflip MX4 Tonneau cover Line-x premium bed liner aFe CAI Rear differential breather moved behind taillight Debadged Windows tinted 20% ESP locking long box rear seat storage OEM all weather mats 6 3/4” antenna Coverking leather rear seat cover
    Why was
    Afraid of
    Because
    9
    JMB, panicman, 2ndgenny and 1 other person like this.
