2" Leveling Kits
Discussion in 'Suspension' started by NY98M3, Dec 8, 2018.
  1. Dec 8, 2018 at 6:00 PM
    NY98M3
    NY98M3 [OP] New Member
    Looking to raise the front a bit on my 17' SR5. The truck is not used offroad. Its equipped with Firestone air bags in the rear for towing.
    I dont want to start playing with taking the factory struts apart.
    Im currently looking at these spacers that fit between the factory strut mount and the frame.
    2" spacers
    https://www.motofablifts.com/2007-2019-Toyota-Tundra-2-Front-Leveling-Lift-Kit-p/tun-2.htm
    Differential Drop Kit
    https://www.motofablifts.com/2007-2019-Toyota-Tundra-4WD-Differential-Drop-Drop-p/07tun-dd.htm
    Any cons to using these?
  2. Dec 8, 2018 at 10:12 PM
    Bigdogg621
    Bigdogg621 New Member
    Just got these in the mail yesterday. I’m planning on an install next week.
  3. Dec 14, 2018 at 8:04 AM
    NY98M3
    Received the 2" kit yesterday along with the diff drop kit. Ordered from Ebay, Everything was about 60 shipped which was about half the cost if you ordered it direct from MotoFab. Hardware looks ok, I was hoping for something corrosion resistant. The hardware is 8.8 and regular black steel.
    The spacer is 1.25" thick but it says it lifts it 2"?? We'll have to see.
    Install was straightforward, I ended up doing in the garage because its cold out. Some of the nuts and bolts that need to be loosened are tough to get off. My truck has 9500 miles and its never been driven in the rain/snow and it was still tough. I put the truck back on the ground about 2am this morning, I didnt get to drive it yet just waiting for it all to settle after a drive. Ill take measurements before and after and report back.
    Stock
    Front - 36.5
    Rear - 39.25
    After lift
    Front - will edit after drive
    Rear - will edit after drive
    Boerseun likes this.
  4. Dec 14, 2018 at 8:07 AM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    really interested to see how this looks, ive been toying with the idea mysef
  5. Dec 14, 2018 at 8:12 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Are you getting the front alignment checked after the spacer install?
  6. Dec 14, 2018 at 8:30 AM
    NY98M3
    Cant go wrong for the money. My truck will never see offroad since there is not much here on Long Island.
    yes, none of the adjusters had to be moved but still doing it as a precaution
    Boerseun[QUOTED] likes this.
  7. Dec 15, 2018 at 6:32 AM
    NY98M3
    Reporting back after a drive.
    Truck looks like it should of came this way from the factory. No difference in ride.
    Height for the front is 38.5 for the front. So exactly 2" rise using a 1.25" spacer. I was a bit skeptical but it works!
  8. Apr 4, 2019 at 3:00 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    How are you liking the lift after a few months?
    How was the install?
    Did you have to use spring compressors or could you turn the shock via bottom eye mount?
    Thank you
