2.5 gen tpms compatible with 2 gen?
Discussion in 'Wheels & Tires' started by idiggplants, Jun 20, 2022.
  1. Jun 20, 2022 at 10:14 AM
    idiggplants
    idiggplants [OP] New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    title says it all. i got some 2.5 gen(2016) wheels on my 2013. a tire tech told me that the tpms on the newer wheels wouldnt work with my truck. bit sick of looking at the tire pressure warning light so i figure id find out for myself. if not, any idea on where to get a set of 2nd gen ones cheap? are there generic options? are they wheel or vehicle specific? ive never dealt with them before.
    this is the style of wheel:75157-toyota-tundra-rims-for-sale-aly75157u45-oem-wheel-426110c170__64633.1643828207.jpg
  2. Jun 20, 2022 at 10:38 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Up to and including 2017 sensors work with 2nd gens. 2018 and up are different sensors.
    I run those same TRD wheels from a ‘17 on mine, with the ‘17 sensors.
  3. Jun 20, 2022 at 10:57 AM
    idiggplants
    PA
    2013 DC 4wd
    ok, to be honest, i just guessed with the 2016 number. they could be newer than that. if its from a 2018, or 2019, do they not work? am i looking at an expensive set of tpms, or is it even possible?
  4. Jun 20, 2022 at 11:50 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Are there tires mounted on the new(er) wheels at the moment?
    If no, you can look for a TRW logo (older style) or Pacific (newer style) and read the ID code printed on them.
    If yes, you will need a (tire) shop with a TPMS ID scanner to read the ID from outside the tire, and that can be used to determine if they are TRW or Pacific.
    Worst case senario, you’d need 4 new TRW sensors, and have them installed.
    https://www.toyotatpms.com/
  5. Jun 20, 2022 at 12:19 PM
    PermaFrostTRD
    Northern NY
    There is also a difference between alloy wheel sensors and steelie's.
    landphil likes this.
  6. Jun 20, 2022 at 12:50 PM
    idiggplants
    PA
    2013 DC 4wd
    thanks. i think its safe to assume they are the new ones and icompatible, as the tire shop definitely attempted to scan for them.
    $40 per tire? ouch. guess i should have looked into this more prior to buying new wheels. thoughts on buying used? this ebay auction seems about right?
    https://www.ebay.com/itm/275311097719
  7. Jun 20, 2022 at 1:05 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    In theory those should work for you. Probably wouldn’t be my choice, since the age / real battery condition is unknown, and it costs to have them installed.
    If your previous wheels were alloys, you could also swap those sensors over to the new wheels. But again, questionable life left in those if they are original from your ‘13.
    That said, my winter set of wheels have what I’m pretty certain are three original sensors from ‘08, and still going. Had to replace one back in ‘16 when I bought the truck.
  8. Jun 20, 2022 at 3:10 PM
    Get sensors from @Roman. He can ensure the correct part numbers as well.
    Roman likes this.
  9. Jun 20, 2022 at 3:15 PM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    Get these Autel TPMS sensors and either clone your existing or program into your truck. I used an Autel TS508 to program my sensors. The MX sensor are compatible since they are dual frequency. (315mhz & 433mhz) Once you are done with the TS508 you can sell it. There are some also used on eBay cheaper.
    https://www.amazon.com/Autel-MX-Sensor-Programmable-Pressure-Monitoring/dp/B075SBSV5Y?th=1
  10. Jun 21, 2022 at 9:19 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
