2.5 Gen Bumpers!
Discussion in '2.5 Gen Tundras (2014-2021)' started by FlashCulprit, Dec 14, 2016.
  1. Feb 5, 2022 at 2:15 AM
    #691
    t.friddy
    t.friddy New Member
    Charlotte, NC
    2019 Tundra SR5 DC
    It looks clean though. You can always get one with a removable control pack and mount in engine bay. Put mine high on passenger fender area.
  2. Feb 5, 2022 at 2:18 AM
    #692
    t.friddy
    t.friddy New Member
    Charlotte, NC
    2019 Tundra SR5 DC
    300BLK likes this.
  3. Feb 5, 2022 at 2:28 AM
    #693
    t.friddy
    t.friddy New Member
    Charlotte, NC
    2019 Tundra SR5 DC
    Wish I have found this a while back so I stopped ripping bumper skin off mine regularly. It says the hitch is only class iii though. Does anyone make a high clearance off-road bumper that keeps the class iv?
  4. Feb 5, 2022 at 10:21 AM
    #694
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    tight fitment like that is not necessarily a good thing. The bumper will need some room to move as the truck flexes or you will start to pop the panel below your headlights or possibly crack your grill. I hang my bumper as low as possible just for this.
    You can see here how the passenger side gap is gone going over an obstacle, if there was no gap the bumper would push up into that panel and either pop it or crack it :thumbsup:
  5. Feb 5, 2022 at 10:35 AM
    #695
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Can confirm, a gap is absolutely necessary. I made the mistake on my Tacoma of the aftermarket bumper not having a gap and I blew those little trim pieces underneath the headlights right off while off-roading.
  6. Feb 5, 2022 at 10:47 AM
    #696
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sexy af.
  7. Feb 5, 2022 at 12:29 PM
    #697
    t.friddy
    t.friddy New Member
    Charlotte, NC
    2019 Tundra SR5 DC
    Yikes - didn’t know there’d be that much movement
  8. Feb 7, 2022 at 6:46 AM
    #698
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    I've got an ADD Pro front bumper on the way. 14-16 weeks :duh:
    excelw and Blue Thunder like this.
  9. Feb 7, 2022 at 3:05 PM
    #699
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    I ordered this bumper recently. Here's my progress. Its an excellent kit. Good quality steel, well thought out and engineered. One thing to mention though is that you must relocate your power steering cooler. This is not mentioned on the website. Its easy and just requires replacing a hose with a 20" piece of 3/8 line and then mounting it higher on the chassis using a provided relocation kit.
    Some minor odds and ends to go then paint.
    There is room for adjustment and the instructions call for a 1/4-3/8" gap. I went a little above that to account for flex from our spaghetti frames.
  10. Feb 7, 2022 at 4:30 PM
    #700
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I've been eyeing that coastal kit. Does it seem pretty sturdy around where the winch mounts? Does it come with eyelets for shackles? I haven't seen any pics with them.
    For those that are looking for a rear bumper too, Coastal said they're going to be coming out with a matching rear bumper kit later this year.
  11. Feb 7, 2022 at 10:18 PM
    #701
    300BLK
    300BLK New Member
    Yes, the design is favorable for a pretty stout winch plate that's boxed in and has gussets under the plate as well. Its then welded to the two side plates that are also the recovery points. I seam welded the sides and stitch welded the rest but you could seam weld the entire plate if you wanted to mitigate against any chance of flex.
    The side plates it attaches to are extremely stout in that they're 3 plates of 3/16 steel sandwiched together that are then plug and seam welded with a center hole as your recovery point. This is in line with the frame rails and bolts right to it so its very strong.
  12. Feb 7, 2022 at 10:44 PM
    #702
    helidave
    flagstaff
    2015 DC 4x4
    Thanks! Did you get it pretty quick after ordering?
  13. Feb 8, 2022 at 8:01 AM
    #703
    300BLK
    300BLK New Member
    It wasn’t terrible given the times, but longer than advertised. Ordered Dec 31st, shipped out January 18th, got it on the 20th.
    helidave[QUOTED] likes this.
  14. Feb 12, 2022 at 2:11 PM
    #704
    Scutterborn
    Scutterborn New Member
    Ben
    '14 Tundra Platinum
    RC Vertex 7" Camburg 1.5” UCA’s Icon RTX rear leafs on option 2 Firestone bags with daystar cradles 20” Fuel Kranks w/ 5.75 bs. 295 Toyo AT3
    Quick question. Does anybody know if the Westin outlaw rear bumper is compatible with the factory hitch and if so, how it looks? I undertand the premise behing relocating it behind the license plate
    equin, 406Michael and 831Tun like this.
  15. Feb 12, 2022 at 4:04 PM
    #705
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    No it's not compatible with the factory hitch, you have to buy the Westin hitch. I had that bumper, this is what remains.rear bumper.jpg
    WXman likes this.
  16. Feb 13, 2022 at 11:07 AM
    #706
    Scutterborn
    Ben
    '14 Tundra Platinum
    Awesome! Thanks for the response. I've got someone local selling a brand new front and rear set for $1200 and was hoping this would work.
  17. Feb 14, 2022 at 7:10 AM
    #707
    showtime240
    showtime240 New Member
    Thanks for the info, and it looks bad ass!
  18. Feb 14, 2022 at 8:22 AM
    #708
    Radarninja
    Radarninja New Member
    Ryan
    Ca
    Is that the “grill tubing” option?
    Looks really good.
  19. Feb 14, 2022 at 8:36 AM
    #709
    300BLK
    300BLK New Member
    Yep! Its the perfect height.
    I had posted these pics elsewhere but for those interested, this is how the finished bumper came out. Extremely happy with it.
    SmokinGunner, equin, GAknight and 8 others like this.
  20. Feb 14, 2022 at 9:44 AM
    #710
    helidave
    flagstaff
    2015 DC 4x4
    Will the factory fog lights bolt up in those square holes or do you need aftermarket ones?
    can you get a shot of underneath where the skidplate attaches to the bumper?
  21. Feb 20, 2022 at 8:46 AM
    #711
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    @300BLK I just ordered up one of these kits. Thanks for your description and pics, it looks like a nice option for those of us who need a project.
  22. Feb 20, 2022 at 9:48 AM
    #712
    BlueLighting
    BlueLighting New Member
    Rick
    California
    2015 Platinum
    4.5 RC Lift, fuel wheels, RC front bumper & front struts
  23. Feb 22, 2022 at 5:27 AM
    #713
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    Those with the HD Ranch Hand style bumpers.... Is there any effect on your headlight output? It seems that the large center uprights would block some of the beam towards the center. Especially on the Steelcraft Elevation one.
  24. Feb 22, 2022 at 10:28 AM
    #714
    Gamer68
    Gamer68 New Member
    2016 Toyota Tundra limited
    2.5 front lift//Hooke Road Front Bumper w/lightbar//20" Black spoke Fuel Wheels//Weather Tech Floor mats//Black Waterproof seat covers//Hard tri-fold tonneau cover//
    Looks good my brother. Assuming you did install, how did you wire the light bar in the middle?
  25. Feb 22, 2022 at 11:33 AM
    #715
    BlueLighting
    Rick
    California
    2015 Platinum
    Wired the light bar with auxbeam switch panel
  26. Feb 22, 2022 at 11:38 AM
    #716
    Gamer68
    Gamer68 New Member
    Nice. Can you send me a pic of your switch and where its mounted?
  27. Feb 22, 2022 at 11:41 AM
    #717
    BlueLighting
    Rick
    California
    2015 Platinum
    Sure I’ll get tomorrow for you
  28. Feb 22, 2022 at 12:01 PM
    #718
    Gamer68
    Gamer68 New Member
    Thanks Blue
  29. Feb 23, 2022 at 9:37 AM
    #719
    BlueLighting
    Rick
    California
    2015 Platinum
    CBF636E1-2386-4FBE-8765-B287F11240C1.jpg F23E7DB6-29D1-4A0A-BFB3-6F04FEA73FD0.jpg 13AB9424-CB30-4CE2-88CB-4D0501708778.jpg FDF070F3-C600-4D8F-8CF1-D2BD4FA1EF99.jpg 2B361427-BBC7-438A-B29D-E3709297F5EF.jpg CBF636E1-2386-4FBE-8765-B287F11240C1.jpg Gamer68 the pic’s you asked for
  30. Feb 23, 2022 at 10:10 AM
    #720
    Blue Thunder
    Washington
    Holy crap that is sexy
