2.5 Gen Bumpers!
Discussion in '2.5 Gen Tundras (2014-2021)' started by FlashCulprit, Dec 14, 2016.
  1. Oct 24, 2021 at 8:44 AM
    #631
    dankberries
    dankberries New Member
    2020 Tundra
    Im sure it will fit with the TRD skid, my truck had the off-road package skid and it was totally fine. I did purchase the complete package that did include the ironman skids.
    I still haven't received the lights, they are ironman branded using osram lights.
  2. Oct 27, 2021 at 9:58 AM
    #632
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    Looking for a winch/30 inch light bar bumper. Not interested in bulky style but rather somewhat slim. Pro if it works with the RCI skid plate and $1000 or less. There’s a lot of companies and pics to go through but thought I’d ask. This is for a ‘16
  3. Oct 29, 2021 at 11:08 AM
    #633
    dankberries
    2020 Tundra
    The lights included in the ironman bumper kit came in the mail a couple days ago.
    For the front they have included a 300w 32' dual row lightbar, 4 40w 3in. Cubed lights (you get to pick spot/beam/clear/amber) and two smaller 10w Amber working LEDs.
    The back bumper gets two 40w & two 20w cubed lights.
    The front bumper, if you choose to not use the smaller 10w Amber working lights, they have a block out filler piece that can be used in its place. It came pre installed on the bumper and can be seen on my first posts.
    There is another block off piece in the kit as well, it's either for the front or back but I haven't figured that out yet, I'm assuming if you chose no lights at all.
    Also in the front as seen is an optional light bar protection piece. Aesthetically I prefer the look without the protection piece, however I like the functionality more.
    The quality seems good. The housing are thick , they feel heavy for there size. Everything appears sealed well, the electric connections are good quality as well.
    So far I only have the lightbar and Amber cubes wired in.
    The lightbar was definitely communicating with aliens last night. Probably burned a hole in the back of that deers head that ran out in front of me last night. That bar is intense.
  4. Nov 12, 2021 at 4:19 PM
    #634
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How was the wiring? Did you use the connectors they came with? Did you use the factory fog harness?
  5. Nov 13, 2021 at 1:17 PM
    #635
    dankberries
    2020 Tundra
    Good question and here is the story.
    Unfortunately the kit did not include any wiring harnesses. Ironman did advertise the kit included all necessary hardware for a complete install.
    I reached out to ironman and it was not there intention to include wiring harnesses in the kit and it was a mistake in the description. Ironman offered to reimburse me for whatever purchase I needed to make to complete the install.
    I went to my local parts store and purchased a few complete wiring harness kits(switch,relay,fuse,wiring) intended for lights. I emailed ironman my receipts and I was credited to my account immediately.
    I used the factory OEM fog wiring for the two Amber cubes. The other 4 lights are wired with the aftermarket harness. The lightbar is on its own harness rated for that wattage.
    The rear bumper lights I also used a wiring harness but I tapped the switch to the cab lighting and took power from the trailer plug.
    All relatively easy and thanks to the forum I completed the rear bumper setup without running wires all the way to the battery.
  6. Nov 13, 2021 at 2:47 PM
    #636
    MadMaxCanon
    Thanks for the details, I suspected that would be the situation. Did the lights only have exposed wires without a connection or they didn't come with wires period?
  7. Nov 19, 2021 at 9:41 AM
    #637
    dankberries
    2020 Tundra
    The lights did include a sealed connection with the mating pig tail.
  8. Nov 19, 2021 at 10:00 AM
    #638
    MadMaxCanon
    I am pretty close to pulling the trigger on this bumper kit and replacing the amber work lights with some SAE rigid fog lights for the road.
    tonynw318 likes this.
  9. Nov 20, 2021 at 4:53 AM
    #639
    Akaklutz
    Akaklutz New Member
    Alan
    2021 Tundra
    New stock
    Very nice ride...
    What's your tire and wheel specs(
    I just got my Tundra three days s ago and am window shopping for new wheels. Your truck looks amazing..
  10. Dec 3, 2021 at 4:19 PM
    #640
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    I finally got my Rough Country DIY bumper done. If anyone is interested the job wasn’t too bad even knowing I’ve never welded before. I bought a Hobart 140, practiced a lot, watched gobs of YouTube videos on the topic and talked with a pretty cool older guy for some welding tips. All told, it took me a few long days of welding and grinding. My local Line-X dealer sprayed it and I put some cheap LED fog lights in it.
    Thanks for looking.
  11. Dec 3, 2021 at 4:20 PM
    #641
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Looks great, nice job!
  12. Dec 3, 2021 at 4:47 PM
    #642
    JohnH
    JohnH From PA
    Pennsylvania
    Thanks!
  13. Dec 3, 2021 at 9:23 PM
    #643
    cowboyjack
    cowboyjack New Member
    Just got the first Tundra High Clearance Phantom Bumper from WarFab Armor. Couldn’t be happier. Super heavy duty, yet lightweight. HUGE increase on clearance and retains the hitch under the license plate.
  14. Dec 3, 2021 at 9:42 PM
    #644
    MadMaxCanon
    Wow awesome, I was wondering when someone would make this style for us. How was the cutting and installation?
  15. Dec 4, 2021 at 12:22 AM
    #645
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Can anyone running an SS Built bumper chime in on front recovery point options? It looks like there is some cutting involved and in the pics I’ve seen I don’t see any front tow hooks.
  16. Dec 4, 2021 at 12:45 AM
    #646
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    cowboyjack likes this.
  17. Dec 4, 2021 at 6:37 AM
    #647
    cowboyjack
    That was part of the deal. WarFab needed a Tundra in their shop for a couple of days to fab up the prototype, so WarFab did the cutting and installation.
    Both the cutting and install were very straight forward, IMHO.
    BTW, the guys at the shop could not have been nicer. Real off road Toyota enthusiasts.
  18. Dec 4, 2021 at 6:46 AM
    #648
    MadMaxCanon
    I actually contacted them late last night via email and someone actually answered me close to midnight on a Friday. I gotta say I like this shop already. They said they are working on instructions for the complete installation currently. I'm really digging this bumper. Only thing I don't like is that 300 bucks shipping. That alone will probably make me wait for a sale or something.
  19. Dec 10, 2021 at 6:59 AM
    #649
    Kentuckytundra
    Kentuckytundra I love spam calls, we talk for hours
    I know this was posted a long time ago but hopefully you're still active here. Any chance you could post a side shot of the bumper, and or possibly measure how far it sticks out from the grill? I have around 7in clearance in my garage and really want this bumper.
    Also, does it work with the factory trd pro skid plate?
  20. Dec 10, 2021 at 10:41 AM
    #650
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    Here ya go. Same bumper. Don't have anything to measure it with currently. I don't have the pro skidplate, but I don't see why it wouldn't work.
  21. Dec 10, 2021 at 10:50 AM
    #651
    Kentuckytundra
    Thank you! Damn that looks like it would fit but it's so close! Does it use the factory tow hook mount location?
    Degausser[QUOTED] likes this.
  22. Dec 10, 2021 at 10:56 AM
    #652
    Degausser
    Kevin
    GA
    2024 LR SR5
    Yes, that's where the support brackets attach
  23. Dec 10, 2021 at 11:01 AM
    #653
    Kentuckytundra
    Gotchya, if you don't mind if you remember later can you hold a tape measure up from the front of the grill to the bull bar to see how far it sticks out? If not no worries. I appreciate your info.
  24. Dec 10, 2021 at 11:28 AM
    #654
    Degausser
    Kevin
    GA
    2024 LR SR5
    Jackstraw, Philogynist and cowboyjack like this.
  25. Dec 10, 2021 at 11:34 AM
    #655
    Kentuckytundra
    That is EXACTLY what I needed. Wish I could buy you a beer. Thank you kindly sir!
  26. Dec 10, 2021 at 11:35 AM
    #656
    Kentuckytundra
    That will fit in the garage, now I just need to order it and wait 4 months lol
    How was the install?
    Degausser likes this.
  27. Dec 10, 2021 at 11:40 AM
    #657
    Degausser
    Kevin
    GA
    2024 LR SR5
    Install wasn't too bad. It's heavy, but my wife was able to help just enough to get it in place and get a couple nuts on. I followed the install video on their site and had no issues.
  28. Dec 10, 2021 at 11:49 AM
    #658
    Blue Thunder
    Washington
    This thread is bumper porn…
  29. Dec 12, 2021 at 2:09 PM
    #659
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    I searched the forums and couldn’t find anyone else with this bumper. It’s the Armordillo RP.
    716EBB00-F702-415A-898B-1237E452B7BE.jpg 1B4C525D-D4E2-4D19-88E9-25E57F97C3B0.jpg
  30. Dec 13, 2021 at 11:24 AM
    #660
    busy13b
    busy13b New Member
    2014 Tundra Double Cab Limited TRD Offroad
    That looks good - very "Raptor-esque." Does it come with any inserts or light bezels for the open areas on either side?
