1UPPER’s 17 CM SC Platinum Custom Build
Discussion in '2.5 Gen Builds (2014-2021)' started by 1UPPER, Oct 20, 2016.
  1. Mar 26, 2019 at 3:05 PM
    #1141
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    Me too!
    ryanwgregg and TokerJoker like this.
  2. Mar 26, 2019 at 4:13 PM
    #1142
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    2nd that motion!
  3. Mar 27, 2019 at 6:34 PM
    #1143
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
  4. Mar 27, 2019 at 6:58 PM
    #1144
    1UPPER
    TEXAS
    Flux capacitor!
    Update on the Magnuson SC and the Dyno. They did a couple light pulls today on the Dyno and it’s not getting enough fuel. I know Magnuson said flex fuel tundras do not need to have different injectors or a fuel pump but the motor needs more fuel to run at the proper air fuel ratio. They said they don’t know how Magnuson can run a SC with the current injectors and fuel pump. I would rather have it done right and be happy then rush to get my tundra back. I guess my tundra will be at the shop a little longer. I’m sure it will be worth the wait.
  5. Mar 28, 2019 at 8:16 AM
    #1145
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    That claim has stuck with me ever since I read it. It just didn't seem right, but I figured there were other factors that I wasn't seeing. Glad to know it's getting answered correctly though. REALLY interested to see what the final tally is going to be to do this upgrade. Thanks for keeping us updated!
  6. Mar 28, 2019 at 8:31 AM
    #1146
    1UPPER
    TEXAS
    Flux capacitor!
    I’m not a big fan of the flex fuel vehicles to begin with but the Gulf State region is mostly all flex fuel tundras.
    I did talk to Whipple about the Tundra SC which is in development right now. It won’t be released for six months or more. No idea what they will do for their setup yet. They did say it’s a bigger performance SC over the Magnuson. I like how Whipple allows you to order different colors or have the SC polished at an upcharge cost though.
  7. Mar 28, 2019 at 8:32 AM
    #1147
    Sas
    OKC, OK
    Wonder if peripheral drivetrain components start having to get upgraded as well w/that one.
    Toyotoholic and Prostar 190 like this.
  8. Mar 28, 2019 at 9:24 AM
    #1148
    1UPPER
    TEXAS
    Flux capacitor!
    Good question. I’m not sure though. They don’t have a lot of info on it yet since it’s still being tested.
    Prostar 190 likes this.
  9. Mar 28, 2019 at 6:43 PM
    #1149
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Can't wait!! Gonna be amazing..
    1UPPER[OP] likes this.
  10. Mar 30, 2019 at 6:54 AM
    #1150
    1UPPER
    TEXAS
    Flux capacitor!
    I spoke with Pro Speed the other day about getting my Magnuson SC tuned properly. The stock OEM injectors have to small of a nozzle and the current fuel to air ratio is to lean. I was told there are only two after market injectors on the market for the tundra and neither are the optimal setup. Pro Speed is working with an injector company to get the proper injectors with the proper fittings to fit my tundra. My fuel tank will be getting a high flow fuel pump installed that will be capable of keeping up with the proper air fuel ratios needed. I have the option for the methanol kit as well. Not sure if I want or need to go that route just yet. The methanol injection kit is like having extra insurance to maintain a cooler running temp. The tank for the methanol would go in my bed if I decided to go that route. I can’t say I’ve heard of anyone doing that setup with a SC. I’m very excited to see what my truck does on the Dyno! The waiting game is always hard to do!
    :burnrubber:
  11. Mar 30, 2019 at 7:25 AM
    #1151
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Good luck with the R&D!:thumbsup:
    1UPPER[QUOTED][OP] likes this.
  12. Mar 30, 2019 at 3:43 PM
    #1152
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I researched this before buying the Magnuson. The OEM TRD SC was developed with great consideration of the peripheral components. Thus, it claimed a modest 505hp, and basically nothing downstream was going to break. Magnuson bumped bit to 550hp and has maintained success in not blowing up the DT. As far as failures... It seems that when people changed the pulley to stretch the hp up to 600, the most common Supercharged failure point is the tranny. NO THANKS! So, after a long consideration, I was confident going with something tried and true (Magnuson) and not try to "get anything more out of it" so as to not risk the peripherals.
    2nd most common failure was the OEM shear pin in the rear diff. Go Auburn or ARB for that fix but again only if going for 600+hp. Stay under 575hp and the rest of the DT will be pushed, but not broken.... I hope ...:fingerscrossed:
    Bo-Hunter, Newm, TokerJoker and 2 others like this.
  13. Mar 30, 2019 at 4:37 PM
    #1153
    1UPPER
    TEXAS
    Flux capacitor!
    Thanks for the info! My intent is not to push my hp numbers but to make sure the engine isn’t running to lean like it currently is. I already upgraded my gears to 4.88 and the Auburn LSD. I should be around 600 hp but I’ll know for sure soon.
  14. Mar 30, 2019 at 6:45 PM
    #1154
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Nice.
    I'm looking forward to your results! ...and I hear you on just wanting to know your engine is getting the right mix of juice and oxygen.
  15. Apr 5, 2019 at 2:26 AM
    #1155
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    What leds did you go with in the shell?
  16. Apr 5, 2019 at 4:16 AM
    #1156
    1UPPER
    TEXAS
    Flux capacitor!
    Just a basic led tape from Amazon.
    xtyfighterx[QUOTED] likes this.
  17. Apr 5, 2019 at 4:31 AM
    #1157
    xtyfighterx
    Ty
    North Idaho
    Thanks
  18. Apr 5, 2019 at 4:48 AM
    #1158
    1UPPER
    TEXAS
    Flux capacitor!
    You’re welcome. I like your new camper shell.
  19. Apr 5, 2019 at 4:58 AM
    #1159
    xtyfighterx
    Ty
    North Idaho
    Thanks man I’m stoked on it...$500 find
    Cfincke and Prostar 190 like this.
  20. Apr 5, 2019 at 4:59 AM
    #1160
    Wow great find!
  21. Apr 5, 2019 at 5:01 AM
    #1161
    xtyfighterx
    Ty
    North Idaho
    Gonna build up a prinsu style rack for it and rienforce it for my RTT
  22. Apr 5, 2019 at 6:03 AM
    #1162
    1UPPER
    TEXAS
    Flux capacitor!
    Dang! That’s a smoking deal!
  23. Apr 5, 2019 at 6:27 AM
    #1163
    xtyfighterx
    Ty
    North Idaho
    Only took a year to find it lol
  24. Apr 10, 2019 at 3:35 PM
    #1164
    1UPPER
    TEXAS
    Flux capacitor!
    My Tundra is finally done with the new injectors, bigger fuel pump and tuning!!! I’ll find out tomorrow what kind of numbers it did on the Dyno. They said it’s impressive but the waiting is the hardest part.
    I can’t wait!! :yes:
  25. Apr 10, 2019 at 4:49 PM
    #1165
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Damn I had an alert for this thread and read through the last few posts, was hoping today was the day. I can't wait, I'd imagine you're really really excited
  26. Apr 10, 2019 at 4:53 PM
    #1166
    1UPPER
    TEXAS
    Flux capacitor!
    Absolutely, I’m very excited to have my tundra back!
    I’m going to do a full stereo build soon. Plan to take the interior all out and do a full audio replacement. It’s going to be something!
  27. Apr 10, 2019 at 4:55 PM
    #1167
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  28. Apr 10, 2019 at 4:59 PM
    #1168
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    What size fuel pump and injectors are they installing?
  29. Apr 10, 2019 at 5:04 PM
    #1169
    1UPPER
    TEXAS
    Flux capacitor!
    I honestly don’t know. Pro Speed had to order bigger injectors with a custom fitting and a larger fuel pump that had to have a bracket made for it is all I know. This is what they do best so I let them have at it. I believe this is the first flex fuel tundra to have larger injectors and fuel pump. At least that I’ve know of. I’ll ask when I go pick up my truck what they used.
  30. Apr 10, 2019 at 5:18 PM
    #1170
    Sas
    OKC, OK
    Should be on the parts list invoice they give to you when it's all said and done. I wouldn't settle for generic entries on this one since it's not a "plug and play" sort of setup. When something goes wrong you'll want to know exactly what the parts are and who made them so they can be replaced and/or swapped out to another manufacturer (if possible).
