1st Gen Tundra TRD Big Brake Calipers
Discussion in '1st Gen Tundra Parts Marketplace (2000-2006)' started by SCRunner12, Oct 29, 2016.
Thread Status:
Not open for further replies.
  1. Oct 29, 2016 at 10:08 PM
    SCRunner12
    SCRunner12 [OP] New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    I have a set of 1st gen (2000-2006) TRD Big Brake Kit calipers and rotors. Bought them for my 06, but I don't have the budget to complete the kit right now. The calipers are in good shape, but be smart to rebuild. I have a set of rotors but the PO decided to use a hammer to remove them and dented them. Basically you'll need new rotors, pads, mounting bolts and brake lines (if you want to upgrade). Also can only be ran with 17" or greater wheels.
    SOSPerformance.com has the replacement parts for about $800. Yes it's a lot but this kit is beefy and will make a significant difference. Keep in mind this is over $2000 new, so you're still getting a deal. I can remove the rotor from the mounting plate to reduce weight if needed (sos sells the rotors that attach to the mounting plate).
    Looking to get $250 obo plus shipping.
    No longer available
    dcsleeper408 likes this.
  2. Nov 8, 2016 at 2:58 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Bump, $200.
  3. Nov 8, 2016 at 3:36 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Unfortunatly those rotors are now scrap. Next time put a 2x4 on them if hammering is your only option
  4. Nov 8, 2016 at 10:48 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Unfortunately I got them from the guy like that, but had a friend pick it up and he didn't see the marks either. Probably a good idea to replace them anyways even if the weren't dented.
  5. Mar 26, 2017 at 3:04 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    They are only dented, not warped. You can take a smooth flat file and file the bumps off and then a flat stone to smooth it down. Those dents are no different than those cooling slots. They will be fine.
    040Tundra likes this.
  6. Apr 13, 2017 at 3:13 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Did u ever sell these
  7. Apr 13, 2017 at 8:14 AM
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Nope sitting in my garage still...
  8. Jul 14, 2017 at 8:20 AM
    egspecr
    egspecr New Member
    How much would the total be, shipping down to Pasadena, CA 91103?
  9. Jul 14, 2017 at 1:04 PM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    I got a third gen so I'm just SOL.
  10. Jul 19, 2017 at 3:40 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Sorry just got this, I'll get a quote tomorrow, but probably $25.
  11. Aug 2, 2017 at 6:51 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Would these require 20" wheels?
  12. Aug 22, 2017 at 11:45 PM
    Djangothehound
    Djangothehound New Member
    Do you know if these calipers are larger than the "upgraded" calipers Toyota switched to in 04'? I believe they're stamped 13WL. I thought the big brake kits were 6 piston calipers.. hmm
  13. Nov 16, 2017 at 9:46 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Sorry disappearing everyone, got busy with life. Ended up deciding to keep these, but thanks for the interest.
Thread Status:
