1st Gen Tundra Tool Kit
Discussion in '1st Gen Tundras (2000-2006)' started by onesojourner, Jan 30, 2021.
  1. Feb 1, 2021 at 6:34 PM
    Sunnier
    Sunny
    San Diego, CA
    ’been a while since something on here caused me to actually laugh out loud. :rofl:
    Darkness and FrenchToasty like this.
  2. Feb 1, 2021 at 6:37 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Lol
    Sunnier, Darkness, N84434 and 4 others like this.
  3. Feb 1, 2021 at 6:39 PM
    Sunnier
    Sunny
    San Diego, CA
    I’m pretty sure the axle nut is 36mm-?
  4. Feb 1, 2021 at 11:15 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    5/8 spark plug socket and electrical tape
    HBTundra and onesojourner[OP] like this.
  5. Feb 2, 2021 at 4:58 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Best packaging ever..
  6. Feb 2, 2021 at 5:19 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Spool of 16 or 18 gauge steel wire and some cutting pliers or leatherman to cut it. Some call it mechanics or agriculture wire. Along with duct tape can come in handy doing some HD repairs.
  7. Feb 2, 2021 at 9:36 AM
    onesojourner
    onesojourner [OP] Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    It's called bailing wire around here.
    Keep the ideas coming guys. I plan to put this in a cohesive list and then I am going to make some sort of tool roll.
    bmc02[QUOTED] likes this.
  8. Jun 14, 2021 at 12:12 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I am gathering tools together. This is a little used area of the basement. At some point in the near future my wife will tell me to get the tools off the basement floor. You guys have until then to add to this hodge podge.
  9. Jun 14, 2021 at 9:01 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    This plus their 20% coupon - $111
  10. Jun 15, 2021 at 2:37 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I think the brake bleeders are 8mm. Not roadside repair, god forbid
  11. Jun 15, 2021 at 2:48 AM
    w666
    Maryland
    35mm
    Sunnier[QUOTED] likes this.
  12. Jun 15, 2021 at 4:08 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Bluetooth OBD scanner dongle.
  13. Jun 15, 2021 at 6:34 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    In addition the sockets and combo wrench sizes used with Asian vehicles (8mm, 10mm, 12mm, 14mm, 17mm), I would have a good 4-way lug wrench, pliers, screwdriver set (magnetic preferred in case you drop a bolt or nut), tire plug kit, & small portable compressor. Also make sure the spare tire holds air.
    The other things that might leave you walking are failed ignition coil and inoperable fuel pump. While you won’t keep a spare fuel pump with you at all times, not a bad idea to keep a spare Denso fuel pump relay in the glove box. I also keep a spare Denso ignition coil in the tool bag as well. Not expensive, especially if you find a good used one at the junkyard.
    Always keep the cell phone charged and be ready.
    des2mtn likes this.
  14. Jun 15, 2021 at 6:51 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Sunnier likes this.
  15. Jun 15, 2021 at 6:57 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
  16. Jun 15, 2021 at 2:06 PM
    Professional Hand Model
    Hand Protectors
  17. Jun 15, 2021 at 4:02 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    201375489_10159181853235275_746479621564_71b90f6e02dda6c5a804be3cabb7cbbc2ce0cf87.jpg
    if i stole that pic from here, im sorry.
    bmf4069 likes this.
  18. Jun 15, 2021 at 4:44 PM
    Outbound
    Aaron
    Northern Alberta
    You need a B.F.H aka Big Fucking Hammer.
  19. Jun 15, 2021 at 4:57 PM
    #49
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    spare phone cable….is that a tool ?
    Let AAA worry about tools….probably jinxed myself now :facepalm:
  20. Jun 16, 2021 at 5:21 AM
    #50
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I probably don't need 4 of these. The drawbacks of "I might need this, throw it in."
  21. Jun 16, 2021 at 5:48 AM
    #51
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    When shtf, i can fill a passenger footwell with tools. I have a hundredsomething piece socket and wrench kit, a bag of ‘tools’ like allen wrenches, hammer, vicegrips, scrapers, etc..
    And a seperate bag of ‘parts’ like wire, zipties, nuts&bolts, a magnetic tray, etc..
    And a bag of fluids.
    One thing thats always handy for nuts and bolts is the wheel from inside a broken ratchet so i can run em one handed in tight quarters. Usually have 2 different sizes of ‘universal’ tools.
    201795596_10159183290445275_115480996670_720603d74a0aab6a0cf6bb48431f41323cea76d4.jpg
    i found this one in an extra cheap ratchet, and i like it because if something needs to be a little tight, i can stab a screwdriver through it.
    but i havent loaded the turdra. I heard the mere sight of tools will send newer ‘yotas into a panic, throwing codes and calling the dealer.
  22. Jun 16, 2021 at 8:21 AM
    #52
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    Home Depot has a nice 3/8 tool kit for cheap. Has most sockets you would need including a ratchet extension and spark plug socket. Also has a few Alan’s and nut driver. Pretty handy. I always carry jumper cables and a tow strap too. OOO yes and lots of zip ties;)
    Darkness likes this.
  23. Jun 16, 2021 at 8:54 AM
    #53
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    This is a treasure hunt to find all the tools you guys mention in my house. I have been collecting partial tool sets for a long time.
  24. Jun 16, 2021 at 9:09 AM
    #54
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    My picks have become more useful. Im terrified of snapping connector latches, so im double careful.
    I keep a cable dog lead, the tiny poodle cable, but its like 30ft, and has come in handy several times. Just put those spring loaded hooks on the ends. It rides in my strap bag. Along with most of a roll of the cheap walmart paracord. I also carry a small roll of outdoor trashbags because this is my river.
  25. Jun 16, 2021 at 9:12 AM
    #55
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    High Five.
    Darkness and Sirfive[QUOTED] like this.
  26. Jun 16, 2021 at 11:59 AM
    #56
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its that 10mm
  27. Jun 16, 2021 at 1:59 PM
    #57
    blackdemon_tt
    Lol, yes a stack of them... I'd give them 10 minutes after the package is open for them to disappear
    Darkness[QUOTED] likes this.
  28. Jun 16, 2021 at 3:28 PM
    #58
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    I have like 3 flares and a first aid kit from when I bought my truck :bananadead:
    In my own time I put 3 smaller sized husky toolkits from Home Depot underneath the back seats.
    My tire iron is too big to insert into my rims so I should really get a skinnier one.
  29. Mar 12, 2022 at 2:14 PM
    #59
    Beast_from_the_east
    Beast_from_the_east New Member
    Steel pipe... aka cheater Bar
