1st Gen Tundra Tire Setup
Discussion in '1st Gen Tundras (2000-2006)' started by YOUNGBUCK34, Aug 16, 2020.
  1. Nov 23, 2020 at 12:18 PM
    YOUNGBUCK34
    YOUNGBUCK34 [OP] New Member
    Rico
    2005 Double Cab 4x4 SR5 V8
    Okay I have decided I am going with stock tires 265/70's until I lift it and have more money. My plan is to get 2 inch add a leaf's with bilstein 5100's for the rear and the 6112's for the front so I can fit 33's. I'm not sure if I will need a new upper control arm though? Anybody know? Also I'm curious, does anyone know what the stock suspension is on these things. Is it bilstein's or do they only include that on the TRD package?
  2. Nov 23, 2020 at 12:26 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I am planning 6112 also. I plan to use the 1.6" notch for the double cab and I do plan to get spc upper control arms.
  3. Nov 23, 2020 at 12:33 PM
    YOUNGBUCK34
    Rico
    So I actually read on wheelersoffroad.com when you go to buy the 6112's, if you look at the description you can actually put them to 2 inches and its okay. That only works for the double cabs though. Also heard it's easier to get them pre-built sense you need a wall compressor to get the coils on the shock. I think I will just end up getting new uca's though that way it rides right.
  4. Nov 23, 2020 at 1:12 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I am hoping that the upper control arms and the 1 notch lower will improve the ride. I know that is true of the 5100s but maybe it is not true on the 6112s?
  5. Nov 23, 2020 at 2:34 PM
    etc25
    etc25 New Member
    2005 Tundra DC 4X4
    I recently got an 05 DC too. It has a Rancho leveling kit (RS9000?) with 275/70R17 KO2s. It doesn't appear to rub now but I didn't look close enough to see if anything was modded for clearance.
    I have 6112/5160 on order and plan to set at 2" lift as max recommended by Bilstein. A shop told me that I would actually get more than that but we'll see. I have no stock starting point reference since truck came with the Rancho kit. I would like to be able to squeeze 33s on there when it's time to replace tires. I'll probably buy new 17" wheels at that time too.
    I'll be tracking this Gen 1 focused tire discussion. Thanks.
  6. Nov 24, 2020 at 5:25 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Can we see what your truck looks like with that tire size? I am curious how the power loss was with those tires.
  7. Nov 25, 2020 at 4:13 AM
    Professional Hand Model
    Hand Protectors
    I see you are worried about power loss with bigger tires. You will lose power for sure. From readings, your best bet is NOT using e-rated tires and avoid the big mud/heavy tread type tire as they are weighty. Many report the big mud/heavy tread type tire as putting off vibration issues probably due to being out of round.
    I’ve been on all types mentioned above. Right now on Michelin Defender 285/75/r16 which are e-rated and weigh about 52 pounds. Stock size tires are about 45 pounds.
    abcinv likes this.
  8. Nov 25, 2020 at 5:55 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    I can't speak to the power loss as my truck had 275/70 17's installed when I bought it but the truck seems to do fine. Not having a comparison is probably best...
    PHM is right; it takes the right shop to get the vibration issues sorted. MPG's also take a big hit if that matters to you. And some say the shift points are off making the drive less enjoyable.
    All considered I think the look is spot on and it is worth it to me (but mine isn't a daily)...
  9. Nov 25, 2020 at 8:05 AM
    etc25
    etc25 New Member
    2005 Tundra DC 4X4
    Not sure on power loss as I bought truck already with this setup.
    onesojourner[QUOTED] and abcinv like this.
  10. Dec 3, 2020 at 9:02 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I am still chewing this decision around. What kind of mileage are you getting?
  11. Dec 3, 2020 at 9:24 AM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    I got a 285/75r16 with a leveling kit up front and Airbags in the rear. I believe it’s two sizes up from stock. It was done at Les Schwab. It’s pretty dang close to the UCA as well as it does run at full lock both ways. Just something to think about. The bigger the tire the more power you lose, mileage goes down a little (not too bad) and Speedometer will be off a few. I’m about 3-4 over at 65-70 mph. If you really wanna do it right, lift, bigger tire and regear. It will do wonders. I have personally regeared ATV’s for better climbing ability and more torque lower in the RPM range. IMHO, it’s really important to regear if you put a much bigger tire on than stock.
  12. Dec 3, 2020 at 10:53 AM
    abcinv
    Tommy
    NW Georgia
    I think between 14-15. A little harder to figure out since the speedometer / odometer is off.
    onesojourner[QUOTED] likes this.
  13. Dec 3, 2020 at 11:13 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I don't plan to regear with this set of tires so I need to find a compromise. 265/70/17 or 275/70/17 is pretty much what I have it down too. I would consider 255s but I am not sure what the stance will be like with the stock wheels.
  14. Dec 3, 2020 at 11:57 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Do you plan on getting an E rated tire or a lower rating? You could go with the bigger size and the lighter rating and (I think) have less loss of mileage and power.
  15. Dec 3, 2020 at 12:25 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I would like to see some data on tire weight vs tire diameter when it comes to power loss.
  16. Dec 3, 2020 at 2:17 PM
    Hand Protectors
    Not anything that will be worse than the crap mpg they get on regular tires. The hit is in City miles. Highway miles you gain mpg. City miles you lose.
    abcinv likes this.
  17. Dec 3, 2020 at 2:18 PM
    Hand Protectors
    You will lose power going to bigger heavier tires.
    abcinv likes this.
  18. Dec 3, 2020 at 3:54 PM
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    And heavier wheels. Not all wheels are created equal!
    I plan to go to 255x70x17 with TRD Pro SEMA wheels (ET4). When that happens, I'll post a pic.
  19. Dec 4, 2020 at 6:33 AM
    #49
    Motopilot
    Motopilot New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    24E2716E-8B49-4C90-83B4-5DF24E940DD4.jpg I’m running 285/75R16 mud terrains on pro comp 16x8 wheels with 4.5 backspacing...I leveled or slightly lifted my 2005 DC 4x4 with the Billie 5100 on the 4th clip position. I have no rubbing fwd or reverse in full lock.
    Next year I’m going to make a few changes. Going to get new springs with the 1.5-2” lift and put the billies back to the stock position. Ride isn’t terrible but the 3rd clip position was probably the way to go. As for the tires I’m probably going to go to an AT...probably the bf Goodrich ko2. I just can’t get used to the loud ass Mud Terrains.
  20. Dec 4, 2020 at 6:51 AM
    #50
    Hand Protectors
    My first larger tire was a ‘Mud Tire’ in 2003. The noise was awful. They rode like crap and the tire wear was atrocious. They were replace a year later with an AT. Loud and awful wear again, but not as bad. Those lasted two years.
    The more I study about tires, the more I learn they can do more damage to a vehicle than anything else by ruining suspension, bushings, shocks, etc.
    The Grampa Michelins ‘Defenders’ are the sweetest tires going. They are quiet and last a super long time. They do well in sand and snow. I avoid mud so unsure about that.
    Motopilot[QUOTED] and abcinv like this.
  21. Dec 4, 2020 at 9:49 AM
    #51
    JP21
    JP21 New Member
    05 Tundra ex cab
    2.5 fox, Rear 5100 B’s, Firestone air bags, 33 Nokian’s, air Intake & Exhaust, ARE Topper, Sony 7”,
    I have 285/75/16 on my set up. You won’t get 285’s on without a level and spacers of some sort. It has a level of 2.5 fox in the front, wheel spacers and rear 5100’s with Firestone airbags. The only time it rubs is if I’m on a hard angle ( uphill on full turn). I could easily cut it out but honestly it happens so rarely that it’s hardly worth it. I highly recommend the airbags though.... serious game changer for hauling anything
  22. Dec 5, 2020 at 4:07 PM
    #52
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Is this the official wheel/tire setup for first gens?
    onesojourner likes this.
  23. Dec 5, 2020 at 4:43 PM
    #53
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    315/75/16 Han look mud terrain
    1stgentundradriver likes this.
  24. Dec 5, 2020 at 5:28 PM
    #54
    llessur2
    llessur2 New Member
    2005 Double Cab TRD off road
    Running 285/70/17 on OEM TRD rims and leveled with very minimal rub. They rub less than the 285/75/16s I had on it previously.
  25. May 27, 2021 at 1:49 PM
    #55
    S-Man
    S-Man New Member
    2002 Tundra
    I'm installing a 3"/1" lift on my 2002, I got these 17" TRD Wheels here: https://parts.leithtoyota.com/p/69529065/PTR2035110GR.html and I'm trying to decide what size tires to get. I'm thinking 265/70/17 but I'm afraid they may be a bit short in the wheelwell. Anybody have pics of this or a similar setup?
    Costco has a pretty good deal on BFG A/T's right now.
    Edit: Do these even fit the '02 Tundra? Some websites say they do not...
  26. May 27, 2021 at 3:08 PM
    #56
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I have this same size tire on my stock rims and it definitely rubs but it looks really good to me. However I’ll probably do what you did and get a 285/70r16 next time.
  27. Jun 13, 2021 at 7:27 PM
    #57
    TurdFerguson
    TurdFerguson New Member
    Waynesboro, Virginia
    2000 TUNDRA SR5 AC 4x4 V8
    2002 TUNDRA SR5 AC 4X4 V8 TRD
    Rancho Quicklift 2.5" struts. 265/70r17. '07 FJ Cruiser wheels. 1.25" Spidertrax spacers. No rubbing. No cutting. No Trimming. I had the same suspension and spacers w/ 285/75r16. Rubbed quite a bit, and had that look like I was trying to stuff too much tire with not enough lift.
    abcinv likes this.
  28. Jun 13, 2021 at 7:33 PM
    #58
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    #TRUTH. I run 275/70/17 and I rub at full turn... I have 5100's and OEM 4Runner Snowflakes.
  29. Sep 8, 2021 at 3:49 PM
    #59
    hendybop
    hendybop New Member
    MT
    2003 Tundra SR5 V6 Manual
    Elka 2.5” coil overs and shocks Deaver leafs SPC UCAs
    Stylie setup! Gonna start looking for these wheels as well. Can anyone help with the name and/or places to shop?
  30. Jan 21, 2023 at 7:21 PM
    #60
    Caleb4.7
    Caleb4.7 New Member
    Caleb
    2003 Tundra 4.7 access cab sr5
    Leveling kit, 4 runner rims
    How about 275/55/20’s, would that rub at all on a 2 inch level?
