1st Gen truck: 265/70/17 (TERRA GRAPPLER G2 vs BFG ALL TERRAIN T/A KO2)
Discussion in 'Wheels & Tires' started by JSM, Apr 14, 2019.
  1. Apr 14, 2019 at 2:03 PM
    JSM
    JSM [OP] New Member
    Jeff (Orlando, FL)
    2003 Tundra 4wd
    Stock
    Nittos weigh 51 lbs each ($196) 65k, BFG 54 ($192) 50k.
    Money wise doesn’t matter. The BFG have a much better appearance. Mainly on road use.
    Will the 3lb difference effect the mileage that much? I wish there was a dB value listed for each.
  2. Apr 14, 2019 at 2:10 PM
    Professional Hand Model
    Hand Protectors
    Depends. Some tires can weigh more and get better mpg than a slightly lighter tire thats designed differently (tread). If you are worried about mpg, then go with a smaller sized tire.
    In your case, I’d get the tire that looks best to you and live with the mpg (good or bad). Our mpg is awful anyways.
    JSM[OP] likes this.
