1st gen transmission PID
Discussion in '1st Gen Tundras (2000-2006)' started by rock climber, Aug 3, 2020.
  1. Aug 3, 2020 at 3:49 PM
    rock climber
    rock climber [OP] New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Trying to get trans temp on an 06 and am struggling with the correct PID,
    I tried many different ones and this is the only one that returns any values, but now my temp is showing 1,637 degrees.
    21D9
    Long Name: whatever you want
    Short Name: whatever you want
    Min Value: 0
    Max Value: 300
    Scale factor: 1
    Unit type: °F
    ((((E*256)+F)*(7/100)-400)/10)
    21D9
    Min Value: 0
    Max Value: 300
    Scale factor: 1
    Unit type: °F
    ((((G*256)+H)*(7/100)-400)/10)
  2. Aug 3, 2020 at 4:01 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've tried 2 and only 1 works.
    01b4
    Min 0
    Max 100
    Scale factor 1
    Unit type F
    A*(9/5)-40 typed just like that.
    Credit goes to @lsaami
    I also tried this one and it didn't work. I think it's for the 5 speed auto.
  3. Aug 3, 2020 at 4:35 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just noticed this. The one I typed out may not work in the 06.
  4. Aug 4, 2020 at 4:56 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I have both the trans one for the 2006 but they are for torque pro app. Hope they can help?
  5. Aug 5, 2020 at 11:08 AM
    rock climber
    That worked, thank you!
  6. Aug 21, 2020 at 4:37 AM
    Professional Hand Model
    Hand Protectors
    Is this equation for the Torque Converter Sensor on Torque Pro App?
  7. Aug 21, 2020 at 5:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Which one are you asking about? There are two in my post. The one I typed out is for the pan reading and works. The one I screenshot doesn't work for me but both were for Torque Pro.
  8. Aug 21, 2020 at 9:00 AM
    rock climber
    I'm not sure if the non sealed trans has a torque converter temp sensor. I was only ever able to get pan temp, same on the 01 Sequoia. On the 06, I used the PID and can get pan and torque converter temp.
  9. Aug 21, 2020 at 10:45 AM
    Hand Protectors
    Thank you! My Torque Pro App automatically has the Pan Temp selection as an option. No need to punch in algorerythmes for Pan Temp on 2002 Tundra.
    I’m dialing in this app. Gotta figure out a way to save my custom settings as they get erased if I go out of the app or if the phone battery auto shuts down. Takes some time setting up the dash the way I like it.
  10. Aug 21, 2020 at 10:49 AM
    Hand Protectors
    See post #9. No need for me to punch in the PID. Its already an option on my App. Just select and it loads. @rock climber seems to think we don’t have a TC option.
  11. Oct 22, 2023 at 2:39 PM
    Galladanb
    Galladanb New Member
    Southeastern Tennessee
    2002 AC Sr5
    Bumping an older thread…
    is there any fresh info on this topic?
    Would these formulas work in OBD Fusion?
    My truck is a 2002 sr5 ac with the 4.7 v8…
  12. Oct 24, 2023 at 4:42 PM
    Galladanb
    2002 AC Sr5
    FYI, I tried these configurations in my 2002, and they did not work, returning a “no data” dialog.
    But, what did work was the default “AT Fluid Temp” pid…
  13. Nov 6, 2023 at 11:50 AM
    Galladanb
    2002 AC Sr5
    Curious? Is there any documentation concerning what each of the variables, such as a, b, c, d, etc are representing in the custom pid mathematical formulations?
    thx?
