1st Gen transmission issue
Discussion in '1st Gen Tundras (2000-2006)' started by Seethan, Jun 7, 2022.
  1. Jun 13, 2022 at 8:44 AM
    #61
    Seethan
    Seethan [OP] Overwhelmed noob
    Seth
    Middle TN
    2000 V6 Tundra SR5 AC 2WD
    When I got the the fluid and filter changed out, I had the engine on and was making sure it was filled to the correct level, and after checking it a couple times, I pulled it out of the tube and the bottom 5 or so inches was gone. We had a heck of a time trying to get that out of the tube. The stick has a part right below the hot section that twists about 90 degrees and it broke right where it bends.
  2. Jun 13, 2022 at 9:07 AM
    #62
    So it broke off inside the pan? Did you retrieve it?
  3. Jun 13, 2022 at 11:25 AM
    #63
    Seethan
    Seth
    Middle TN
    It got stuck in the pipe because it takes a 90 into the pan and the pan and pipe are one piece. I was running a couple wires through it, and I was able to snag it by twisting the wires. It was a major pain.
  4. Jun 15, 2022 at 11:37 AM
    #64
    Seethan
    Seth
    Middle TN
    #64
  5. Jun 15, 2022 at 3:11 PM
    #65
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    What's the build date of your truck? There were 2 different filters available.
    35330-30011 (02/1999 - 07/2000)
    35330-30020 (08/2000 - 07/2002)
    Edit: also if the fluid when cold and engine not running is below the 'hot', you're definitely low. If you are low enough the filter won't be able to pickup enough fluid for the trans to work. Have you tried adding a quart (or more) to get it to register on the dipstick?
    Jack McCarthy likes this.
  6. Jun 15, 2022 at 7:54 PM
    #66
    Seethan
    Seth
    Middle TN
    The date is 03/2000. I'm waiting till I get the new dipstick before checking the fluid levels.
    Jack McCarthy and NickB_01TRD like this.
  7. Jun 16, 2022 at 4:31 PM
    #67
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    This is a common misconception with a dash of truth mixed in.
    If your fluid is really dark that means there is a lot of clutch fluid in suspension. Changing your fluid in this scenario can lead to trans problems. Primarily because you drained out all the clutch material.
    If your fluid has a ton of miles but still looks nice and red you can change it with limited risk.
    FirstGenVol and FrenchToasty like this.
  8. Jun 16, 2022 at 6:01 PM
    #68
    Seethan
    Seth
    Middle TN
    It's about as black as old oil and smells worse ;-;
  9. Jun 17, 2022 at 1:10 AM
    #69
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    @Seethan with regards to identifying the correct part(s) go to this site and enter your vin and search for the desired part: https://www.toyotapartsdeal.com
    Changing the fluid should not result in the transmission from going into gear regardless of the condition of the original fluid. You must have disconnected something else beyond simply removing the bolts to the drain pan and filter. Check the shift linkage on the side of the transmission. Are any of the gears working?
    You shouldn't have installed a new filter/part if it was identical to the original and/or failed to verify the correct part #.
    3.4 L 5VZ-FE V6 190 hp (2000-2004)
    4-speed A340 automatic (2000-2004)
  10. Jun 17, 2022 at 2:48 PM
    #70
    Seethan
    Seth
    Middle TN
    I verified the part number on that website when I got it, so I know that it's the correct part (according to that website). I simply removed the bolts and nothing else. I really had to wrangle the pan out though; maybe I knocked something loose:notsure: I'll check the shift linkage.
    What do you mean by that?
    tunyota[QUOTED] likes this.
  11. Jun 17, 2022 at 7:05 PM
    #71
    tunyota
    When you put it in reverse or any other gear besides drive nothing happens as well correct? Usually when you put in it gear you should feel the torque from the engine preload the driveline before releasing the brake to move. If your not experiencing this I would assume the shift linkage isn't engaging the transmission.
  12. Jun 18, 2022 at 9:22 AM
    #72
    Seethan
    Seth
    Middle TN
    That is correct. And that is exactly what I noticed (and failed trying to explain) wasn't happening.
  13. Jun 18, 2022 at 10:47 AM
    #73
    tvpierce
    tvpierce Formerly New Member
    Maine
    The transmission is really at its heart, a hydraulic pump. If there is not enough fluid to in the pan to feed the inlet of the pump, it's not going to build pressure and load the drivetrain. Didn't you say earlier that when the shift lever in is Park the transmission is "locked" as it should be. And when you shift into Drive the truck will roll as if it was in Neutral? If that's the case, then your linkage is fine.
  14. Jun 18, 2022 at 11:06 AM
    #74
    Seethan
    Seth
    Middle TN
    Yeah, it sits perfectly on an incline in park.
    So at this point, the main suspect is not enough fluid.
  15. Jun 18, 2022 at 3:07 PM
    #75
    I think that's been the assertion many have tried to make since page 1. Main reason I never jumped in. Pretty sure they nailed it.
    tvpierce and Seethan[QUOTED][OP] like this.
  16. Jun 18, 2022 at 9:03 PM
    #76
    I’m still suspicious of the new filter setup. Even if 4 came out and you only put 3 in I would think it would do something. I think the new filter isn’t allowing fluid to be pumped through the trans. Think the holes don’t line up the same.
    shifty` likes this.
  17. Jun 19, 2022 at 4:35 PM
    #77
    Seethan
    Seth
    Middle TN
    The only differences between the filters is the length and the new one doesn’t have the spout. Maybe the spout on the old one caused it to be able to suck it up even at low levels?
    The filter is the secondary suspect for me at this point. I'll check it if the fluid check doesn't work.
  18. Jun 21, 2022 at 11:53 AM
    #78
    Seethan
    Seth
    Middle TN
    Here's the old fluid
  19. Jun 21, 2022 at 12:22 PM
    #79
    Would love to see a few drops of that on a paper towel, just so the color is more obvious.
    w666 likes this.
  20. Jun 21, 2022 at 12:39 PM
    #80
    Seethan
    Seth
    Middle TN
    Jeez that's ginormous
    FrenchToasty likes this.
  21. Jun 21, 2022 at 12:58 PM
    #81
    That's not quite what I was thinking of, but I see the error of my suggestion.
    You got a small transparent cup you can put barely enough fluid to cover the bottom and hold it over something white like this, taken from my previous truck's tranny?
    Just enough to actually see the color of the fluid. What you got in the bucket looks like it's burnt to a crisp, but when it's that deep, it doesn't take much to make tranny fluid look like motor oil.
  22. Jun 21, 2022 at 1:30 PM
    #82
    Seethan
    Seth
    Middle TN
    Thar ya go (still massive)
  23. Jun 21, 2022 at 1:40 PM
    #83
    Looks like 20yo fluid to me.
    My photo above has a little more garnet, but that was on a 80k mile half-ton GMC with 4l60e transmission that typically didn't tow, just hauled stuff in the bed occasionally.
  24. Jun 21, 2022 at 1:53 PM
    #84
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Looks like a need for the good ole blackstone lab analysis. See if that’s atf, motor oil or a combo of the two with metal shavings thrown into it.
  25. Jun 21, 2022 at 2:00 PM
    #85
    Seethan
    Seth
    Middle TN
    If what I found is correct, doing a fluid change replaces around half of all the fluid in the tranny. I'm gonna go ahead and put in new fluid, so last chance to tell me if it's a bad idea
  26. Jun 21, 2022 at 2:19 PM
    #86
    Jack McCarthy
    Bill
    North of Boston
    Actually, it’s only a third since it’s 12 quarts or 3 gallons when you include the fluid in the torque converter.
    tvpierce and shifty` like this.
  27. Jun 21, 2022 at 2:28 PM
    #87
    What he said.
    Most people try to do multiple drain-and-fill on set cycle, like every oil change or every 6 months. No filter change.
    I'd start by replacing exactly what you took out, start up, shift thru every gear a couple of times, then use the proper method to check fluid level with a fully-functional dip stick. I suspect you're going to find you're low, which I still think was the instigator to your initial problem.
  28. Jun 22, 2022 at 6:25 AM
    #88
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Doesn't look great but doesn't look terrible. Looks like it's been overheated a time or two, which I believe you said it smelled burnt so that tracks. Likely from being underfilled, once you get a new dipstick and get the correct amount in I think you'll be fine.
  29. Jun 23, 2022 at 7:31 PM
    #89
    Seethan
    Seth
    Middle TN
    Thank the good Lord above, it worked. I ended up putting 6+ quarts into it. I only emptied about 3.5 to 4. Needless to say, she was thirsty. Now off to get new tires and get the alignment fixed and she'll be good as new.:yes:
  30. Jun 23, 2022 at 7:34 PM
    #90
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yay!!!
    w666 likes this.
