1st Gen Suspension Friends!
Discussion in '1st Gen Tundras (2000-2006)' started by wingnutted, Jan 30, 2020.
  1. Jan 30, 2020 at 7:41 AM
    wingnutted
    wingnutted [OP] New Member
    Seattle
    2006 Black Tundra TRD Double Cab
    Hi All,
    Finally looking to order new suspension for 2006 double cab. Going with 6112 in the front with SPC UCA, and 5160 in the rear. Add a leaf pack is most likely included as well, but it seems like there are some conflicting opinions on which one is most effective here, so I haven't quite decided specifically which one.
    I'm also curious if anyone has completely replaced the OEM rear leaf springs when they have upgraded suspension, as they're 13 year old parts at this time. If the other suspension components are new / upgraded, should the rear leafs be as well?
    Truck is primarily used for camping and road trips, and isn't a daily driver at this point.
    Thanks!
  2. Jan 30, 2020 at 8:00 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    I do not recommend the add-a-leafs. In fact, I'm actively going to crusade for their demise.
    All joking aside, if you are hell bent on an AAL, go with wheelers. If you really want/need lift in the rear, leave the overload spring in. Personally, I wish I had just saved my money for new leaf packs instead of wasting money on the ICON AAL.
  3. Jan 30, 2020 at 8:59 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I swapped to Alcan full leaf pack around 2012. At the time the only options were some soft Deavers, some soft under axle Deavers, or some middle of the road Alcans.
    With most aftermarket off road springs you lose payload in exchange for flex. There are a lot of options now and at least one member here replaced his leaf pack with oem style replacement and an add a leaf.
    Your best bet with suspension is to decide exactly what you'll use your truck for. Then reach out to a few suppliers and talk to them about your needs.
  4. Jan 30, 2020 at 9:02 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I literally JUST had this install on mine a week ago (6112s set at 6/8 respectively for driverside lean) and 5160s in the rear...except I have Freedom Offroad UCA and used a Wheelers AAL with overload left in. My intention was always to go with a full leaf-pack (this will be a dedicated camping rig at some point), but there are precious few leaf-packs made just for our trucks without going for a built to order. I'm keeping my eye on Archive Garage Shackleton leaf-pack for our trucks for the not so distant future after some reviews get out there, but the Wheelers AAL is working fine at the moment. I'm almost completely level...if you don't have a cap, you may get a bit more lift out of the AAL.
    https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-498#post-1595133
    https://archivegarage.com/explore-archive?olsPage=products/archive-shackleton-springs
  5. Jan 30, 2020 at 11:45 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    All depends on the condition of your leaf springs. You can always install the new shocks and drive them for a bit to see if the leaf springs are ok.
    I used the toytec 3 leaf AAL which is made by deavers, left the overload in and I got roughly 1.5 of lift. I've since realized my leafs are shot and I should have just replaced them at the get go. If you don't have extra weight in the bed, getting replacement leafs from general springs or sd truck springs and adding the AAL isn't a bad cost effective option. I have a shell on mine and some camping stuff so when I can swing it, I'm going with the Icon RXT. I like that I can move the leafs around if I ever remove the shell, or add more weight to the truck.
    Atlas makes a leaf pack and you can specify the lift you want.
    So far the options I know of are Alcan, Deavers, Atlas, Icon, General Springs and sd truck springs
  6. Jan 30, 2020 at 8:16 PM
    wingnutted
    Seattle
    @speedtre I hadn't even UCA's by Freedom Offroad...it looks like they have two models that fit the truck, which ones did you end up with? Any reasoning behind going with those over SPC or Chaos?
    I'd seen the Archive Garage full leaf set, but had thought it would end up overly stiff for me, as it would be a rare trip that I would have that much weight in the bed.
    On a separate note, have you noticed much of a difference from the new steering rack bushings? I've been thinking about those too, and I'm in a pretty similar situation from a mileage standpoint (2006 truck, 110K miles)
    Your truck looks awesome BTW!
    speedtre likes this.
  7. Jan 30, 2020 at 8:19 PM
    wingnutted
    Seattle
    @Darkness and @rock climber, thanks for the tip on Alcan, I'll reach out to them with details on how I use / plan on using the truck. Icon offers a leaf pack (other than AAL) for 1st gen?
  8. Jan 30, 2020 at 8:20 PM
    wingnutted
    Seattle
    Do you mean new OEM leafs just to refresh them? Or full pack replacement from another company?
  9. Jan 30, 2020 at 8:34 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Steering rack bushings were hands down, the best thing that I’ve done to my truck.
    You don’t realize how much the rack moves and creates that famous steering slop. After the bushings, a quick alignment and ensuring my tires were balanced properly, this thing tracks as well as my wife’s X3.
  10. Jan 30, 2020 at 9:58 PM
    wingnutted
    Seattle
    Did you use the same kit as @speedtre ? It looks like Energy Suspension has a front bushing kit, but also a complete front end rebuilt kit?
    The steering has definitely been one of the few disappointments for me since picking up the Tundra, so it's good to know other folks have found improvements to it. Previous vehicle was an 06 Subaru Outback, which had surprisingly awesome steering feel and feedback. Other than that, I'm usually riding motorcycles, so the steering response and feedback from the Tundra has been underwhelming to say the least....
  11. Jan 31, 2020 at 4:42 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    It’s been a bit but I think that sounds right. All I remember that I was sure to get the graphite impregnated ones.
  12. Jan 31, 2020 at 4:50 AM
    FirstGenVol
    East TN
    2002 AC
    New leaf packs from anyone would have been better use of my money than these AAL's.
    Volt92 and mcharfauros like this.
  13. Jan 31, 2020 at 5:03 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have used Alcan to do this on two different Toyota trucks, they will build in whatever lift and added cargo capacity you want and the quality is excellent.
    Darkness likes this.
  14. Jan 31, 2020 at 6:08 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Someone posted on here awhile back asking about the Freedom Offroad UCAs and the reviews for them were good, but like some of the other more expensive UCAs, they were making slight contact with the upper shock tower. Freedom Offroad redesigned them and offered a set to someone to test, report on them and then review them (waiting for the suspension to settle and finalize my alignment before I review them) so I took them up on their offer. So far so good. I was able to get my alignment in spec with no issues at all. I have read that for these trucks when you lift them you want to set caster higher than normal to prevent a wandering feeling. I talked about this with my shop and he convinced me it would be best to set the alignment to factory spec, drive it for a week or two and come back and adjust the settings based on how it was driving and that made sense to me so that is what I'm doing.
    So...how is it driving? Well, the steering is more deliberate and tighter, which is what others have reported with the energy suspension bushings. I do have what I would call a slight wandering feeling at highway speeds compared to my previously 100% stock setup, so I'm planning on taking it back to him next week, discuss the way it's driving and adjust the alignment. Right now, it appears the conventional wisdom that these trucks need additional caster once lifted appears right. I'm at 1.6...my understanding is that 2+ is where you want to be, but I don't know how much above 2. I seem to remember @empty_lord and @Festerw having some knowledge on this so maybe they can chime in?
  15. Jan 31, 2020 at 6:13 AM
    Professional Hand Model
    Hand Protectors
    Here are the specs from mine. I have no idea what this stuff means, but the truck drives nicely.
  16. Jan 31, 2020 at 6:13 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I just had mine aligned while it was in for the airbag recall. At 2.5" lift on mine the caster is set 2.4 and could probably use a touch more but it doesn't wander like it did when it was closer to 2.
    KarmaKannon and speedtre like this.
  17. Jan 31, 2020 at 6:22 AM
    FirstGenVol
    East TN
    2002 AC
    I'm at 2.7. I believe @toyotech2016 says the more caster, the better. No wondering steering for me.
  18. Jan 31, 2020 at 7:49 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    2.5-3 caster is ideal you want it to be even on each side. In spec toe and camber
    speedtre[QUOTED] likes this.
  19. Jan 31, 2020 at 7:51 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Perfect, that's what I'll have him shoot for next week...:thumbsup:
    empty_lord[QUOTED] likes this.
  20. Jan 31, 2020 at 7:52 AM
    empty_lord
    05 rollover special
    Biggest thing is left to right make sure camber caster and toe are even. Makes gather drive soo much better
    KarmaKannon and speedtre[QUOTED] like this.
  21. Jan 31, 2020 at 8:03 AM
    rock climber
    Here's the Icon option
    https://accutuneoffroad.com/product...iqxQa4Ct_QBA4x-uCsse-Mtq36Rz0gfsaAsfCEALw_wcB
    One note of caution on the freedom offroad UCA, it's not adjustable like the SPC and it's not terribly clear how much additional caster you get, but it appears to be minimal to none. You can get the Eibach version of the SPC (which seems to be the exact same thing even down to the part number) for $500. Jegs has it for $550 and they have tons of $50 off coupons.
    https://www.jegs.com/i/Eibach/369/5.25485K/10002/-1?ymm=4294829852+4294829046+4294827907
    Festerw likes this.
  22. Jan 31, 2020 at 8:22 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I personally wouldn't trust their lift claims for a Tacoma to be equally applied to a 1st Gen Tundra...
    I'll let you know next week when I get my alignment adjusted. It's right in the middle of spec right now, but I'll be shooting for 2.5. :thumbsup:
    FirstGenVol likes this.
  23. Jan 31, 2020 at 10:42 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Good info @speedtre
    What I've found from my truck is to have toe and camber within factory spec and get the caster as high as you can within allowed spec. I had a shop give me too much caster once and it introduced some pitch feelings when turning fast or sharp with any sort of speed, it didn't feel comfortable. Getting back to high end within spec solved that.
    This is pretty much in line with the famous "DJ Specs" from long ago on TS.
    Festerw and speedtre like this.
  24. Jan 31, 2020 at 2:39 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    More caster will make it drive straighter if toe is correct. I'm about 2-2.5 and could use some more. I could also use a sway bar and/or stiffer coils, so take that into consideration on my setup. My ranger has about 5* with maybe a little too stiff coils up front and it will do 70 on a severely rutted/bumpy dirt road with as little as 1 hand on the wheel.
    It's all relative, but 2 is on the low side and 5 is high in my opinion. The sweet spot depends on the vehicle, springs, use, sway bars, etc.
  25. Jan 31, 2020 at 2:46 PM
    FirstGenVol
    East TN
    2002 AC
    I'm skeptical of anything ICON says at this point. I had no idea they offered leaf packs for our trucks. When I asked for leak pack options in the past those were never mentioned. New?
  26. Jan 31, 2020 at 4:01 PM
    rock climber
    How much caster was too much? The DJ specs 2 degrees said was Toyota spec, but he strongly hinted that he'd go higher. Just curious when I finally get new UCA's what caster I should ask for.
  27. Jan 31, 2020 at 4:32 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    When I had 2.6 it felt pretty twitchy, the truck seemed to roll hard when turning as if it upset the balance(no other way to explain). I went back down to just under 2 and it was good. Hard to believe there was such a difference but there was.
  28. Jan 31, 2020 at 7:10 PM
    terrythesalmon
    terrythesalmon New Member
    2001 Tundra
    I just installed a general spring HD leaf pack on my 2001 tundra along with some 5100s. Ill let you know my initial impressions this next week when I torque everything down and get to drive it.
  29. Feb 1, 2020 at 3:33 PM
    wingnutted
    Seattle
    Can't wait to hear how it compares to your old leaf pack. How many miles on the ones you took off?
  30. Feb 1, 2020 at 4:26 PM
    terrythesalmon
    2001 Tundra
    Yeah, stoked to see how it rides. The old leafs had 120k miles on them.
