1st gen starter issues?
Discussion in '1st Gen Tundras (2000-2006)' started by Willyboi02, Sep 8, 2019.
  1. Sep 8, 2019 at 5:53 PM
    Willyboi02
    Willyboi02 [OP] New Member
    William
    2006 Tundra SR5 4.7L
    Custom exhaust, 3”level, 17x9 on 265/75/17, black head/taillights, full sound system, 20% tint, etc...
    Hey guys, first timer here! Recently the starter(or what I thought was the starter) went out on my 06 4.7l tundra. When I turned the key it clicked and didn’t turn over. Long story short I replaced the starter and everything was good. A month and a half later, I go to start my truck in the morning and it does the same clicking when I turn the key. I just kept turning the key for a few minutes and it eventually turned over just fine. I just wanna know if there is anything I can check to see why it would be fine one day and then not work, but then decide to work again. Thanks!
  2. Sep 8, 2019 at 6:07 PM
    Mike Tread lightly.
    south carolina
    Battery or battery connections could be bad..
    Pinay likes this.
  3. Sep 8, 2019 at 6:08 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    This ^^^
    speedtre likes this.
  4. Sep 8, 2019 at 6:09 PM
    Willyboi02
    William
    I’ve looked over the fuses and battery connections and they seem to be good. I purchased a voltmeter and I’m planning on testing the battery. Thank you!
  5. Sep 8, 2019 at 6:11 PM
    Mike Tread lightly.
    south carolina
    Unless you have a bad starter that is possible... Money is on battery or bad connections (clean them wire brush)...
    Might want to double check the big + wire coming off the battery that's starter wire... Make sure that is still crimped good.
  6. Sep 8, 2019 at 6:12 PM
    Willyboi02
    William
    Alrighty will do. That would make sense why it works sometimes.
  7. Sep 8, 2019 at 6:16 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Could be a bunk starter.
    Most of the time when the Oe ones “go bad” it’s simply bad contact between the plunger and the contacts.
    I always recommend keeping the Toyota starter and first replacing those parts before going for a parts store rebuild.
    My 99 Tacoma has the factory original starter to this day (245k). I had to replace the starter contacts at 110k due to intermittent starting issues like you are experiencing.
    Google Toyota starter contacts.
  8. Sep 8, 2019 at 6:17 PM
    Mike Tread lightly.
    south carolina
    Op replace the starter..
  9. Sep 8, 2019 at 6:20 PM
    Willyboi02
    William
    Unfortunately I didn’t get to do much research before I replaced the starter. I bought the starter from autozone an hour after it went out. I was stranded at Walmart and didn’t have time to waste because of work.
  10. Sep 8, 2019 at 6:22 PM
    Mike Tread lightly.
    south carolina
    Have the battery tested also.
  11. Sep 8, 2019 at 6:24 PM
    Willyboi02
    William
    I’m planning on it. I would much rather buy a battery than go through replacing the starter again. Thanks for all you help!
  12. Sep 8, 2019 at 6:24 PM
    Mike Tread lightly.
    south carolina
    Let us know...
  13. Sep 8, 2019 at 6:25 PM
    Willyboi02
    William
    Will do
  14. Sep 8, 2019 at 6:41 PM
    Twinky
    07 double cab work horse
    Yeah, definitely the best and most economical place to start.
    I'm leaning more towards a bad/corroded connection. Its not uncommon and easy to miss when reconnecting the power and grounds.
    There's only a couple important ones to check. The battery terminals, the negative to the body. The body to block ground and the starter, typically.
    For what its worth, Its always the ground wires when I have similar problems.
    Hopefully its something as simple, and cheap, as that.
    Filthyphil likes this.
  15. Sep 8, 2019 at 8:29 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I read the OP. I guess you didn’t.
    Op stated he is having the same exact symptoms a month and a half later.
  16. Sep 8, 2019 at 8:35 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I hear ya. I’d have done the same thing in a jam. I should have just said “it sounds like your new starter failed.”
    I guess the other guy who quoted me didn’t understand my last post. :rolleyes:
  17. Sep 8, 2019 at 8:54 PM
    Limu
    Limu New Member
    Alan
    2001 Tundra white
    Donahue coilovers front, Fox rears. Deaver 10 leaf pack
    Check to see if your terminal wires can rotate. I tightened the nut but they still moved. The solution was to get a cap that fit over the post and put the wire back on. After tightened there was no rotation and it fired right up. In my case it was intermittent, but just had my starter replaced so thought it was a bad starter. It was a bad connection turns out.
  18. Sep 9, 2019 at 4:28 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Was the new starter a cheaper aftermarket unit? If you replace the starter again, do it right and get a Denso or OEM unit.
  19. Sep 9, 2019 at 4:58 AM
    Willyboi02
    William
    After school today I’m going to check everything once again with everything you guys have suggested. I’ll keep you updated. Thank you!
  20. Sep 9, 2019 at 5:20 AM
    Mike Tread lightly.
    south carolina
    I read your post.. hard to rebuild the starter if it's been replaced and at the parts store for the exchange right o_O...
  21. Sep 9, 2019 at 5:26 AM
    Willyboi02
    William
    It was a duralast. May be cheap but I don’t really know. Hopefully I won’t have to again.
  22. Sep 9, 2019 at 5:26 AM
    Mike Tread lightly.
    south carolina
    All my post are to the battery /connections not pointing fingers. :rolleyes:
  23. Sep 9, 2019 at 5:27 AM
    Mike Tread lightly.
    south carolina
    I have one in my Tacoma for 16 years no problem...
  24. Sep 9, 2019 at 5:28 AM
    Willyboi02
    William
    That’s crazy but I guess if you take care of it they last. Unfortunately I don’t think the previous owner of my truck took good care of it.
  25. Sep 11, 2019 at 8:00 AM
    Willyboi02
    William
    Update: I’ve checked my battery, connections, fuses, and then checked them again. I found nothing wrong and I don’t really know where to go from here. I suppose I’ll wait and see if it does it again and go from there. Thanks for all the help.
  26. Sep 11, 2019 at 10:54 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    Check the ground wires as well...especially the one by the battery, Make sure the connection is clean and the wire isn't corroded.
  27. Sep 11, 2019 at 4:09 PM
    Willyboi02
    William
    I wish I could say I haven’t checked them yet but I’ve looked over and cleaned every wire I can.
    SC T100[QUOTED] likes this.
