1st gen sequoia
Discussion in '1st Gen Tundras (2000-2006)' started by Jake0996, Mar 8, 2023.
  1. Mar 8, 2023 at 12:58 PM
    Jake0996
    Jake0996 [OP] New Member
    I just recently changed water pump timing belt injectors injector pigtails plugs and coil packs but have a multiple cylinder miss fire code and it’s running super rough I’m thinking maybe I mixed up some vacuum lines anyone have any ideas
  2. Mar 8, 2023 at 1:04 PM
    Boy the possibilities are endless. Could be out of time now. Could have counterfeit injectors. Could have counterfeit coils. Could have mixed up coil pack wires. Could have improperly routed the cam sensor wire. Could have bad gas. Could have improperly routed the vacuum lines. Where to start? Go back over your work, use a repair manual or the FSM.
  3. Mar 8, 2023 at 1:25 PM
    Jake0996
    Okay perfect thank you any idea on where I can get the repair manual for this thing
  4. Mar 8, 2023 at 1:48 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Pre vvti? Tundra2 has one linked in his signature.
  5. Mar 8, 2023 at 1:53 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    CEL on? What codes?
    Could be fuel pump, could be spark plugs, could be you did something wrong, etc...
    My money is on the timing being off
  6. Mar 8, 2023 at 2:11 PM
    the FSM is the Toyota “bible” for these trucks. A treasure trove of info. I have a Haynes / Chilton’s manual that I reference when making major repairs I haven’t done before.
  7. Mar 8, 2023 at 5:28 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    No idea which year/model you have, but Tundra manuals are in the fourth paragraph of this article.
  8. Mar 8, 2023 at 5:38 PM
    Sounds like you fucked up the timing to me.
    Unless you used non-OEM parts. OR maybe you ordered parts off scAmazon, fleaBay, or WallyWorld and got counterfeits like so many other people have. These trucks are particular about aftermarket parts with the electronics. And counterfeit parts are rampant on the big 3 I just listed.
    But let's go with timing first. Start backwards. Go back in and re-confirm timing. Yes, it sucks, but you don't want a brick, right? Make sure you know what the hell you're looking for, if you don't understand how to set the timing let us know, take some pics of your timing marks. Still misfiring? Reinstall the original coils. Still misfiring? Come back and let us know.
    Make sure you didn't make the stupid, hair-brained mistake a lot of others do - make sure you properly tucked away the crankshaft position sensor's wiring harness. It should not be hanging out in any way, there's a spot for you to tuck it into properly.
  9. Mar 8, 2023 at 5:38 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Might be a vacuum leak or a hose put on wrong. Did you pull off the Manfold?
    Put the old coils back in.
