1st gen rear locker
Discussion in '1st Gen Tundras (2000-2006)' started by Wes_heppy, Jan 3, 2021.
  1. Jan 5, 2021 at 6:19 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think Toyota calls for 90 API GL-5 but thats really hard to find. 80w-90 works fine. I believe mine takes just a bit over 3 qts.
    Be sure to check put your diff breather while you are at it. Good investment to do the breather mod and run an extension tube up into the rear tail light area. Making sure the breather works will prevent you from blowing seals.
  2. Jan 5, 2021 at 6:21 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  3. Jan 5, 2021 at 6:22 PM
    Wes_heppy
    Wes_heppy [OP] Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    Ok sweet. Ill do a fluid change before too long then.
  4. Jan 5, 2021 at 6:47 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Thanks for sharing that, looks like the guy to get in touch with if I decide to add more traction to my non LSD 2wd and he's only 20 minutes away!
    Darkness likes this.
  5. Jan 5, 2021 at 7:09 PM
    FrenchToasty
    Mo
    Bone stock
    His work is very well known in the local clubs, it was either here or on one of the local forums; he fixed another company install issues and got the customer back on the road proper. If I ever regear or lock something I’ll send it up there.
    Darkness and Lil Steve[QUOTED] like this.
  6. Jan 5, 2021 at 8:08 PM
    ADKYoter720
    ADKYoter720 New Member
    Raymond
    Adirondacks of NY
    2006 DCLB TRD Mica Blue
    Stock... for now
    Some good info going here. I’ve been thinking on what to do out back for a traction adder. Installing an Old Man Emu suspension this weekend, and so far I’ve been unimpressed with the limited slip
    Wes_heppy[OP] likes this.
