  1. Mar 12, 2022 at 8:54 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm only replacing mine because they have 325k miles on them and want 100% new suspension. You should be fine.
    chrisb likes this.
  2. Mar 12, 2022 at 9:04 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    No, your shackles are 100% good
    5N0W808 and des2mtn like this.
  3. Mar 12, 2022 at 9:04 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Also, some dickhead keeps drinking all my beers. It's super annoying. I keep having to get up and replace them. And get this: as a side effect of that, I keep having to pee! What are the coincidences?
    NUDRAT[OP], Darkness and daveeasa like this.
  4. Mar 12, 2022 at 9:05 PM
    alb1k
    Left Coast
    It's good
    That guy got me too. I’m going to pee in a beer can and see if that stops him.
  5. Mar 12, 2022 at 9:30 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    flywheel for the mr2 is here. waiting on the gasket kit so i can reseal the engine and get it prepped for the car.
  6. Mar 12, 2022 at 9:32 PM
    alb1k
    Left Coast
    It's good
    Sweet. And stickers. Yew!
  7. Mar 12, 2022 at 9:47 PM
    empty_lord
    05 rollover special
    LOL stickers and a free 10mm... dude knows how to sell shit and man, its all beautiful parts too.. wait till you see his mounts when im ready to drop the motor in
    bmf4069, 5N0W808 and Darkness like this.
  8. Mar 12, 2022 at 9:49 PM
    alb1k
    Left Coast
    It's good
    10mm Glock or socket? Solid mounts on that, right?
    Darkness likes this.
  9. Mar 12, 2022 at 9:56 PM
    empty_lord
    05 rollover special
    na, he uses rubber. solid mounts arent needed. its just a pretty damn firm rubber. i'll be running front and rear mounts, his mounts on the side mounts.
  10. Mar 12, 2022 at 9:58 PM
    alb1k
    Left Coast
    It's good
    I look forward to seeing those. :)
  11. Mar 12, 2022 at 10:00 PM
    empty_lord
    05 rollover special
  12. Mar 12, 2022 at 10:17 PM
    alb1k
    Left Coast
    It's good
    That's really nice looking gear. I wonder, as a side note, why he is not doing all pedals?
  13. Mar 12, 2022 at 10:21 PM
    empty_lord
    05 rollover special
    no need to. toyota sells pedal covers that fit and match the is350 gas pedal. the only reason he sells a pedal is because you need to convert to a fly by wire in a car with a throttle cable originally
  14. Mar 12, 2022 at 10:23 PM
    alb1k
    Left Coast
    It's good
    And there we have it. I'll try harder next time.
  15. Mar 12, 2022 at 11:36 PM
    alb1k
    Left Coast
    It's good
    Plan D and E.
    I found check valves that run on 3/8 or 1/4 inch air line. I also found a superior 5 gal talk to the one I bought. We will see if the no return first tank guy will cancel the order that hasn't moved an inch over a Saturday. But no big deal, either I fit both that tank and the superior tank for different jobs, or I eat the inferior tank and move on. But, I think we are no longer a closed water system with the check valves, and can run an air tank as a manifold and a water tank that has a regulator to it. And with a primary air tank as a manifold, air for inflation and air horn(s). Every day I get cut off in the same places. Bitches are going to hear about it.
    chrisb likes this.
  16. Mar 12, 2022 at 11:54 PM
    alb1k
    Left Coast
    It's good
    And after a quick jump under the truck - Plan E.
    (2) 5-gallon tanks will fit. Spun model for air distribution, welded model as a low pressure water tank. Both have a ton of ports and adjustable mounts. The plumbing will take some time and thought, but I'm excited about what can happen here.
    chrisb, FrenchToasty and Sirfive like this.
  17. Mar 13, 2022 at 4:14 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Hey make sure that your "spring bumpers" are still there. You might not have enough rust but I've seen those just fall right off the metal plate they're attached to.
    Tundra2 and Darkness like this.
  18. Mar 13, 2022 at 4:31 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    3CD8FC3E-0B00-4B70-B976-3F9D82FBB082.jpg 1400 plugs done yesterday
  19. Mar 13, 2022 at 7:15 AM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
  20. Mar 13, 2022 at 7:32 AM
    daveeasa
    David
    I can see how that brown color isn’t a fan favorite.
  21. Mar 13, 2022 at 8:12 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  22. Mar 13, 2022 at 9:04 AM
    alb1k
    Left Coast
    It's good
    Urban hiking series…
    bmf4069, Darkness and FrenchToasty like this.
  23. Mar 13, 2022 at 9:29 AM
    alb1k
    Left Coast
    It's good
  24. Mar 13, 2022 at 9:37 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Creepin on someone’s penthouse!
  25. Mar 13, 2022 at 9:46 AM
    alb1k
    Left Coast
    It's good
    Full trespass. But Sunday am is a fairly safe time for it.
    chrisb and FrenchToasty[QUOTED] like this.
  26. Mar 13, 2022 at 9:51 AM
    FrenchToasty
    Mo
    Bone stock
    I know the problem is bad everywhere; but holy shit we have some camps that would rival skid row. They recently “removed” this huge one right along the street after months of it being there because it was blocking the bike/pedestrian trail. There’s another one close by in the center of a traffic horseshoe that looks literally like a dump, and they even have hoses hooked up to back flows so they have fresh water!
    Darkness and alb1k[QUOTED] like this.
  27. Mar 13, 2022 at 9:54 AM
    alb1k
    Left Coast
    It's good
    I did an urban hike through Venice Beach and Santa Monica yesterday. I was thinking about you guys. Next time I’ll take pics. It’s like a Walmart hall of shame with more drugs, thugs and ass.
  28. Mar 13, 2022 at 9:56 AM
    FrenchToasty
    Mo
    Bone stock
    I just do urban drives, don’t wanna step on anything or get bitten by the local wildlife. Haha I’ll take some pics next time to show you how shitty my city is!
    bmf4069, GODZILLA and Darkness like this.
  29. Mar 13, 2022 at 9:58 AM
    alb1k
    Left Coast
    It's good
    I would have to go out of my way to one up you I bet. But let’s see what we can come up with.
  30. Mar 13, 2022 at 10:00 AM
    FrenchToasty
    Mo
    Bone stock
    Haha maybe a “Yo MTV Cribs” thread of sorts!
    alb1k[QUOTED] and Darkness like this.
