  1. Mar 3, 2022 at 10:27 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    5N0W808 and sn_85[QUOTED] like this.
  2. Mar 3, 2022 at 10:34 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    A medium sized suv isnt as happy with a trailer as a 1gt. The sequoia is even better. My trailer is easily over 2klbs before the 200-300 lbs of chains tools and straps. And my xj or ‘97 4runner werent happy about it. Not enough wheelbase or spring.
    i still think i need to stretch the tundra chassis with a sequoia chassis for a long bed. Tote a trailer like it isnt there. It also sucks setting up the blanket/tarp when loading things that leak.
  3. Mar 3, 2022 at 11:07 AM
    Sounds like you need to sport truck it, honestly. Lower it 2/3 or 3/5 and go with a more sensible-mpg wheel/tire combo so you're lower to the ground and maybe eek out a little more aerodynamically, while giving yourself a new driving experience with the new stance. If you don't get beyond 2/3 you should be fine without having to adjust any of the driveline stuff, not sure about 3/5.
    Something tells me the 1GT would be a really, really goddamn fun truck to throw sport suspension onto.
    Purely the war. This same crap happens any war, every war. Wasn't it Desert Storm that ended up forever pushing us over $1 nearly forever? Then just when prices were getting back down, 9/11 kicked off more BS war that doubled the high point of the one prior, sending it up to $4-something, then the recession hit a few years later, high gas prices and that recession made for a fun crime experience down here.
    It all sucks. Again, this is why I was seriously hunting for a 2.4L Taco 2WD. Has a bed to haul stuff, pretty solid mpg, looks good, some aftermarket options for either sport truck or offroad conversions, double-DIN radio opening going back several decades, extra cab options, it's a no-brainer. But at this point, a smaller sedan hybrid like either a Prius or maybe the RAV4 hybrid seem like really damn good options rn.
  4. Mar 3, 2022 at 11:20 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Beautiful pre-face lift 5th gen. Those OG 5th gens are some of my favorites.
    5N0W808 and FrenchToasty[QUOTED] like this.
  5. Mar 3, 2022 at 11:24 AM
    FrenchToasty
    Mo
    Bone stock
    Thanks. I’m trying to find a new front bumper plastic, so I can remove that winch and throw it in the truck!
    It’s the mom-mobile but it has served us great!
  6. Mar 3, 2022 at 11:26 AM
    daveeasa
    David
    I just canceled my arb front locker as it's 3 months after the order went in and still not here. I have front and rear gears so it's now time to figure out if I'm doing a locker at all or just doing 4.56 with LSD in the back and open in the front. @alb1k what do I do?
  7. Mar 3, 2022 at 11:29 AM
    FrenchToasty
    Mo
    Bone stock
    Send it!
    I think you’ll be fine without a front locker
    5N0W808 and Sirfive like this.
  8. Mar 3, 2022 at 11:34 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I've looked at a few setups and it seems to depend on if you are doing front rear or both. I would have to research it to give any real advice. TrueTracs are really popular if you don't need selectable. Some people use different types for the front and the rear in 4WD. Someone on here that has 4WD must have some insight. I think it's hard to go wrong with selectable front and rear, and that is a shit ton of money. I'm going to punt :anonymous:
    5N0W808 likes this.
  9. Mar 3, 2022 at 11:35 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I've considered a sport-truck.
    But I'd want to lose my whole mind if I did that. Pick up an S10, Taco, or hardbody chassis, shove a modern turbo 4cyl in it, hammer it on its nuts, big C-notch in the back, 4-linked rear w/coilovers & airbag helpers, long arms (double wishbone) up front, rack n pinion, Vette knuckles, wilwood discs all around, etc. Basically a solid-axle sports car with a truck body over it. #fullsend
    5N0W808 and shifty`[QUOTED] like this.
  10. Mar 3, 2022 at 11:39 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    find soft wet grass. Soft enough to sink in a bit. Thats where i see lockers being worth it. It was more prevelent around houston, but hard locking sounds like the plan for achievement. Especially if i want some predictability to crawling over things.
    chrisb likes this.
  11. Mar 3, 2022 at 11:47 AM
    alb1k
    Left Coast
    It's good
    Also depends on how crazy you want to get. 4WD with open/LSD is pretty capable. I don't think @Casper421 has his ARB rear in yet and he has been pretty successful from what I gather. @Cruzer Tries to climb walls - he has front and rear ARB. I got selectable because my drive only pushes so two wheels is a big help. With the push and pull of 4WD, it might worth some type of auto, like a TrueTrac. Those are more affordable and cheaper since you are already going in there for gears. Wish I was more help.
    5N0W808 likes this.
  12. Mar 3, 2022 at 11:48 AM
    daveeasa
    David
    I should clarify a bit I think? My truck is 4wd. I'm spending a fair number of pennies so cost isn't the primary concern. I am 99% confident on using one of the two LSD's for the rear when I do the regear. I want this truck highly driveable on and off road by a novice/idiot such as my kids once they are older or any friend who needs to borrow it. The entire point of this truck is to be as bulletproof as I can make it and then use it for anything it's safe to use it for.
    For the front, given that I nuked the ARB it's really Eaton or open diff. I'm ok with spending on the Eaton now that I'm off the hook on the ARB. I'm going to try to send 3rds to Zuk for the gear and I'm sure that's going to cost. I have new cv axles from whever you guys said to get them from, I forget the 3 letter name.
    I think it's really Eaton or no Eaton at this point. I don't expect Zuk will touch anything other than Eaton.
    5N0W808 and FrenchToasty like this.
  13. Mar 3, 2022 at 11:51 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Story time about nuking the arb? Or is there a thread?
    FrenchToasty likes this.
  14. Mar 3, 2022 at 11:55 AM
    alb1k
    Left Coast
    It's good
    It's probably Eaton E-Locker at like 1200 for the unit. Eaton TrueTrac for a bit over half, but also install and forget it, or open as the three options now. The ARB is reportedly strongest, but hard to get it seems.
  15. Mar 3, 2022 at 11:55 AM
    daveeasa
    David
    Ordered at the end of November during whatever black friday sales they had. As of today it's still not received. Who knows if they even attempted to ship it. Who knows if they have anything to ship. Maybe it's on a boat somewhere. No idea. Nytro does not impress. They did send me two of one gear set and two of the LSD though so I can live with the 3 month wait.
  16. Mar 3, 2022 at 11:56 AM
    daveeasa
    David
    ARB was my pick b/c it seemed robust but with Zuk refusing to touch it, I soured on that plan.
    Eaton e locker or open are about all I'd consider I think.
  17. Mar 3, 2022 at 11:56 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Just teenyweeny walls :anonymous::rofl:
    Love the front locker. Can do a lot more things with it, just have to be careful when to use it.
  18. Mar 3, 2022 at 11:57 AM
    alb1k
    Left Coast
    It's good
    That's happened to me on a couple of things. Shops take orders for what they don't have and then order it themselves without having a clear timeline.
  19. Mar 3, 2022 at 11:59 AM
    daveeasa
    David
    If I do order up an Eaton, anyone know where I might have a chance of it actually being in stock or getting to me in a month or less?
  20. Mar 3, 2022 at 12:01 PM
    Casper421
    In the woods
    06 DC
    I’m still waiting for the last gear set from Nitro! Getting very pissed!
  21. Mar 3, 2022 at 12:01 PM
    alb1k
    Left Coast
    It's good
    I ordered mine through Frank the installer and he had it in a day.
  22. Mar 3, 2022 at 12:02 PM
    alb1k
    Left Coast
    It's good
    Revolution perhaps.
    At this rate you are going to breaking in the gears on the way to Sedona...Eww.
  23. Mar 3, 2022 at 12:03 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    But for the grace of god, there go I.
    i havent ordered the bits i need/want. Watching the bits over time and noting whats needed, but im still waiting on some kr’s to protect the shipping industry.
    chrisb likes this.
  24. Mar 3, 2022 at 12:06 PM
    alb1k
    Left Coast
    It's good
    I just noticed you are the Handicapper General. Nice.
    FrenchToasty and Sirfive[QUOTED] like this.
  25. Mar 3, 2022 at 12:08 PM
    Casper421
    In the woods
    06 DC
    I gotta call nitro after work and get some answers. I’ve checked around and there are no nitro 4.88’s available anywhere. Might go revolution or Yukon.
  26. Mar 3, 2022 at 12:11 PM
    alb1k
    Left Coast
    It's good
    2 or 3 of those are made in the same factory. So the story goes.
  27. Mar 3, 2022 at 12:17 PM
    Casper421
    In the woods
    06 DC
    I hope my oem gears and lsd will survive the 35’s in Sedona!
  28. Mar 3, 2022 at 1:13 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I feel like you left us hanging. Did you get the 35's mounted yet? I saw you mounted 1 wheel but never saw a follow up. Send pics!!!
  29. Mar 3, 2022 at 1:32 PM
    alb1k
    Left Coast
    It's good
    Not yet - he's gonna shoot for this weekend.
    Casper421 and FrenchToasty like this.
  30. Mar 3, 2022 at 1:33 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Eaton e-locker for easy steering and additional grip when necessary (if ever necessary). Also rebuild the rear LSD, unless you also already got a torsen for the rear (true trac, grip pro, etc.)
    Also probably true.
    5N0W808, daveeasa[QUOTED] and alb1k like this.
