  1. Feb 26, 2022 at 4:04 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    I honestly don't think I've ordered specific truck parts from Amazon. You're right, their search function is terrible and will typically bring up either counterfeit or cheap chinese parts. I've just never trusted them with anything important because they don't have any QC over their vendors.
  2. Feb 26, 2022 at 4:50 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I was driving behind one of those new corvettes last night. They have an LED monitor for a rear view mirror.
    RUSTYNUTS and NUDRAT[OP] like this.
  3. Feb 26, 2022 at 4:57 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    and the camera is up on the roof. Can't make parallel parking easy.
  4. Feb 26, 2022 at 4:58 PM
    alb1k
    Left Coast
    It's good
    The guy driving this one wasn't making forward movement or right turns easy.
    Darkness likes this.
  5. Feb 26, 2022 at 5:22 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’ve never seen anyone parallel park in a new Vette. Personally, if I owned one, it would be a point A to point A car for me.
    NUDRAT[QUOTED][OP] and alb1k like this.
  6. Feb 26, 2022 at 10:51 PM
    alb1k
    Left Coast
    It's good
    I'm going to look for the wire by the drivers kick panel that is the high beams if it's there. I found the tail light wire searching online for the back up cam, but now I want to run the switch-pros trigger wire for every light facing forward via high beam. I'll probably be able to find it with a test light, but if anyone knows off-hand, thanks.
  7. Feb 26, 2022 at 10:53 PM
    alb1k
    Left Coast
    It's good
    With the rear wheels so far to the rear of the body, I'll back that ass up.
  8. Feb 27, 2022 at 1:19 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    to any of you running 33" tires. please. if you have your alignment specs, post them for me... im going to try and deal with my trucks alignment in the next couple weeks.. im tired of my excessive camber. so i need to start looking as to why i have to have so much for the caster to be where i want it... if i get camber in spec i end up with horrible rubbing
    chrisb likes this.
  9. Feb 27, 2022 at 1:51 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    This is mine from a year ago. I still need to go back and get some more caster.
    chrisb and FrenchToasty like this.
  10. Feb 27, 2022 at 2:05 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ll probably be doing a rack and rods soon, so I’ll post mine up as well, maybe make a sticky of printouts
    RUSTYNUTS and Casper421 like this.
  11. Feb 27, 2022 at 6:56 AM
    empty_lord
    05 rollover special
    Your casters about where mines at. But my camber is 1 degree and it’s bugging me
    I wonder if these reg and access cabs just can’t do it without some extra shit. I do have the camburg arms
  12. Feb 27, 2022 at 7:50 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Is it wearing the inside edges? The sequoia would wear the front tires, and while an alignment would helped, the fix was steering rack bushings.
    RUSTYNUTS and GODZILLA like this.
  13. Feb 27, 2022 at 8:53 AM
    Casper421
    In the woods
    06 DC
    I feel like alignment specs would be a good sticky!
    chrisb, alb1k, RUSTYNUTS and 3 others like this.
  14. Feb 27, 2022 at 8:57 AM
    FrenchToasty
    Mo
    Bone stock
    Maybe list tire size and other suspension mods, and then post your printout and any pros or cons that can be felt driving or in tire wear
  15. Feb 27, 2022 at 10:11 AM
    daveeasa
    David
    Ok, now that I have my drum brake order in, I think I want to do hubs and seals after all. Anyone have a link to a thread or post which might have part numbers on either?
  16. Feb 27, 2022 at 10:32 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Rear hubs? Like an axle swap?
  17. Feb 27, 2022 at 11:35 AM
    daveeasa
    David
    Whoops, sorry, bearings. I was sleepy. Hauling horses again.
  18. Feb 27, 2022 at 11:43 AM
    Jack McCarthy
    Bill
    North of Boston
    What’s involved with replacing rear axle wheel bearings?
    I’m guessing you don’t need to place an axle under a 20-ton press to get the new ones into it.
  19. Feb 27, 2022 at 11:46 AM
    daveeasa
    David
    Would an axle swap be of any value? I assume they are reasonably beefy? But maybe some strength could be added for towing?
  20. Feb 27, 2022 at 3:42 PM
    alb1k
    Left Coast
    It's good
    From +30 to 0mm offset plus a 1" wider wheel and a big tire for the truck = way too much, lol. Damn, I was planing on getting some 7 series methods for me.
    FrenchToasty likes this.
  21. Feb 27, 2022 at 3:53 PM
    alb1k
    Left Coast
    It's good
    I have 275/70/17 on a 8.5" 0mm offset. A tad over 32" The truck would be level if the rear was stock. That combination seems to be max without modification. Maybe if I had stock 15mm offset, I could go bigger without modification. I get the shop to go +3 deg caster and factory spec everything else.
  22. Feb 27, 2022 at 7:15 PM
    empty_lord
    05 rollover special
    whos in gerogia? i found most of the interior i would love to have. LOL just would be missing all the interior pieces for the rear at that point
  23. Feb 27, 2022 at 7:21 PM
    daveeasa
    David
    Shifty might be within range but B pillar remains your challenge and not sure I’ve ever seen a dark charcoal in that. You’d know more than me.
  24. Feb 27, 2022 at 7:23 PM
    empty_lord
    05 rollover special
    they're out there.
    but this would get me closer to a complete interior. i can live with the rear painted for a while till the proper stuff shows up. the dash and lower trim pieces wearing away is making it ugly.
  25. Feb 27, 2022 at 7:24 PM
    empty_lord
    05 rollover special
    still not 100% sure i know what i'll do with seats.. i may end up trying to fit avalon seats in it.. i really love the seats in my car.. but the arm rest situation is a real issue...
    NUDRAT[OP] likes this.
  26. Feb 27, 2022 at 9:29 PM
    daveeasa
    David
    I saw some slides somewhere which fit FGT? Maybe the same guys who make the LCA’s? Looked interesting. I wondered what could be done with that.
    I’m too enamored with my bench to let go.
    https://youtu.be/Zip4QyJyD5g
  27. Feb 27, 2022 at 9:32 PM
    alb1k
    Left Coast
    It's good
    Ive been listening to Cake for 20 years. And, I changed my mind, you OEM paper gasket for the diff/carrier on a rebuild are crazy.
  28. Feb 28, 2022 at 4:37 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You have to pull the axle and use a 20 ton press to unpress everything, then press it back on.
  29. Feb 28, 2022 at 4:46 AM
    Jack McCarthy
    Bill
    North of Boston
    I saw online some guy built a welded tube assembly just to use with a 20-ton press. None of that looks like any fun.
    des2mtn likes this.
  30. Feb 28, 2022 at 4:50 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Don’t really want to but at the point where I need to. Three car seats and items can no longer manage in the AC 1st gen. Looking at 2nd gens, sequoia, or lx470. Before I’m banished, any input? 20k is pretty much most I’m willing to drop; homeschool the kids with stay at home mom
