  1. May 28, 2020 at 6:28 PM
    #2791
    Professional Hand Model
    Hand Protectors
    I think 2003 was the first year Toyota offered the rear sway bar as a package.
  2. May 28, 2020 at 6:29 PM
    #2792
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think he's the only person on here that has the factory sway bar. It's neat and apparently rare!
  3. May 28, 2020 at 7:31 PM
    #2793
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    It came with the TRD sport package. so did a lsd which the offroad didnt.
    Rex Kramer likes this.
  4. May 28, 2020 at 7:32 PM
    #2794
    jImmegart
    Jonah
    California
    Ya ill go out and get one in a sec
    Rex Kramer[QUOTED] likes this.
  5. May 28, 2020 at 7:37 PM
    #2795
    jImmegart
    Jonah
    California
    Rex Kramer[QUOTED] and Tundra2 like this.
  6. May 29, 2020 at 4:21 AM
    #2796
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I first saw this OEM bar in 2003 I think, and I investigated adding it to my 2002 but bolting up a Hellwig was much easier.
    Tundra2 likes this.
  7. May 29, 2020 at 5:24 AM
    #2797
    Hand Protectors
    Finally was able to schedule my first mani-pedicure in months! Looking forward to it. Gonna do some work on the truck before the appt. just in case I break a nail.
    1) Checked my records and its time to rotate tires. Might wait another week and see if this axle seal is leaking.
    2) Received some Used parts and I’ll tinker a bit with those today.
    3) Working on my first cup of Italian Roast and maybe I’ll think up more stuff after the second cup.
    bmf4069 and Tundra2 like this.
  8. May 29, 2020 at 7:03 AM
    #2798
    Rex Kramer
    Georgia
    Drinking some Costa Rican dark roast, and waiting on a delivery.
    I will be working on rejuvenating the weather strip on my doors this weekend, and making plans to change the oil & filter. I also plan to clean out the PS pump, add fresh PS fluid ... then drop the pan, clean the screen and add fresh ATF.
    Should I use Dexron II or III transmission fluid for the PS?
  9. May 29, 2020 at 7:35 AM
    #2799
    Hand Protectors
    Use Valvoline Dex/Merc in both your Transmission and your PS Rez. Cheap and Wallace Wurrld. Good stuff, too. Meets the early 1st gen spec without all the other additives in TypeIV Fluids.
    Take pics of that pan drop! Curious of the debris, or lack there of.
    Tundra2 and Rex Kramer[QUOTED] like this.
  10. May 29, 2020 at 8:31 AM
    #2800
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Cool. Did you already order the gasket for the pan? I'm curious what is used there.
  11. May 29, 2020 at 8:35 AM
    #2801
    Rex Kramer
    Georgia
    I am not doing it myself... my Toyota mechanic will have everything he needs on hand, I will take pictures because I am also curious to see if the screen has captured anything over the past 17 years.
    NUDRAT[OP] likes this.
  12. May 29, 2020 at 8:39 AM
    #2802
    Hand Protectors
    I bet its pretty clean based on others reports. Might have a little sludge on the magnets. Ask your Tech to tighten up the Valve Body Bolts while its open.
    Maybe change out the Solenoids while its open if you want to spend the extra $.
  13. May 29, 2020 at 8:56 AM
    #2803
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Looking into the running board option.
    Again following the PHM model.
    National salvage yard search revealed hits in Ohio, Washington state, and Californication.
    @Professional Hand Model how many mounting brackets per board?
  14. May 29, 2020 at 9:25 AM
    #2804
    Hand Protectors
    I’ll snap some pics and post them in awhile. I had to retrofit these even though I had the factory brackets. You’ll see what I did in the pics. They are super user friendly and very strong.
    Tundra2[QUOTED] likes this.
  15. May 29, 2020 at 10:24 AM
    #2805
    speedtre
    speedtre New Member
    Inland Northwest
    Funny cause it's at least partially true....yea, I know it's more an issue of material quality than design, but some Toyota trucks in the last couple decades have come with some suspect engineering for a truck frames (example, 1st Gen Tacoma's have notoriously weak rear frame sections...if you add any noticeable weight they need to be strengthened)....
    100041791_3378680055475517_4311442159187_c592f24e5a404bcbf7cbb19172c963a755174b85.jpg
  16. May 29, 2020 at 10:26 AM
    #2806
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The frames design seems solid. The big issue is the damn supplier originally. (DANA INDUSTRIES). Look at all the Jeep frame issues and Colorado. All Dana.
    the new frames are made by metulsa. They do indeed seem better (at least all the replacement frames seem to be holding up alright up here. And some of them are over 10 years old now)
  17. May 29, 2020 at 10:52 AM
    #2807
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    When I got a filter, the gasket came with it.
  18. May 29, 2020 at 11:34 AM
    #2808
    Hand Protectors
    Tested the ‘Blank Fuse’ Location on the 2002 SR5. She reads 30Amps without the key even in the ignition. Zzzzttttt! Thats plenty of juice for whoever wants to add shtuff.
    bmf4069 likes this.
  19. May 29, 2020 at 11:49 AM
    #2809
    Hand Protectors
    bmf4069, speedtre and Tundra2[QUOTED] like this.
  20. May 29, 2020 at 11:50 AM
    #2810
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Looks real nice. Sturdy looking too! So 4 per board?
  21. May 29, 2020 at 11:57 AM
    #2811
    Hand Protectors
    Yep. 4 each side. I added the Aluminum Posts for extra strength. Did that after squaring up the install the way it ‘felt’ it should be put in (couldn’t find instructions online). Their is some margin of tweaking and dry fitting along with slight loosening of bolts, sliding brackets, and re-tweaking. Once everything is good looks wise, then tighten her all up and add the support posts with Fuze.
  22. May 29, 2020 at 9:01 PM
    #2812
    empty_lord
    05 rollover special
    just because its pulling 30 with the tester doesnt mean id use it for a 30 amp circuit. 10 amp at most.. you dont want to overload the fuse box and start a fire.
  23. May 29, 2020 at 9:03 PM
    #2813
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    So that’s how I can get a new truck! :)
  24. May 30, 2020 at 10:50 AM
    #2814
    jImmegart
    Jonah
    California
    Im contemplating getting the suspension upgrades I want. But I either have to also spend money on a jack, stands and maybe an impact, or pay someone to do it. Hmmmm decisions decisions
  25. May 30, 2020 at 2:09 PM
    #2815
    Hand Protectors
    Get the jack stands used on where ever. You want 6 Ton stands (they are taller). You can buy a jack at the same place, as well (3 ton).
    Sadly, the Mamba Impact is too big for the leaf work without taking off the bed. Space too tight. Not sure if a short socket will help. You’ll need some kind of Stubby or Angle Impact for this work or take the bed off.
    I’ll be taking my bed off soon to do my leaf work prep as I want to grease up the frame chassis and clean between the cab and bed areas. Might break the nuts with Mamba and come back later to do the leafs with a breaker.
    You’ll be happy on the tools purchases as eventually they pay for themselves. You’ll always have them. Stuff is cheap online used or at garage sales.
    NUDRAT[OP] and jImmegart[QUOTED] like this.
  26. May 30, 2020 at 3:11 PM
    #2816
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @jImmegart I agree with him. Tools are a good investment. Especially at your age. I wish I had been smarter with my tool purchases. Insteading of picking up random things here and there I would have bought sets. Now I have a bunch of random tools that aren't as organized as I'd like.
    NUDRAT[OP] and jImmegart like this.
  27. May 30, 2020 at 3:14 PM
    #2817
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Spent a good hour trying to remove the driver side axle nut today. It's really on there. I even nuked it with my torch. I'm going to have to try Festers suggestion tomorrow.
  28. May 30, 2020 at 3:49 PM
    #2818
    empty_lord
    05 rollover special
    Wedge a thick screwdriver in the canes of the rotor and let it hit the caliper to stop the wheel from spinning.
    Then go
    Ham.
    NUDRAT[OP] and bmf4069 like this.
  29. May 30, 2020 at 3:53 PM
    #2819
    jImmegart
    Jonah
    California
    I see what you guys are saying. Just getting the necessary tools plus all the upgrades is kinda scary price wise. I usually do work at school where i can use lifts and tools for free but not sure when that will be back. Maybe Ill try to split cost with my brother in law
  30. May 30, 2020 at 4:01 PM
    #2820
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Oh I've been doing that. Still no luck. I'll try again in the morning.
