  1. May 23, 2020 at 11:07 AM
    #2611
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Pop the center out of the wheel, bolt it back up, lower the truck, then stand on the end of the breaker bar. If that doesn't work, flip the bar around and put the jack under it.
  2. May 23, 2020 at 11:18 AM
    #2612
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG][​IMG]Parts washer put some work in today
  3. May 23, 2020 at 11:22 AM
    #2613
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm wondering if this breaker bar might break first. I put my entire weight on it and it started to bow. Considering just going to get an impact. May try your suggestion first.
  4. May 23, 2020 at 11:42 AM
    #2614
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Do it.
  5. May 23, 2020 at 11:48 AM
    #2615
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Well. I gave it one more shot and got it. Then I promptly pulled a @bmf4069 and snapped a LBJ bolt. Not quite sure what my next step is.
  6. May 23, 2020 at 12:22 PM
    #2616
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    :eek2:
    Leave the mangling too me!
  7. May 23, 2020 at 12:35 PM
    #2617
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    If they’re machine thread, grab the part that’s exposed and continue it on thru the spindle in the normal direction
    NUDRAT[OP] and Darkness like this.
  8. May 23, 2020 at 12:37 PM
    #2618
    Professional Hand Model
    Hand Protectors
    Double Dose Manglers Club!:rofl:
  9. May 23, 2020 at 12:40 PM
    #2619
    Hand Protectors
    Just get that Milwaukee 2767-20 Impact. It will save a bunch of headaches. @FirstGenVol
    Makes for easy working on stuff.
    NUDRAT[OP] and FrenchToasty like this.
  10. May 23, 2020 at 12:43 PM
    #2620
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Not sure what you mean. This is what I'm working with.
  11. May 23, 2020 at 12:46 PM
    #2621
    Festerw
    Festerw New Member
    04 Tundra DC
    3 choices I see.
    1. Weld a nut on it and turn it out.
    2. Heat it and try to grab it with some vise grips.
    3. Drill it out. Start small and work your way up drilling slowly.
  12. May 23, 2020 at 12:47 PM
    #2622
    FrenchToasty
    Mo
    Bone stock
    I would soak it in PB or kroil, or your choice of penetrant, maybe take a torch to it, and vice grips and try removing it in reverse. You have threads exposed on either side, so you can send it whichever way you want, just send untouched threads whichever way your going
  13. May 23, 2020 at 12:48 PM
    #2623
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Alright. Toyota doesn't stock the bolts naturally. I'm running to Napa to see if they have any. I'll attempt surgery when I return. I don't have a way to weld or a torch. May have to grab one.
    Darkness likes this.
  14. May 23, 2020 at 12:49 PM
    #2624
    Hand Protectors
    Thats Hurtsville right there. Need a torch and some vice grips. If that doesn’t work, might need to drill it out which looks to be at least a 6 carbide tip bits job.
    FrenchToasty likes this.
  15. May 23, 2020 at 12:54 PM
    #2625
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The weird thing is that the bolt was turning. It wasn't stuck. Shouldnt have snapped.
  16. May 23, 2020 at 12:56 PM
    #2626
    Hand Protectors
  17. May 23, 2020 at 12:57 PM
    #2627
    FrenchToasty
    Mo
    Bone stock
    That’s a good thing if it was turning, maybe the tables will TURN in your favor!
    Definitely soak it in penetrant and you could probably work it back and forth, in and out, all nice like; and it would come out relatively easy
  18. May 23, 2020 at 12:57 PM
    #2628
    Hand Protectors
    Maybe the turning was shearing effect?
  19. May 23, 2020 at 12:59 PM
    #2629
    FrenchToasty
    Mo
    Bone stock
    I’ve had that happen on a water pump bolt on my old 2.7l taco, super scary!! But I knew that’s what it was doing, so I stopped, gently went in reverse.....and saved it!!! The bolt felt apart in two in my hand after I removed it, I bought a lotto ticket, nothing exciting followed.
    speedtre likes this.
  20. May 23, 2020 at 1:01 PM
    #2630
    Hand Protectors
    Shearing is tricky, but does have a certain feel once you know about it.
  21. May 23, 2020 at 1:06 PM
    #2631
    FrenchToasty
    Mo
    Bone stock
    Haha me and my dad sheared lots of bolts on my first every vehicle, 88 ford ranger stx package, auto locking hubs, 5speed manual, 3.0l v6(it was a salty wet dog!)
  22. May 23, 2020 at 1:09 PM
    #2632
    Festerw
    Festerw New Member
    04 Tundra DC
    Nothing fancy is needed a propane or mapp one will work just fine.
  23. May 23, 2020 at 1:12 PM
    #2633
    FrenchToasty
    Mo
    Bone stock
    Soufflé would do in a pinch I bet.
  24. May 23, 2020 at 1:36 PM
    #2634
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hate when that happens. Good luck Erik.
  25. May 23, 2020 at 1:57 PM
    #2635
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Napa didn't have the bolts but I got a torch.
    :bananadead::bananadead::bananadead:
  26. May 23, 2020 at 2:17 PM
    #2636
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  27. May 23, 2020 at 2:27 PM
    #2637
    empty_lord
    05 rollover special
    Trust me, my voice isn’t. It’s just how I had the camera lol
  28. May 23, 2020 at 3:15 PM
    #2638
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Man I'm exhausted. Been fighting with the new axle for an hour. Can't seem to tap it into place. Really need a 2nd person to hold while I tap.
  29. May 23, 2020 at 3:24 PM
    #2639
    FrenchToasty
    Mo
    Bone stock
    Use the outer as a slide hammer to gently tap the inner into place, make sure the C clips opening is facing down
    NUDRAT[OP] likes this.
  30. May 23, 2020 at 3:40 PM
    #2640
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Tried that a few times. Most people just tap the metal lip that's past the inner boot. I'm not sure what the issue is but I'm about to call it quits for the night.
    Edit- so tired I can't type.
