  1. Jan 10, 2022 at 4:36 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I follow the rest, but this part…did you over tighten this screw, causing the drum to drag?
  2. Jan 10, 2022 at 4:38 PM
    normally a gm guy52
    normally a gm guy52 New Member
    Good evening everyone, I have a 2000 tundra with the 4.7 and I am pulling what hair I have left out. I cleaned my throttle body over a month ago and ever since then the engine idle is way too high. It wont drop below 1000 rpm and is ruining my new brakes. Anyone have any idea why it would do that and what I possibly did to cause it? I am getting this thing ready for my 16 year old and I dont want to risk him having an accident.
  3. Jan 10, 2022 at 4:40 PM
    alb1k
    Left Coast
    It's good
    All I can say is if the problem started when work was done, the work likely caused the problem. I wish I was more help.
  4. Jan 10, 2022 at 4:43 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Are there any obstructions holding the butterfly open? Did you use anything that may have scraped the throttle body or chip the butterfly? Did you bend the butterfly?
    2000 has a cable operated throttle so that should not need any sort of adaptation ritual after cleaning. Are any cables binding?
    Welcome to the forum
    NUDRAT[OP] likes this.
  5. Jan 10, 2022 at 4:45 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Maybe go back to a GM???
    Did you plug the TPS back in? Can you pull the intake off and verify if the throttle body bufferly valve is closing all the way freely?
    Throttle cable could have popped out of the bracket ‘perch’ if that makes sense
    Jack McCarthy, shifty` and txagg like this.
  6. Jan 10, 2022 at 4:48 PM
    normally a gm guy52
    Not from what I can see. When I take the breather tube off the front of the butterfly it is sprung up a little. I can push it down but it just comes back up.
    It will go down where its supposed to if I unplug my MAF sensor but it runs terrible. I replaced the sensor hoping that was the problem but that didn't work.
  7. Jan 10, 2022 at 4:48 PM
    alb1k
    Left Coast
    It's good
    I’m often there, but a buddy got this for me of the boy. Nice, not a friendly wave.
  8. Jan 10, 2022 at 4:49 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    With the truck off is the butterfly sprung open a bit?
  9. Jan 10, 2022 at 4:53 PM
    normally a gm guy52
    There appears to be no binding in the cable. I can push down on the cable itself and it doesn't move the cam at all.
    Anyway to reset the TPS?
  10. Jan 10, 2022 at 4:55 PM
    normally a gm guy52
    Yes, it is sprung open a little with the truck off.
  11. Jan 10, 2022 at 5:13 PM
    shifty` Inside his chest they found ten thousand pencils
    The big thing is clear after. Doesn't matter if you wipe it on like the 3M kits or spray it on. If you don't clear after, they'll be hazy again within a year.
    FrenchToasty[QUOTED] and alb1k like this.
  12. Jan 10, 2022 at 5:15 PM
    daveeasa
    David
    Now I have to re-read to figure out the proper clear, got tasked with doing the nanny's crappy corolla, hah.
    FrenchToasty likes this.
  13. Jan 10, 2022 at 5:16 PM
    alb1k
    Left Coast
    It's good
    Im hoping you are right, but If I have to re-buff sooner, so be it. These look good on 01/10/21, yew.
  14. Jan 10, 2022 at 5:18 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Hewwwww!
    Darkness and alb1k[QUOTED] like this.
  15. Jan 10, 2022 at 5:22 PM
    FrenchToasty
    Mo
    Bone stock
    Tundra on call. Bat in a bucket, has no one ever trapped a spider and let it outside before?!? Either way, I gave this bat a good dose of justice, and some rice milk, he was on his way into the night! 8CBE1CE3-A37E-4ABA-9062-E0E082C17A4A.jpg56DB9E51-6A5B-4DAA-A495-2E49FDD35BCE.jpg8F961FD0-C682-42A2-8BCF-A55845746B10.jpg
    bmf4069, txagg, des2mtn and 2 others like this.
  16. Jan 10, 2022 at 5:24 PM
    alb1k
    Left Coast
    It's good
    Yes. Wait, you had a bat call? Like Batman?
  17. Jan 10, 2022 at 5:25 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I was the dedicated bat remover when I worked 3rd. People get all worked up about them.
  18. Jan 10, 2022 at 5:26 PM
    FrenchToasty
    Mo
    Bone stock
    Hahah yeah I don’t get it. I really like when we go into RAs rooms or the community directors appts, I’m the known cat lady, haha hey come check out this cat! The last one had 3 legs!
    alb1k and Darkness like this.
  19. Jan 10, 2022 at 5:28 PM
    alb1k
    Left Coast
    It's good
    WTF are you talking about? In english :)
    Darkness likes this.
  20. Jan 10, 2022 at 5:32 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    College campuses are wild. Even more wild at night when you're an employee.
    chrisb, Darkness, bmf4069 and 3 others like this.
  21. Jan 10, 2022 at 5:45 PM
    FrenchToasty
    Mo
    Bone stock
    Hahahah yesssss!
    I had a absolute level 10 black water back up that I was out on, and about 430Am this girl walks in wearing the most see thru clothing, but definitely themed; I wish I knew which direction she came from!
    The day time is still good, but night time, and game day weekends are insane!!!
    RUSTYNUTS, Darkness and des2mtn like this.
  22. Jan 10, 2022 at 5:45 PM
    alb1k
    Left Coast
    It's good
    I was going truetrac, and 4.56 rear.
    Now I'm going e locker and 4.88 rear.
    If I was 4WD, it would be different I think.
    Next tundra for that.
  23. Jan 10, 2022 at 6:33 PM
    alb1k
    Left Coast
    It's good
    That reminds me of a time I still have catalogued. Nuts.
  24. Jan 10, 2022 at 6:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My little brother just showed me a show called roadkill. Man, those guys are wilin the fuck out? How do I get to do this type of shit? Wonderful!
    A fucking off road 1970 challenger? Are you shitting me???
    https://youtu.be/Yx465Mg9pnI
    Darkness and txagg like this.
  25. Jan 10, 2022 at 6:38 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Man you were pretty close a few days ago at that junkyard
  26. Jan 10, 2022 at 6:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'll drink to that!
    Fuck yeah!
  27. Jan 10, 2022 at 6:46 PM
    alb1k
    Left Coast
    It's good
    I do all my body work with a fork lift. Ive always wondered, are those standing burn-outs with front brakes only?
    Tundra2[QUOTED] likes this.
  28. Jan 10, 2022 at 6:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Totally Forgot to grab the correct wires from work for my Harness project. So I guess I’ll continue tomorrow
    alb1k and Tundra2 like this.
  29. Jan 10, 2022 at 6:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hell I don't know on the burn outs. At TG we had a Lexus sedan cab, and a tacoma cab. They had me move those outside when I was taking my break from the forum. They to me they were going to sell them for scrap metal.
    I was outside for at least an hour tearing them things up with the Komatsu. Fun times!
    alb1k[QUOTED] likes this.
  30. Jan 10, 2022 at 7:10 PM
    Bats are a common source of rabies in the US. Both through scratches and bites. Rabies is pretty brutal way to die and 100% fatal if you don't catch it super early, I don't mind handling bats, but I think a lot of 'normal' folks probably don't want that risk. :rofl:
    I have similar task with a Yarris waiting for me.
    The Cerakote kit I think comes with clear.
    But if you need it, 3M makes this a brainless process. I didn't believe you could get a good clear out of a wipe, but these are good for at least 1-2 years. I've used them quite a few times now, Advance Auto Parts carries them but so does scAmazon. Two different packages, same stuff.
    Tundra2 likes this.
