  1. Dec 22, 2021 at 12:12 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    If i want an extra 300 lbs on the back of my truck it’ll be a thick steel tube bumper full of mineral oil, with a pump and some spray nozzles.
    NUDRAT[OP], bmf4069, Darkness and 3 others like this.
  2. Dec 22, 2021 at 1:09 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    :bananadance:
    TRDGen likes this.
  3. Dec 22, 2021 at 1:19 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    To spray the back tires for showin’ off my burnouts! Promise.
    Darkness likes this.
  4. Dec 22, 2021 at 1:25 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I think a better use of 300lbs of cargo would be banana peels to tactically distribute in traffic.
  5. Dec 22, 2021 at 1:32 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Ive seen the wiggle gif of the 2nd gen. Theres no fixing that. Might as well start over.
    i pick up more than 300 lbs anytime i find a pile of tree or fence.
    makes my truck ride like a cadillac.
    NUDRAT[OP], bmf4069 and Darkness like this.
  6. Dec 22, 2021 at 1:50 PM
    daveeasa
    David
    I realize I’m obsessed.
    these feel nice. Not the right color but I got them cheap to experiment with before I take the real plunge. Very tempting after feeling them in my hands.
    Maestro harness is bare wire so it’s mostly a matter of the spiral cable as far as complexity goes? Then finding a proper wheel and airbag cover and see if my existing airbag fits or I need a new bag too?
    80955B65-4D2F-4E4C-B34E-DA16522E316B.jpg 4CB239FA-584D-4AE5-83E8-815656CD7DE6.jpg
    chrisb, Sirfive, TRDGen and 1 other person like this.
  7. Dec 22, 2021 at 2:10 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  8. Dec 22, 2021 at 2:49 PM
    daveeasa
    David
    Photo of the TRD decal. It’s hard to see the black on black. A thin red outline could be just right. I’ll think about it. Or a white or all red TRD if I can find one like this.
  9. Dec 22, 2021 at 3:27 PM
    alb1k
    Left Coast
    It's good
    Looks pretty sweet to me.
  10. Dec 22, 2021 at 3:44 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I think a red outline or white outline would set it off
  11. Dec 22, 2021 at 3:46 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Once you have wheel controls you'll never want to go back
    shifty` likes this.
  12. Dec 22, 2021 at 4:04 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @TRDGen did you ever post pics of the Terminator?
    TRDGen likes this.
  13. Dec 22, 2021 at 4:13 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Not really. First thing I did when i got it home after having to jumpstart it 6 times in 60 miles was remove the grille for some serious rehabilitation. 3 of the tabs that hold the bolts that hold the grille to the hood were broken and the nuts were seized. I need to remove those nuts so I can get the remains of the tabs and do some serious surgery to preserve the grille. The paint on the truck is in bad shape, especially the tail gate where it looks like it's been rattle canned. I've got a remanned alternator I'll be installing sometime in the next 2 weekends or so. Will be my first time doing one and my first time doing the belt myself too. I've also got some 05-06 tails ordered and a new inner driver door handle and console latch ordered. I need to order the T3 bedside decals because they peeled off according to PO. I did run the VIN and it is legit T3 though.
  14. Dec 22, 2021 at 6:10 PM
    I didn't want to be the guy to say it, but I tend to agree. I would like it, but the outer rim is too thick. If it was half as thick, I think I'd absolutely love it.
    36gal of water is roughly 300lb. Didn't someone used to make water bags 'bed bags' or similar for just this purpose?
  15. Dec 22, 2021 at 6:15 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    any one done this that could help me out?
    Also, my cheapo underseat subwoofer just crapped out. Nothing else is NOT working though so I don't think I need to check any fuses. I did check the fuse at the battery for the sub and it's fine but no power light on the sub...guess I gotta get another. I did only pay like $78 for it or something 3 years ago.
  16. Dec 22, 2021 at 7:28 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Is there an internal fuse on the amp? Maybe check for power and ground at the amp just to be sure. Got a link to whatever model it is?
    NUDRAT[OP] likes this.
  17. Dec 22, 2021 at 7:32 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  18. Dec 22, 2021 at 8:20 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I cut my airbag cover when I installed mine. Turned out pretty well, if I may say so.
    https://www.tundras.com/threads/06-dc-daily-driver-2wd-to-4wd-conversion.48447/#post-1259892
    daveeasa[QUOTED] likes this.
  19. Dec 22, 2021 at 8:27 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Well I tugged on the ground wire inside the eye connector and it moved a bit. I looked a little more and the connector was completely split. I replaced it and it all works as it should. Thanks for the basic tips!
  20. Dec 22, 2021 at 8:36 PM
    PenderBen
    2003 Tundra AC 4x4
    Awesome, always nice to find when it’s an easy fix :thumbsup:
    CodyP[QUOTED] likes this.
  21. Dec 22, 2021 at 8:55 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yup…1 issue down, 1 to go! I can’t figure out for the life of me how this rear fold down cup holder is removed!
  22. Dec 22, 2021 at 9:00 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Go on..........
    FrenchToasty likes this.
  23. Dec 22, 2021 at 9:10 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I like the subtlety.
  24. Dec 22, 2021 at 9:35 PM
    daveeasa
    David
  25. Dec 22, 2021 at 10:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  26. Dec 22, 2021 at 10:34 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    http://www.headlightservices.com/Wiring.html
    txagg[QUOTED] and FrenchToasty like this.
  27. Dec 23, 2021 at 8:05 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    What the hell is going on in here today?
    Everyone on vacation already?
    shifty` and FrenchToasty like this.
  28. Dec 23, 2021 at 8:12 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'm going to an office party today. Wonder if I'm going to get that performance review I was supposed to have two weeks ago.
    (also didn't have one last year)
  29. Dec 23, 2021 at 8:15 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yep, paid time off for university wide shut down, until Jan 3
    NWPirate, TRDGen, FirstGenVol and 3 others like this.
  30. Dec 23, 2021 at 8:17 AM
    FrenchToasty
    Mo
    Bone stock
    At our job, they can’t give us “too good” of a review, because that would mean more paperwork, followed by a raise.
