  1. May 17, 2020 at 9:40 AM
    #2461
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Thought of something: using the whole can of seafoam through intake is a waste, most of it is already ran through your system before you have a chance to use the rest of the bottle. So today I'm going to just use half the bottle.
  2. May 17, 2020 at 9:44 AM
    #2462
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I used the offset socket. My advice is to run it and then try to change them about 30 minutes later. If it's only been 6 years you shouldn't have much issue removing them with the socket and breaker bar.
    The problem I always have with RA is the shipping. Usually by the time that's added Amazon or local stores are nearly the same sometimes cheaper especially when you're ordering multiple/heavy parts.
    I used the Aisin kit, 35k so far with no issues
  3. May 17, 2020 at 10:28 AM
    #2463
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well. I can have these for free... I’m tempted to make the 2200 mile drive
    [​IMG] [​IMG]
    Darkness, bmf4069, Tundra2 and 2 others like this.
  4. May 17, 2020 at 10:32 AM
    #2464
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I did indeed use crows foot. My Napa friend lent me his set that had various types to choose from. Getting O2's out was not really that bad....unplugging them was the bitch with the tight space Toyo engineers gave us. Didn't help that it was colder hell that day and ith thin blood, I looked like a blood soaked fem teenager who learned the facts of life for the first time.
  5. May 17, 2020 at 11:07 AM
    #2465
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    What's for lunch guys?
    Throwing down some chicken sausages and grilling onions. Gonna use Hawaiian rolls as buns.
    bmf4069, NUDRAT[OP], speedtre and 3 others like this.
  6. May 17, 2020 at 11:11 AM
    #2466
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Just tore up a publix sub. My Floridians know bout that life!
    DaBoro54, Tundra2, NUDRAT[OP] and 2 others like this.
  7. May 17, 2020 at 11:23 AM
    #2467
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Chicken mozzarella and herb sausages with grilled sweet onions (heavily seasoned with garlic salt and pepper) on Hawaiian rolls.
    Burning my mouth but so worth it
  8. May 17, 2020 at 11:42 AM
    #2468
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Sir, the correct term is PubSub.
  9. May 17, 2020 at 4:32 PM
    #2469
    Professional Hand Model
    Hand Protectors
    Went out to Coots Place on the Island, but he was closed.
    chrisb, TX-TRD1stGEN, bmf4069 and 2 others like this.
  10. May 17, 2020 at 4:42 PM
    #2470
    Hand Protectors
    My pump was leaking for about a year before I took her in for a timing belt. Pink crustys developed on the underside with the occasional sweet smell of coolant wafting about.
  11. May 17, 2020 at 4:49 PM
    #2471
    Hand Protectors
    Good points. Lots of extra work and time to flush the coolant system versus just filling and sending after the new belt and pump go on. I think thats what happened after my belt change by others. The coolant looked like butt after a year after the belt change. They put in a new radiator a year later and used green OAT coolant (another fail). Our trucks need Phosphated coolant (Pink) to offset the chemical reactions going on between Aluminum heads and Iron Block.
  12. May 17, 2020 at 6:40 PM
    #2472
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Why all the rust in the front left - is that leaky battery syndrome?
  13. May 17, 2020 at 6:45 PM
    #2473
    NUDRAT
    SW CT
    I don't see no picture... ???
  14. May 17, 2020 at 7:18 PM
    #2474
    empty_lord
    05 rollover special
    I think it has to do with where the frame was stored. No clue. No big deal.
  15. May 17, 2020 at 7:38 PM
    #2475
    NUDRAT
    SW CT
    Agree, looks superficial, just oddly concentrated.
  16. May 18, 2020 at 12:47 AM
    #2476
    Hand Protectors
    NUDRAT[OP] likes this.
  17. May 18, 2020 at 3:57 AM
    #2477
    Hand Protectors
    Need advice on the o2 sensor clips removal. Been reading to squeeze the top clip and pull.
    Read some others say to slip a flat head between the two connectors and slightly twist the flat head and pull the connectors apart.
  18. May 18, 2020 at 4:30 AM
    #2478
    Festerw
    Festerw New Member
    04 Tundra DC
    It has to be pushed down towards the center of the connector, take a look at the new one and you'll see what I mean. Try pushing the connector together and then pushing down. Sometimes they get hung up on the mating piece and don't like to release.
    You may be able to use the screwdriver twist to help push it down but be careful about it.
  19. May 18, 2020 at 4:36 AM
    #2479
    Hand Protectors
    So push the outer sleeve bump tab down (while pushing the connectors together) so that it releases the inner connector tab mating. If this doesn’t work, then gently try the flathead insertion technique.
  20. May 18, 2020 at 5:53 AM
    #2480
    Festerw
    Festerw New Member
    04 Tundra DC
    Sounds correct. I also pulled the whole connector off of the mount it's on to see it a little better.
  21. May 18, 2020 at 6:05 AM
    #2481
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Sometimes it felt like I was pushing the release tab but couldn’t tell if I was lifting it enough to clear the nub. Maybe push the tab and if you can see the keeper lift, then you know where to shove a small screw driver. The screw driver makes for one hand pull out usually. It would be hard to push the screw driver to far, just make sure it’s small enough, but still wide enough to encompass that nub so the catch can slide over it
  22. May 18, 2020 at 6:26 AM
    #2482
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Looks like brake fluid may have leaked from master.
  23. May 18, 2020 at 8:45 AM
    #2483
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My 13 year old earned his own money to buy one of these after you posted it. He's been driving it for a few weeks and absolutely loves it! I'm amazed at how well it's built and handles. Super fun!
    Darkness[QUOTED] and YardBird like this.
  24. May 18, 2020 at 4:07 PM
    #2484
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Thinking about buying this '93 pickup, for absolutely no good reason. Not for a daily driver or winter use, just to putz around with and do hardware store runs and haul $hit around my property... and maybe teach my teenager to drive a stick. Bad idea or good idea? Any reactions to asking price? Any fatal flaws on these things? I assume a southern CO car will have minimal frame rust, but I will look ...
    https://cosprings.craigslist.org/cto/d/fountain-1993-toyota-pickup/7126430524.html
    bmf4069 and imDementeD like this.
  25. May 18, 2020 at 5:09 PM
    #2485
    Hand Protectors
    Got jealous of everyones Wildlife Stories from the other day. Took a few shots of Igor and Matilda nesting up near the Northern portion of the South Coast. They are Variegated Wild Turkeys that have adapted to living on the water. A rare sight.
    bmf4069 likes this.
  26. May 18, 2020 at 5:57 PM
    #2486
    Dog
    Dog sit!
    22re
    theBIGnaud[QUOTED] likes this.
  27. May 18, 2020 at 6:00 PM
    #2487
    FrenchToasty
    Mo
    Bone stock
    Dude yes! I’m not sure which motor it’s got, but hell yeah!
  28. May 18, 2020 at 6:09 PM
    #2488
    Dog
    Dog sit!
    22re
  29. May 18, 2020 at 6:35 PM
    #2489
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Cool. For that price I like your reasoning.
    FrenchToasty likes this.
  30. May 18, 2020 at 9:39 PM
    #2490
    empty_lord
    05 rollover special
    Started pulling apart the engine I got the same time as my tundra. Came from a 1997 4runner that rolled after hitting a wall. There’s fucking glass everywhere
    [​IMG] [​IMG] I’m replacing all the gaskets. Reseal the whole thing and give it a good once over before putting it in the 01 Tacoma to test out camshafts from a Camry and some other things
