  1. Dec 9, 2021 at 5:42 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Good morning team!
    I went into 4WP last night and talked about tires.
    They strongly recommended the MT Baja Boss AT over everything else on my list. (what I was hoping for, but did not hint at to get as honest a recommendation as possible)
    I asked them about the Cooper Rugged Treks and they said they're still so new (and uncommon) that they don't really have any basis for comparison. Best I can tell, they just don't sell them so they don't see them.
    So those are the two I'm down to.
    So here's the primary differences:
    -The MTs are 33x12.5x17
    -The Coopers are 285/70r17
    -The MTs are about $200 more
    -The MTs are 8lbs per tire heavier
    -The Coopers are load range E
    -The MTs are load range D
    -The Coopers are sourced through work from TireRack
    -The MTs are sourced through work from 4WP
    To my inexperienced brain, the MTs are the way to go. Softer sidewalls and rowdier looks make me feel like I'll be happier. But my racecar brain is absolutely shitting its pants at +8lbs per corner.
    Any insight here is hugely appreciated.
    Cummins3500 and des2mtn like this.
  2. Dec 9, 2021 at 6:21 AM
    NGL, when I saw that 8lb add per tire, I immediately thought, "yeah, screw that, don't need to bother looking at any other numbers..."
    Tough call. Maybe I'm overreacting. It's only 16lbs of added rotational weight across the rear axle, but ... Meh.
    chrisb[QUOTED] likes this.
  3. Dec 9, 2021 at 6:44 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thanks for this. I'll try to get a peek into everything tomorrow.
  4. Dec 9, 2021 at 7:23 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Now that i have daylight, it looks like the rear trans line goes to the top port of the cooler. Maybe someone could verify.
  5. Dec 9, 2021 at 7:28 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    fun fact, MT, Dick Cepek, are both subsidiaries of Cooper Tire.
    If you're set between those two, I'd go the Coopers. the $200 price differential, and the fuel economy you'll gain with the 32lbs less rotational mass will be worth any negligible performance differences.
    NUDRAT[OP] and chrisb[QUOTED] like this.
  6. Dec 9, 2021 at 9:18 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    bmf4069 and chrisb like this.
  7. Dec 9, 2021 at 9:32 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Never throw nothin’ away. Pile it into a hoard, and you’ll never want for anything.
    NUDRAT[OP], bmf4069 and alb1k like this.
  8. Dec 9, 2021 at 10:31 AM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    Looking to replaces my OEM leaf springs as they are starting to splay a lot and the bushings are looking pretty shot. Currently I have Bilstein shocks all around and I am sitting level since I went 2 clicks up on my fronts. I am planning to go to 33s and will be getting new to new OME springs to get rid of my front preload. (looking for information on which front springs to get if I'm planning to go with BFF or COR front bumper) I do not tow or have lots of weight in the rear.
    What kind of leaf springs can I get so I am level and don't have to (Add a Leaf ) And I don't want to be ass high with really tough leaf springs. Found this website I just don't understand Leaf spring weight calculations
    https://www.generalspringkc.com/leaf-springs/toyota/tundra/2000-2006/
    Which OME springs should I get for Heavier front bumper ?
  9. Dec 9, 2021 at 10:34 AM
    Yeah, and it's much easier to explain why you're riding coopers than it is riding dicks! :rofl:
  10. Dec 9, 2021 at 10:40 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    This is really confusing to me. But I would figure out your front, then move to the back. I'm on my third leaf pack counting OEM to get where I wanted (partly because I came to realize I needed MD springs). Regardless, get your front set, and you will have a better idea what level or slight rake will require.
    Sirfive and chrisb like this.
  11. Dec 9, 2021 at 11:27 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I went with the 2885 springs on my bilstein 5100s bottom notch. Oem front bumper and don’t plan to change.
    I think you’d want the 2886 at least with a steel bumper
  12. Dec 9, 2021 at 11:57 AM
    04 Tundra
    Albert
    Hahaha didn't mean to confused with OEM VS OME and I was trying to see what ppl did since I know a lot of guys do 886 fronts and AAL in the back which I'm trying to avoid.
    Leafs have to changed asap front is in the near future....... bad position I guess .
    alb1k[QUOTED] likes this.
  13. Dec 9, 2021 at 12:00 PM
    Kauaitundra1
    Kauaitundra1 New Member
    2000 TRD Tundra limited 4x4
    Was it running ok? My truck runs fine for a month now at least. Just those codes.
    How did you find out the gasket was cracked? Is there a test or you gotta open it up?
  14. Dec 9, 2021 at 12:16 PM
    alb1k
    Left Coast
    It's good
    Well, if you have to do rears first, that's OK. You can go stock height, which puts you roughly level with a 2-2.5 lift up front. That's only level until you load it though, then you squat. Now you are looking at AAL or something. Or get springs built 1.5"-2" over, that rake empty but perform better with weight. My point is, level is only level when empty, unless your springs are so stiff they ride like crap, or you have add-ons to help. It took me a while to figure out what I wanted my springs to do and how to get there. Spring height is only part of it.
    dinosaur likes this.
  15. Dec 9, 2021 at 7:32 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I could hear hissing from under the intake, so it was sucking in unmetered air causing it to run lean. It definitely wasn't running right. It idled like shit and backfired through the intake. To check your IM gasket, you have to listen, then pull the intake if it's suspect.
  16. Dec 9, 2021 at 10:10 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Potential power adder. Will experiment once I have one for the mr2, but based off displacement and hp, the Frankenstein Motorworks MAF pipe may actually make gains if VF tuner allows maf tunning. 3.5 gets like 15-20hp gains from it. Hmm
    dinosaur, chrisb and FrenchToasty like this.
  17. Dec 9, 2021 at 10:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Dec 9, 2021 at 11:56 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  19. Dec 10, 2021 at 12:48 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Did you get the info you needed on this or not? I can take a gander on my truck when I get home if need be. My skid plate is off at the moment.
  20. Dec 10, 2021 at 1:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Partial info. More pics please. Thanks Nick!
  21. Dec 10, 2021 at 4:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pops and mys last morning in the maintenance office together.
    Kinda sad, but kinda not. More scared now than when I agreed to the new job.
    I'm still learning at my current employer, but I'm learning more about the old ways. The ways that aren't the future of this industry. I've got one hell of a grasp on the mechanical side of things, but that's 98% of what I'm learning here.
    I want to know more about PLCs, and programming. As automation becomes more, and more prevalent in the industrial setting. That will eventually be the ticket to better jobs. Even an introductory course would be better than what I've got now.
    In essence, what I'm saying is I'm comfortable here because I know 98% of the usual problems, and am crafty enough to bull shit my way through the other 2%. Due to my shift, I'm not learning new things here because of the culture here. I'm excited to learn, and have always been vocal about that. Unfortunately, it's fallen on deaf ears...
    Walking into a completely different industry with a completely different set of requirements without a general understanding of the process is scary. I've seen the inside of the plant, and met the maintenance guys on 1st. They seem like good, genuine people. Dirty clothes, and hard workers like me. The maintenance team lead said that he would personally take care of me as far as educating me to be better for them. I hope those aren't empty words because I know I'm going to need help the get started...
    All I need is a push, and some guidance.
    I'm not quite sure where exactly I'm going to end up in life, but I know that my current plan will ensure future jobs should it prove to be what I was told it is..m
    I'm nervous. I'm scared. I'm leaving being the senior guy on shift to the very bottom of the ladder. I'm okay with that, but it's still scary.
    I tried to make a "time capsule video" but I kept getting off track...
  22. Dec 10, 2021 at 4:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I understand that feeling. I was the same way starting here at my new job in October. You got this. Your drive and experience will show and they'll be glad they hired you. What shift are you gonna be working?
    RUSTYNUTS, shifty`, dinosaur and 6 others like this.
  23. Dec 10, 2021 at 4:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I knew you'd understand.
    They haven't decided yet for sure which makes me nervous... they told me 2nd or 3rd eventually, but there should be a short training period on days.
    bmf4069[QUOTED] likes this.
  24. Dec 10, 2021 at 4:21 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    These factories literally run 24/7?
    We don’t have much like that out here besides maybe the power plant.
    Tundra2[QUOTED] likes this.
  25. Dec 10, 2021 at 4:23 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    95% out here are continuous operations. 25/8.
    The other 5% are day shift only, and you have to know somebody to get on board there.
    chrisb and FrenchToasty[QUOTED] like this.
  26. Dec 10, 2021 at 4:24 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Also, @bmf4069 thank you for the kind words. I hope you're right!
    I'm a little frazzled at the moment...
    alee891, FrenchToasty and bmf4069 like this.
  27. Dec 10, 2021 at 4:24 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I literally made myself sick in the weeks leading up to and making the decision. After I told my boss I was nervous the whole time during my 3 week notice. When I actually started here I was excited and nervous. Since then, I've found where I fit in the machine and enjoy going to work. More hours, more pay, more benefits. In the end it was a win/win.
  28. Dec 10, 2021 at 4:31 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Today is the only day I've felt sick, so I completely get where you're coming from there. I hope I find my place quickly. Won't be totally grasping in the dark, but it's damned close to dusk, I tell you h'what.
    RUSTYNUTS and bmf4069[QUOTED] like this.
  29. Dec 10, 2021 at 4:57 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    In my experience as a leader (official and non), I have always done my very best to hire good people who want to work and want to learn.
    You can teach anyone the skills they need to do most jobs.
    You can't make them good people or give them the desire to work.
    My interviews were never from a form, and didn't really focus on work. They focused on the person being interviewed and then about myself. I wanted to hire people I could count on and get along with. The job was always secondary or tertiary.
    My hope is that this is how your new company is.
    And even if it isn't, they'll quickly learn what sort of man you are and you'll be a-ok.
    I went through last November what you're doing now. Left as a the subject matter expert and lynchpin of my department to become the FNG in an entirely new field. Here I am a year later and I am oft lauded as the best in my department.
    What I'm trying to say is that it's more about the worker than the work. I have full confidence you'll succeed at anything you put your mind to.
    RUSTYNUTS, shifty`, bmf4069 and 5 others like this.
  30. Dec 10, 2021 at 4:59 AM
    FrenchToasty
    Mo
    Bone stock
    Agreed
    RUSTYNUTS, chrisb[QUOTED] and Tundra2 like this.
