  1. Dec 6, 2021 at 3:36 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    There's a guitar thread?
    w666 and Darkness[QUOTED] like this.
  2. Dec 6, 2021 at 5:12 AM
    Jack McCarthy
    Bill
    North of Boston
    Pulled the trigger on buying the Milwaukee M12 compact 1/2" impact driver kit (batteries, case and charger) for $220 at Home Depot.
    Considering the reliability of UPS/FedEx lately, I'm having it delivered to the store. Hopefully, I won't be disappointed with its performance. :fingerscrossed:
    It's either that or setup a 2-stage IR upright compressor in my living room. That might be cool, but I'm not exactly wired for 220V except at my washer/dryer and water heater.
  3. Dec 6, 2021 at 5:32 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    you’ll really like the impact tool it makes easy work. i just used mine this weekend on wheels removal doing some fluid bleeds on a honda. i’ve used it on many other things to and it’ll crack anything. never broken a bolt yet as it has a sensor feedback to prevent such things. only negative is the thumb reverse is to easy to switch into forward which isn’t good if you aren’t paying attention.. J.P.
    TRDGen, bmf4069, dinosaur and 2 others like this.
  4. Dec 6, 2021 at 5:34 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thumb reverse is easy to swap. Sometimes handy, sometimes not. Lol
    I've swapped over intentionally, and it still drive the wrong way. Only on the 1/4 hex impact I dropped 60 feet out of a lift though...
    bmf4069 and Jack McCarthy like this.
  5. Dec 6, 2021 at 6:01 AM
    Jack McCarthy
    Bill
    North of Boston
    I'm guessing the 200-250 ft-lbs of torque it produces may not be enough for exhaust manifold bolts, but anything larger in size probably won't fit in the engine compartment, so I'll most likely have to borrow a pneumatic impact wrench instead if/when I choose to tackle that.
  6. Dec 6, 2021 at 6:08 AM
    Kauaitundra1
    Kauaitundra1 New Member
    2000 TRD Tundra limited 4x4
    I have codes for all cylinders misfire, so thats p0300-p0308. I also have a rich code bank 1, p0172.
    The truck runs fine 99% of the time. Occasionally it will shut off at low idle, usually about to park it.
    I have new fuel filter, new MAF sensor, 8 new platinum plugs, all denso ignition coils (4 brand new to replace cheap chinese ones), clean air K&N filter, and clean throttle body.
    I ran my computer to verify the O2 sensors functioning. I got normal sin wave pattern between 0 and 1. I understand that to mean they are working.
    I replaced the engine about 5 years ago with a refurb, came with about 50K miles. This is a 2000 Tundra with 190K and I have no idea what may need to be replaced with normal wear and tear. Maybe old vacuum lines? I live in Hawaii, lots of sand, salt and heat. I am second owner.
    Anyway I trying to keep this thing solid so any ideas what could make these codes? Maybe failing fuel injectors? Evap. Canister? PCV valve? Fuel Pressure regulator?
  7. Dec 6, 2021 at 6:16 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Jack McCarthy[QUOTED] and w666 like this.
  8. Dec 6, 2021 at 6:53 AM
    Timing? With the engine being swapped out, a bit of a Pandora's box. Everything is suspect due to the missing 50k miles of history for the motor. Who did the engine swap? Maybe they can help shake it out with you.
    dinosaur likes this.
  9. Dec 6, 2021 at 7:22 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Fuel pressure was my first thought. I think you’re on the right track.
  10. Dec 6, 2021 at 7:26 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I would guess metering or ignition. (air leak or spark plug or COP)
    The rich condition is from unburnt fuel. So either the truck is injecting too much (would be reflected in MPG immediately) or it's not consistently able to burn what is injected. (worn plugs or coils...or both)
  11. Dec 6, 2021 at 10:06 AM
    daveeasa
    David
    Re: my Jura, randomly stumbled on the invoice while stashing some printed documents, it was (is) a J5 purchased 3/28/2011 as factory refurb. I have a photo somewhere that one of the guys upstairs sent me showing the teardown he did to fully clean it. It was $899 at the time plus $30 shipping. I definitely enjoyed it for a few years.
    shifty` likes this.
  12. Dec 6, 2021 at 10:08 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    damn you. I need a flathead in my life.
    Tundra2[QUOTED] likes this.
  13. Dec 6, 2021 at 11:01 AM
    daveeasa
    David
    A friend recently closed off his garage attic for storage with plywood. The garage is ventilated but the new garage attic is not. Any opinions on the options for
    1. add a vent to the exterior (front wall so visible from the street above garage door)
    2. Cut a hole into the house attic (which is insulated)
    location is inland north county San Diego, some pretty hot summers and a little bit of cold but not severe winter.
  14. Dec 6, 2021 at 1:54 PM
    Punk1974
    J.P.
    it should do it and you’ll need a boat load of extensions and wobble bits of all types along with twisty bits the kind that bite and grab in reverse. need special e10 torx bit for the studs.. the big boy milwalkie impact with extensions and wobbles will do it all from the wheel well and out..
  15. Dec 6, 2021 at 2:14 PM
    daveeasa
    David
    Another question, speed freak jason mentioned if I do a front locker I should also do new axles up front? And that everyone goes with one specific axle? Anyone have a suggestion there so I can get out ahead of that one? Or should I say screw it to the front locker? Hmm...
  16. Dec 6, 2021 at 2:16 PM
    Jack McCarthy
    Bill
    North of Boston
    So I wouldn't need a stud extractor socket if I spin a nut off? An e10 torx will grab it? Interesting.
    After I looked at what was involved on a 1A auto video, it doesn't look i could get an impact to every exhaust bolt especially around the motor mount on the drivers side. Seems like more right angles are needed to get in there to the nuts which would require a breaker bar and socket instead. I haven't tried putting together wobble sockets and swivel extensions to make a 90 degree angle though.
    Some as you say could be done with a long extension and an impact on the passenger side though.
    Punk1974[QUOTED] likes this.
  17. Dec 6, 2021 at 2:33 PM
    Punk1974
    J.P.
    bottom line is be prepared for every combination and then some. buy stuff and return it if you dont use it. some people cut there manifolds off and then remove the bolts which is another trick using a sawzall an special ax milwalkie blade. dangerous.. but faster than motor mount removal..
  18. Dec 6, 2021 at 5:02 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Unless you're planning to go full crawler or have money to burn, I wouldn't even lock the front. Locking the front will just lead to even more 4wd binding and that will lead to broken CVs. Which is probably why he said get new CVs (as spares). I wouldn't bother swapping your CVs if they don't need to be swapped (aren't broken or boots shredded, popping etc.) Unless you're planning to get high angle CVJ CVs to go with long travel suspension. Or at least mid travel with the sway bar removed. Also Napa and a few other autopart stores have lifetime warrantees on their CVs and give discounts on new sets if you bring in a core (or broken CV). I've been running Napa on my truck for about 2 years now with no issues so far and I abuse my shit at least 2 or 3 weekends a year
    chrisb, dinosaur and daveeasa[QUOTED] like this.
  19. Dec 6, 2021 at 5:04 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Not a T100
    NWPirate, NUDRAT[OP] and FirstGenVol like this.
  20. Dec 6, 2021 at 5:07 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Someone just had this issue recently and fixed it. @bmf4069 @MrDirtjumper
  21. Dec 6, 2021 at 5:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    chrisb and TRDGen[QUOTED] like this.
  22. Dec 6, 2021 at 5:21 PM
    daveeasa
    David
    I was thinking to get myself out of mud/snow type stuff more than rock crawling. Still a horrible idea? Even with new axles? Seems like it'd be nice to have a locker if used responsibly? Maybe it's just dumb...
    TRDGen[QUOTED] likes this.
  23. Dec 6, 2021 at 5:21 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Just saying, it's listed as both an 87 T100 and pickup. But T100 was only from 93-98 and never came with such straight lines or sealed beam headlights (I wish they did though)
  24. Dec 6, 2021 at 5:22 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Not a horrible idea at all. Just depends on your needs and your bank account brother lol
  25. Dec 6, 2021 at 5:40 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    TRDGen likes this.
  26. Dec 6, 2021 at 6:07 PM
    shifty` Inside his chest they found ten thousand pencils
    Hard to beat that price, you could stuff nearly any drivetrain in it. That paint is single stage also, will buff out shiny as hell with a good orange cutting pad, basic polishing compound (you can skip buffing/cutting compound if you use aggressive enough pad) and some elbow pain.
    I'd probably be stupid enough to buy this. It's hard to ignore a mostly rustless truck under $1k, regardless whether it's running.
  27. Dec 6, 2021 at 6:58 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    You want some level of fire stop from garage to house. I would not vent into house. Front vent or cut in a ridge vent.
    daveeasa[QUOTED] likes this.
  28. Dec 6, 2021 at 7:00 PM
    daveeasa
    David
    Great point. If he cut he’d likely have to drywall the ceiling for fire suppression. I remember getting harassed about that on my rental property when I sold it. Keen eye for detail.
    NUDRAT[QUOTED][OP] likes this.
  29. Dec 6, 2021 at 7:24 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I've been looking at the smaller models, all I want is espresso. No need to beat my milk :D
    Hopefully we can get through the cow manure that is building code and move on to greener pastures, mi casa es su casa. I'm a city boy and know nothing about fishing and boats but I'm looking forward to figuring it out but please bring a helmet, I will crash more than once :D.
    Since I'm here, I'll park this right here for you guys to figure out the quality of the crack this guy has been smoking.
  30. Dec 6, 2021 at 7:39 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
