  1. May 14, 2020 at 7:12 PM
    #2401
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Ok thanks. Again it is like a weird loose feeling. And it makes a clunking/rattling noise too. It feels like its coming directly behind the steering wheel. Also it is 100 percent prominent when driving down an old rough gravel road. It feels horrible.
    lsaami[QUOTED] likes this.
  2. May 14, 2020 at 7:41 PM
    #2402
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Have someone rock the steering wheel back and forth while you watch the different components in the steering system. If it’s a prominent rattle, you’ll likely see the play in the culprit part.
    chrisb and NUDRAT[OP] like this.
  3. May 14, 2020 at 8:48 PM
    #2403
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Get that thing in the air soon. It can be tie rod or ball joint related.
    you do not want EITHER failing it will end badly
  4. May 14, 2020 at 9:31 PM
    #2404
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    I have been having the same lately. I need to climb under tomorrow and give it a check
  5. May 14, 2020 at 11:33 PM
    #2405
    jImmegart
    Jonah
    California
    Is upgrading to a hellwigs front swaybar worth it? Or is it about same as stock
  6. May 15, 2020 at 3:44 AM
    #2406
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I did the upgrade but also did a bunch of stuff together so not sure the impact this had but it's definitely a more robust sway bar
  7. May 15, 2020 at 3:55 AM
    #2407
    Professional Hand Model
    Hand Protectors
    Well worth it! Makes street driving super fun. Keeps the inside wheel down in a slow 90° turn. During highway speed lane changes, it makes them snappy and precise.
    Hellwig 7700 is the bar. It has three settings holes. Start with the loose setting first and you’ll notice a big difference. I moved it up to the middle setting after some time and love it. My truck has the OEM front sway bar also.
    Also, it helps tremendously with towing and hauling.
  8. May 15, 2020 at 3:58 AM
    #2408
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I agree 100% concerning the rear bar, but what about the front?
  9. May 15, 2020 at 4:05 AM
    #2409
    Hand Protectors
    Not sure your question, but my truck came with a front bar. The rear bar makes a huge difference. Never drove with the front bar off with just the rear on.
  10. May 15, 2020 at 4:06 AM
    #2410
    Hand Protectors
    You just sent Pucks into hyper-anxiety worry mode. Code Red!
  11. May 15, 2020 at 4:16 AM
    #2411
    Rex Kramer
    Georgia
    The previous poster asked about upgrading the front by replacing the factory bar with a larger Hellwig bar, TRD offers the same option for 2nd gen trucks. I have left my front bars factory.
  12. May 15, 2020 at 4:21 AM
    #2412
    Hand Protectors
    Thanks for the correction. Yeah, my front swaybar links rusted off and I drove it around like that for a few years from 2014-2018. Truck wobbled around turns similar to a boat turn. A shop rebuilt the front end and reconnected the dangling front bar with new links. She drove much better. The rear addition months later was even better. Survey says: Get both!
    Rex Kramer[QUOTED] likes this.
  13. May 15, 2020 at 5:34 AM
    #2413
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Based on the videos I'm seeing, it looks like I don't have to touch the tie rod.
    The axle nut requires 173ft lbs torque spec. My brand new torque wrench only goes to 150lbs. You think I can get by going by hand after that, or should I go invest in another torque wrench?
  14. May 15, 2020 at 5:50 AM
    #2414
    Pucks18
    Lmao. I am pretty sure my ball joints are good. But still, my cortisol is through the roof now!
  15. May 15, 2020 at 5:52 AM
    #2415
    Pucks18
    I usually lick my wrench handle, about 3 times and once my hand slips off of it once thats about 60ftlbs for me. Its a pretty accurate way tbh. So do that like 3 times bro, trust me
    bmf4069 and chrisb like this.
  16. May 15, 2020 at 5:53 AM
    #2416
    Pucks18
    Will do
  17. May 15, 2020 at 6:24 AM
    #2417
    Pucks18
    Yo i just watched chris dicks coolant flush video (chris fix) and this dude flushed it with straight up water.wouldnt that wreak havoc on your water pump and seals? I hear most jdms are very specific about what coolant to use and using water for even 10 minutes sounds like a really stupid idea
  18. May 15, 2020 at 7:15 AM
    #2418
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Go buy a new one. The torque on your axle shaft set the preload on the wheel bearing, without the correct torque you'll wear out the bearing prematurely. The parts stores have them as loaner tools also.
    FirstGenVol[QUOTED] likes this.
  19. May 15, 2020 at 8:47 AM
    #2419
    empty_lord
    05 rollover special
    Eh. Your pretty close just nudge it a bit
    More. But ideally you want it 165-180
    bmf4069 likes this.
  20. May 15, 2020 at 9:00 AM
    #2420
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    We are hoping my wife is allowed to WFH permanently as well. She prefers the quiet here vs the [needy & dramatic] office environment.
    I don't make it a habit of licking my tools. I'll give this a try next time I'm really fighting something that's tight.
    Unless your engine is full of raw, solid sodium, I can't imagine water doing anything at all (let alone bad) in 10 minutes.
    I'm reasonably sure all coolant has water in it...sans Evans Waterless.
  21. May 15, 2020 at 1:08 PM
    #2421
    Hand Protectors
    I flushed my heater core with the garden hose as it has no bottom plug to let the gookies out. I then ran copious amounts of the Zerex Pink via the Borneo Blow Dart Technique.
    chrisb and TX-TRD1stGEN like this.
  22. May 15, 2020 at 2:20 PM
    #2422
    Hand Protectors
    @FirstGenVol here are a few pics from the archives to help you picture where the bolts are located on the headers/shields. Its tight in there for sure.
    Also included, from the archives, is the steering column bushing caulk repair.
    FirstGenVol and imDementeD like this.
  23. May 15, 2020 at 6:13 PM
    #2423
    speedtre
    speedtre New Member
    Inland Northwest
  24. May 15, 2020 at 6:34 PM
    #2424
    empty_lord
    05 rollover special
    Ehh. It’s not that bad of a job
  25. May 16, 2020 at 4:45 AM
    #2425
    Hand Protectors
    I’m beginning to think everything is not as hard as it seems when working on the truck. Most of the battle is having the PROPER parts before hand along with the right tools. Most everything is plug and play on repairs with some small degrees of retro fit. I need to get over my suspension hurdles, though.
  26. May 16, 2020 at 5:26 AM
    #2426
    Hand Protectors
    So after a week of meditations about these short tube headers, I have become very enlightened and at the same time a little hesitant on doing them due to reports of not really any gains in performance.
    This morning, after finishing my second cup of Italian Dark Roast, I’ll be crawling under the truck for the first time in many moons for a deep inspection of:
    1) Manifolds (as much as can be easily seen).
    2) Y-Pipe
    3) o2 Sensors
    4) Front Brake Caliper Bolt markings.
    I need to also inspect drivers rear wheel drum to confirm/deny stealers warranty work from a few weeks back. Might drop my spare tire and do some touch up painting.
    On another day, based on a theory, I may try to just re-torque the OEM manifold nuts after removing the shields for a true inspection. If I find some real problems/cracks/leaks, then its new header time. Currently, I have no exhaust ticks/weird noises/or fumes coming from engine bay. I do remember having the engine tick circa 2005-07 but I ignored it and it went away after a few years. :notsure:
  27. May 16, 2020 at 5:40 AM
    #2427
    Rex Kramer
    Georgia
    Leave the factory manifolds alone if they aren't cracked & ticking.
    The only reason I have JBA shorties on my truck is because they were direct bolt on replacements, and they cost a lot less than replacing the cracked factory manifolds with new factory manifolds would have cost... I didn't replace them for a power gain. All that being said, I do enjoy the little boost in low end power they give me, and they seem to also enhance peak power in the highest RPM ranges.
  28. May 16, 2020 at 6:13 AM
    #2428
    :thumbsup:
    speedtre[QUOTED] likes this.
  29. May 16, 2020 at 6:18 AM
    #2429
    Pucks18
    @Jim LE 1301 "you ever change a cam tower on a turd gen ;)"
    NUDRAT[OP] likes this.
  30. May 16, 2020 at 6:24 AM
    #2430
    Nope
