  1. May 11, 2020 at 4:25 AM
    #2341
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Happy monday, to the working men and woman of the usa.if we are slow at work today i will spend the majority of my day going through every page of the "what have i done "thread and getting ideas for mods
    NUDRAT[OP], FrenchToasty and bmf4069 like this.
  2. May 11, 2020 at 5:14 AM
    #2342
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Skinny has crossed my mind
    speedtre[QUOTED] likes this.
  3. May 11, 2020 at 5:45 AM
    #2343
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    If you want another rabbit hole to go down, in the 1st gen section, somewhere, there’s a thread “must have mods under 100$” or something like that, CIO(check it out)
    Tundra2 and NUDRAT[OP] like this.
  4. May 11, 2020 at 6:31 AM
    #2344
    Pucks18
    Im seeing a trend of people with the limited trims with the fake wood grain blacking out the "wood grain". I'm sorry but why? I totally think it looks way better then the black center piece by the radio and the window controls. Lol
    jImmegart and Tundra2 like this.
  5. May 11, 2020 at 10:27 AM
    #2345
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm pretty sure it got put in the info dump page.
  6. May 11, 2020 at 10:28 AM
    #2346
    empty_lord
    05 rollover special
    Honestly with the black dash, if I can find the wood piece I’m probably doing
    Tundra2 likes this.
  7. May 11, 2020 at 6:02 PM
    #2347
    Professional Hand Model
    Hand Protectors
    Pit crew today checking out my really really good looking suspension.
    chrisb, bmf4069, Jerry311SD and 2 others like this.
  8. May 11, 2020 at 6:14 PM
    #2348
    empty_lord
    05 rollover special
    All i see is ducking off going on there
  9. May 11, 2020 at 6:41 PM
    #2349
    FrenchToasty
    Mo
    Bone stock
    Probably a mother duck!
  10. May 11, 2020 at 7:50 PM
    #2350
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    I have the black TRD Sema wheels - I like 'em. A little less offset (i.e stick out farther) than OE rims. I am running 265/70/17, very pedestrian.
  11. May 12, 2020 at 5:19 AM
    #2351
    Pucks18
    I'm doing a brake fluid change, but i was just gonna buy whatever the auto parts store has in stock and change it once a year. Is it really that big of a difference? I'm doing a simple suck it out of the reservoir and put fresh in. Not flushing
  12. May 12, 2020 at 8:28 AM
    #2352
    Pucks18
  13. May 12, 2020 at 8:32 AM
    #2353
    Hand Protectors
    You should do a 32oz. flush with DOT3 (cheap!) and that will push all the existing dirty old fluid out. I’d then follow up with one can of El Fluido Supremó 5.1 and push out all the newer DOT3. Double flush! Gotta flush it with the brake pedal pumps using another person. Or, you could get some high dolla self bleeders and do it yourself.
  14. May 12, 2020 at 8:47 AM
    #2354
    Pucks18
  15. May 12, 2020 at 11:01 AM
    #2355
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Bleeding brakes is super easy. Even I didn't fuck that up. Everything else yes, but not the brake bleeding.
  16. May 12, 2020 at 1:46 PM
    #2356
    Hand Protectors
    Its easy. I was a bit scared myself after finding out that brake fluid is slightly caustic and might hurt my hands. Once you do it the first time its easy which is why I recommend doing the DOT3 first. Get your practice in on the inexpensive stuff. My fluid was slightly gnarly and believe I bleed them a total of 3 times before getting the Supremó stuff
    First time was a regular bleed. Second was after doing new flex brake hoses. Third was after a rebuild of calipers and rear cylinders. I then bled them a forth time to purge all the cack/rubber grease from rebuild and introduced the Supremó 5.1.
    Even into my second bleeding when doing the flex hoses there was a little bit of bad mojo coming out.
  17. May 12, 2020 at 5:20 PM
    #2357
    Pucks18
  18. May 12, 2020 at 6:04 PM
    #2358
    Hand Protectors
    We have nothing to fear, but fear itself. Winston Churchill or FDR?
    Make it happen! Worst thing that could happen is that you re-bleed the brakes again if air gets in there. Might cost you $9 for another DOT3 bottle 32oz. :notsure:
  19. May 12, 2020 at 6:13 PM
    #2359
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    What climate are you in? I can tell you I'm not bleeding mine until something needs replaced.
    I've replaced a handful of calipers after snapping off the bleeder during a brake job and nearly every wheel cylinder. It's not worth the aggravation if you're someplace they salt roads.
    NUDRAT[OP] likes this.
  20. May 12, 2020 at 7:04 PM
    #2360
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    kroil/PB and a 1/4 drive ratchet with 6-point socket. We live that real salt life here in Indiana just like you guys in PA do.
  21. May 13, 2020 at 4:52 AM
    #2361
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  22. May 13, 2020 at 5:42 AM
    #2362
    Pucks18
    I live in the good ole suburbs of chicago. So a shit ton of salt, and this truck was orginally from MA. So yea prob not doing it, will just replace the reservoirs fluid. I have learned a few lessons of if it aint broke dont fix it. Obviously you want to do preventative maintenance but i will just hold off on this one for a while. My fluid as far as i can see is very clean still.
    Festerw[QUOTED] likes this.
  23. May 13, 2020 at 5:43 AM
    #2363
    speedtre
    speedtre New Member
    Inland Northwest
    chrisb likes this.
  24. May 13, 2020 at 5:50 AM
    #2364
    FrenchToasty
    Mo
    Bone stock
    My favorite pictures are the hideous gold color matched front bumper, and the lady with her welding helmet on; and socks and tevas
    bmf4069 and Rex Kramer like this.
  25. May 13, 2020 at 5:54 AM
    #2365
    Rex Kramer
    Georgia
    Agreed, and that's why I chose the one I did.
  26. May 13, 2020 at 6:25 AM
    #2366
    speedtre
    speedtre New Member
    Inland Northwest
    CodyP, lsaami and bmf4069 like this.
  27. May 13, 2020 at 6:28 AM
    #2367
    ezdog
    ezdog New Member
    Gateway To The West
    Doesn't it make you wonder exactly how they offer bumpers for the Tundra but have no pics of any on one?
    chrisb and Rex Kramer like this.
  28. May 13, 2020 at 6:44 AM
    #2368
    Pucks18
    Hey guys im thinking about replacing my rear bumper. Its rusty af. I might sand it and repaint it imperial jade but its missing a small chunk on the side of the bumper. So ive been looking at chrome replacement ones, how exactly would i install this? It doesnt look like i have to take the bumper off of the frame, it looks like it just kinda gets clipped back into my bumper frame. Is this the way to go or should i buy a whole new rear bumper? Im clueless on how the installation would go. Thanks
  29. May 13, 2020 at 8:38 AM
    #2369
    Hand Protectors
    Way harder and time consuming than brake bleeding! Be scared of this one as replacing that rear bumper is harder than it looks! All those Northeast salted and rusted brackets and bolts will haunt you. You’ll wish you bled your brakes instead of doing the bumper. :rofl:
    bmf4069 and FrenchToasty like this.
  30. May 13, 2020 at 8:43 AM
    #2370
    Pucks18
