  1. Nov 19, 2021 at 3:43 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'm in DC though so I'd imagine an AC would get a little more height.
  2. Nov 19, 2021 at 3:58 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    https://www.tundras.com/threads/how-big-is-yours-measure-up.46186/
    shifty` and Darkness like this.
  3. Nov 19, 2021 at 4:16 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I just put 885s on the front of the truck last weekend.
    My measurements are all good for nothing until I unfuck the carolina squat I've got going on. (...which will be as soon as FedEx unfucks themselves and brings my new rear springs)
    bmf4069, Darkness and TRDGen like this.
  4. Nov 19, 2021 at 4:55 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Which springs you get? I want some flexier rear springs. The stock pack with progressive AAL and overload removed is ok for wheeling. But could always be better.
  5. Nov 19, 2021 at 4:57 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    So when you first start the truck it should be the same as your wt or close to it, it should slowly rise and not see any up or down fluctuations. On the freeway unloaded I’m usually between 150-170ish, if I’m loaded and haulin ace; closer to 190-192
    do you have a v3 of their scan gauge?
    Darkness and TRDGen[QUOTED] like this.
  6. Nov 19, 2021 at 5:21 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I bought stock replacements from ATS and AAL from Skyjacker. (~2")
    Won't be as flexy as a progressive, but that's not a top priority for me at this time.
  7. Nov 19, 2021 at 5:55 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    V3? I have an older SG2 and a brand new one. I'm still breaking in the new one on the Tundra. The older ones going in the T100. It's been super mild weather here lately and a cold front just blew in so trans temps have stayed pretty low so far. Scangauge just sent me the new xgauge for the A750 trans temp yesterday for me to try
  8. Nov 19, 2021 at 6:15 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm ready to craft memes for you
  9. Nov 19, 2021 at 8:52 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    There you go
    bmf4069 and chrisb[QUOTED] like this.
  10. Nov 19, 2021 at 8:56 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    FOR
    REAL
  11. Nov 19, 2021 at 9:36 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Man I opened the guitar box this morning to allow more air passage. Sonofabitch its a box within a box. I pulled that box out and its all taped up, not sure how humidity will balance in a sealed box. I slit the top open to let it breathe. Wasn't expecting that.
  12. Nov 19, 2021 at 9:44 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    @Darkness Did they put any silica in it to help? I would only worry if the package was colder than the room and would cause condensate to form. You're probably okay since it's not vacuum sealed anyway.
    chrisb likes this.
  13. Nov 19, 2021 at 10:10 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Happy Fri-yay :bikewhoops:
  14. Nov 19, 2021 at 11:02 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I had an 01 AC with no extra weight up front and mine eventually settled at 24. Higher than most and when I took it in to toytec to look at it they said the 1st gens vary a lot for whatever reason. Mine was on OME shocks.
  15. Nov 19, 2021 at 11:06 AM
    rock climber
    That sounds low. I've had 3 first gens
    01 AC - 160-180
    01 Sequoia 120-140
    06 DC 170-180
    I'm trying to figure out why the sequoia temp is so low. First thing I'm going to check is see if the PO bypassed the radiator cooler, the external cooler is there.
  16. Nov 19, 2021 at 11:15 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Had to open it to find out hahaha. Just opened it up, first inspection all looks fine. Action is lower than expected and I'm amazed that it can be this low. Plays super easy, barre chords are no effort at all. I'll post some pics later today in the guitar thread.
  17. Nov 19, 2021 at 11:19 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I’m back, baby.
    NWPirate, NUDRAT[OP], bmf4069 and 6 others like this.
  18. Nov 19, 2021 at 11:23 AM
    Jack McCarthy
    Bill
    North of Boston
    That's what separates the cheap guitars from the good ones. The good ones you expect it, the cheaper ones are hit or miss.
  19. Nov 19, 2021 at 11:27 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Care to explain this to us laypeople?
    bmf4069 and Tundra2 like this.
  20. Nov 19, 2021 at 11:35 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    action height refers to how close the strings are to the fretboard. the lower the action, the easier to play and/or push the strings down, but the more likely you are to have buzzing and intonation issues.
    high quality guitars can sound really good and have zero intonation or buzzing issues with an extremely low action, cheaper guitars struggle.
  21. Nov 19, 2021 at 11:56 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    This one is surprisingly affordable. I spotted it at an online retailer for $345, the retailer I prefer was able to match that price (regular $429). Outstanding deal with free shipping. I went ahead and asked them to do the setup and strings for $70 to offset their discount a bit. Glad I did that.
  22. Nov 19, 2021 at 12:15 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Excellent description.
    Thank you.
    Glad to have you back.
  23. Nov 19, 2021 at 12:50 PM
    shifty` Inside his chest they found ten thousand pencils
    Guitars: The one place you don't want to catch a lot of action. It might leave you fretting.
    NUDRAT[OP], bmf4069, chrisb and 4 others like this.
  24. Nov 19, 2021 at 12:54 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have one big problem now. I won't be playing my Taylor acoustic that cost twice as much. I might have to lower the action on that, for some reason I'm afraid to do it. On my Les Paul no biggie but intonation is easy to fix, different story on acoustic.
  25. Nov 19, 2021 at 12:59 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Yew!
    FrenchToasty and Darkness like this.
  26. Nov 19, 2021 at 1:24 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I let my dog out and took a quick pic for @bmf4069 and @Jack McCarthy
    I'll clean it up and get better pics if the sun comes out.
    Tuners could have been aligned better but doesn't bother me. Color and finish are sweet.
    "I don't see what you're excited about"
    FirstGenVol, bmf4069, Sirfive and 4 others like this.
  27. Nov 19, 2021 at 1:27 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    pretty. How’s it sound?
  28. Nov 19, 2021 at 1:35 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Cool, but what kind of candy did you get?
    chrisb, Tundra2, shifty` and 2 others like this.
  29. Nov 19, 2021 at 1:48 PM
    Jack McCarthy
    Bill
    North of Boston
    Nice! So why the Guild in addition to the Taylor? I haven't made the changeover so I'm not familiar with the acoustic sounds from the different makes.
    Darkness[QUOTED] likes this.
  30. Nov 19, 2021 at 1:51 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I need to play it more indoors, I played for about 10 minutes outside. Sounds clean, wasn't getting as low as expected but I was being gentle on it and maybe indoors it will have more thump. I felt clumsy while trying to get used to the action, its so much lower than my others. I'll play it more after work and post better pics in the guitar thread if I can.
    A lot of people knock the Chinese built guitars but so far I think this is on par or very close to my Mexican built Taylor that cost 2x as much. Frets are clean and polished, no sharp edges, all nicely filed. So far the joins look clean and tight. Only qc thing I noticed was the tuners being a little crooked.
    The usual stuff, but I don't recall getting Smarties before.
