  1. Oct 25, 2021 at 2:22 PM
    shifty` Inside his chest they found ten thousand pencils
    Now I mounted my hands-free mic at the edge of my cluster trim where I'm talking straight at it, I've reduced the number of wires I need to take up across the headliner.
    I've been mulling over my install. Thinking about taking a single run up and terminating at an ACC + IGN + GROUND block above my sunglass/map light unit. This way, if I ever had a rear-facing cam, I can tap to the block. When I want to finish wiring the mirror, tap to the block. Just need to find something low profile that'll work. Would also allow me to take one step at a time, at my own leisure, instead of trying to find 2-3 hours time to knock it all out at once.
    I'll probably send up a spare pair with it too, in case I want to retrofit for temp later.
    Tundra2[QUOTED] likes this.
  2. Oct 25, 2021 at 2:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hey, wait a minute. The shit-rolet has an auto dimming mirror with compass and temp readout.
    Will need to investigate compatibility. :pccoffee:
    NUDRAT[OP] and daveeasa like this.
  3. Oct 25, 2021 at 2:24 PM
    daveeasa
    David
    The Intel I have from Bob the mirror guy is that temp + homelink v4 is the unobtainable holy grail. Hence I’m stuck with v3 for now if I want temp.
    Tundra2 likes this.
  4. Oct 25, 2021 at 2:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Homelink is for garage doors? No use currently, but maybe in the future.
    I just want auto dimming really. Corolla has a temp reading on the instrument cluster, but it's always been a few degrees off either way. It changes its mind more than some people change underwear.
    bmf4069 likes this.
  5. Oct 25, 2021 at 2:31 PM
    Uh. Anything is "compatible", you just need about 12" of harness from the donor, plus the concealment plate, and that's about it. All of GM and Honda's stuff uses the same window keystone as others.
    Swap yours into the GM now. Maybe you can snake the temp wiring. GM is what some other people used here.
  6. Oct 25, 2021 at 2:43 PM
    ** from our era, I mean
    Tundra2 likes this.
  7. Oct 25, 2021 at 6:41 PM
    BTW, I just wanted to confirm that the exterior ambient temp sensor for GM was actually a 2-wire setup. A couple of the guys on fleabay like Boost-Parts here in ATL are selling a kit with the GM mirrors and using the GM temp sensors to get the reading, it appears. Looks like the GM p/n is 25775833 if you wanted to look it up. Amazoan has pretty good pics.
    I presume all Gentex mirrors would use similar ambient temp sensors, rather than custom-make your mirror for every manufacturer, but I guess you never know.
    @daveeasa does your mirror w/temp have a 2-wire sensor? Any intel on the p/n on that sensor?
  8. Oct 25, 2021 at 6:48 PM
    daveeasa
    David
    Still waiting on the invoice. I decided I like Bob of bobs mirrors because he is chock full of knowledge. So I’d rather do as he advises and pay a bit more than make decisions on my own. I’ll let you know once it’s here.
    NUDRAT[OP] and shifty` like this.
  9. Oct 25, 2021 at 10:03 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Amen
  10. Oct 26, 2021 at 1:53 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Anyone ever tried the VLEDs H4s in our trucks? Pops said the V6 has a headlight out. Not against another katana set, but they lasted a year, and a day with occasional driving.
    V6 has been on standby with maintenance drives since may.
  11. Oct 26, 2021 at 2:28 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Drivers side headlight on the V6.
    And now drivers side headlight on the corolla
    Lol
    NWPirate and bmf4069 like this.
  12. Oct 26, 2021 at 7:52 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Needs more headlight fluid.
  13. Oct 26, 2021 at 12:24 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Dear tundras,
    Anything you can do i can do better.
    but like any real full size truck, its a bitch in tight parking spots. But has a much tighter turning radius.
    bmf4069 and Tundra2 like this.
  14. Oct 26, 2021 at 1:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hate to admit it, but that's pretty neat. Now weld both doors together, beef up the front door hinge, and have one Huge super door on each side.
    bmf4069, Jack McCarthy and chrisb like this.
  15. Oct 26, 2021 at 1:13 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    fixt
  16. Oct 26, 2021 at 1:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ooh. That's much better than what I had going on in my brain.
    :bowdown:
  17. Oct 26, 2021 at 2:23 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I sure do miss my Regular Cab Tundra.....
    Sirfive[QUOTED] likes this.
  18. Oct 26, 2021 at 2:26 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Lol “i should call her”. A joke ac tundra guys would think is funnier than it is.
    RUSTYNUTS likes this.
  19. Oct 26, 2021 at 2:38 PM
    Jack McCarthy
    Bill
    North of Boston
    @Sirfive It should be even faster if you just take all the doors off along with the tailgate and just put netting there instead.
  20. Oct 26, 2021 at 8:53 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Found this mean s.o.b. He was ~ 4ft in length.
  21. Oct 26, 2021 at 9:23 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  22. Oct 26, 2021 at 10:09 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Uhh. Are we calling a frontier a full size truck now?
    Jack McCarthy and RUSTYNUTS like this.
  23. Oct 26, 2021 at 11:29 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looks like a Titan to me but I don't pay much attention to any Nissan truck other than hardbody.
    FrenchToasty, chrisb and bmf4069 like this.
  24. Oct 27, 2021 at 1:04 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Ive gotta go back to driving the titan until i fix my cv boots and get some front diff bushings.
  25. Oct 27, 2021 at 3:45 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Y'all keep talking about outside temp in the mirrors. Here a pic of my 30 year old taurus:
  26. Oct 27, 2021 at 3:49 AM
    18" TRD Off Road Wheels
    Look at you and your fancy electric antenna. Not all of us are as baller as you, ok? :oops:
    Lil Steve, chrisb, NWPirate and 2 others like this.
  27. Oct 27, 2021 at 3:51 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think mine is broke and stuck down anyways. :rofl:
  28. Oct 27, 2021 at 3:52 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Cold outside...
  29. Oct 27, 2021 at 5:56 AM
    Where I come from, that's called dinner. Some good eatin' right there.
    Jeebus man, how about we talk about that pile of dust on your vent? You actually breathe in the air coming out of that thing? :rofl:
    bmf4069[QUOTED] and FrenchToasty like this.
  30. Oct 27, 2021 at 5:58 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve never eatin one, but they get turned into a lot of belts and hat bands around here. My old ladies grandpa used to make jewelry out of the vertebrae
    shifty`[QUOTED] likes this.
