  1. Oct 16, 2021 at 10:10 AM
    That's not beer, and it's about time! (congrats!!)
    Told you so! :D Felt kinda like you were making a mountain out of a molehill on this one, but I get it. Next step: Set a goal to move your next part over from one of the other SHOs? Fo shol.
    That's probably only a 1-beer(water) job. GIT R DUN![/quote][/QUOTE]
    bmf4069[QUOTED] likes this.
  2. Oct 16, 2021 at 10:26 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    [/QUOTE][/QUOTE]
    I think the next goal is getting the rod shifter sitting in the back seat swapped in. Then a complete front end rebuild. I also need to get the other one drivable, then do the rod bearings.
  3. Oct 16, 2021 at 10:42 AM
    Remind me the condition of the three again, you're looking to get two of them running, or just make one supercar, then sell the other two off as parts?
  4. Oct 16, 2021 at 10:49 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I kept it around 20mph and really tried to baby it. I already knew from past experience that my transmission gets real hot in 4HI while going slow. I tried both and it cooled down in 4Lo. The issue there is that I could only go so fast in 4Lo. This was the first time I've seen coolant temps get over 195 even in the summer so it surprised me.
  5. Oct 16, 2021 at 2:39 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    The one I fixed has a semi good black interior, but a shit body. Rust free, 3.0 from CA with an egr system. Mostly stock. The other 91 has a trashed tan interior, but clean exterior. Semi rusty from Indianapolis, 3.2 no egr. Lots of mods. But, it needs rod bearings. The 92 hasn't ran in 11 years, but has a $1200 lsd in it, and a few rare parts. I'll make 1 really nice car, one ok car, and the 92 will be parted.
    Also, my plans changed on what's next. A dude offered to air up my tire (it leaks) at his shop across the street from where we were getting beer if he could check out the SHO. I agreed and went to air it up. I looked underneath and saw this:
    Looks like tires are next for me. I'm gonna go from 225/40zr18 to 235/45zr18 to get the speedometer a little more accurate. Stock size is 215/60r16.
  6. Oct 16, 2021 at 4:51 PM
    NWPirate
    Zach
    WA
    Thinking about these for the Sequoia when I do the lift and front end rebuild. You're running these right @empty_lord? Any other feedback on these would be appreciated.
  7. Oct 16, 2021 at 4:56 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    They make replicas with better offsets and wider. 7” is pretty narrow if your airing down or running wider tires
    NWPirate[QUOTED] likes this.
  8. Oct 16, 2021 at 4:57 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I also realized they’re different brands, I was just talking about the missing part, and wondered what happened to it, like hopefully it didn’t get left somewhere that it could cause more problems. That’s all. Carry on
  9. Oct 16, 2021 at 5:29 PM
    NWPirate
    Zach
    WA
    Thanks, yeah I thought 7" was pretty narrow. 0 offset is what I'm leaning towards.
    @Cummins3500 mind sharing your wheel specs on both rigs?
  10. Oct 16, 2021 at 5:46 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    @NWPirate
    Tundra is running :
    16x8 method 304’s, 4.5 inch backspace w/ 0 offset. Plus 1.25in spidertrax wheel spacers. 285/75/16 general grabber x3’s
    sequoia is running:
    17x8.5 Kmc technics, 4.75 backspace w/ 0 offset. 275/70/17 falken wild peak at3w’s
    I’m pretty sure fn wheels have replicas with better specs than the oem Toyota’s.
    https://www.fnwheels.com/store/product/fn-wheels-fx-pro/
    NWPirate and FrenchToasty like this.
  11. Oct 16, 2021 at 5:50 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Went for a nice hike the other day. Boys found lots of salamanders on the way up and down.
    Grifola Fondosa; hericium genus
    FCF06F94-ADC5-4923-865E-AEF25A5F9910.jpg AC8FE7A2-1260-45D9-B61E-DE6A071900E7.jpg
    HBTundra, bmf4069 and FrenchToasty like this.
  12. Oct 16, 2021 at 5:51 PM
  13. Oct 16, 2021 at 5:54 PM
    YUM. Hen of the woods and Bearshead tooth! Someone eating good tonight. Nice find!
  14. Oct 16, 2021 at 6:01 PM
    MEWaters
    MEWaters New Member
    Maine
    Then three large hens were a little old so I left them. I did grab the hericium, though
    FrenchToasty and shifty`[QUOTED] like this.
  15. Oct 16, 2021 at 6:03 PM
    NWPirate
    Zach
    WA
    Awesome, thanks man.
    :hattip:
  16. Oct 16, 2021 at 6:30 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    my coolant temps got higher and replacing my radiator fixed it.
  17. Oct 16, 2021 at 6:32 PM
    Cummins3500
    Logan
    no problem :thumbsup:
  18. Oct 16, 2021 at 6:34 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’m 177-184 consistent. 180 is the ideal engine temp for any engine with an iron block
  19. Oct 17, 2021 at 7:21 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    6k seems a little steep if it does need a trans. If nothing else you could take a look at it and see.
    shifty`[QUOTED] likes this.
  20. Oct 17, 2021 at 12:59 PM
    Kinda what I was feeling too. Figure if it needs trans and is 2WD, 4k is more appropriate. Looks like the rear driver side dent around the gas door is limited to the bed and nerf bar, but wasn't so stoked about that once I noticed it. Otherwise body looks nice. I may reach out. Still mulling.... Would prefer a '00-'04 2WD Taco with same mileage and PW/PL.
  21. Oct 17, 2021 at 2:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Went to O-boro to check out a door for crackie.
    Door was in nice shape on the outside. Door panel was still good. Door check been completely ripped out. Wiring harness cut, and hinges cut off the donor truck. No rust on the door shell though.
    Bummed about the door check. Almost scooped it up anyway to sell for parts here, but decided to pass.
  22. Oct 17, 2021 at 2:14 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    NWPirate likes this.
  23. Oct 17, 2021 at 2:46 PM
    NWPirate
    Zach
    WA
    That song hits good. :fistbump:
    What's the build going to be?
  24. Oct 17, 2021 at 6:52 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Owensboro is home to a famous motorcycle racer I was a fan of, his nickname was "The Kentucky Kid". Sadly he was killed while training in Italy in 2017. I was fortunate enough to have seen him race a few occasions and even met his mom.
  25. Oct 17, 2021 at 9:51 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Love Hayden. And Marco. Sad they both had short lived lives.
  26. Oct 17, 2021 at 10:05 PM
    Lil Steve
    Gilbert, AZ
    The best race I've ever attended was the 2005 MotoGP at Laguna. Nicky winning and then giving his dad a lap around the track afterwards was priceless.
    Darkness, Sirfive, alee891 and 3 others like this.
  27. Oct 18, 2021 at 12:19 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    So cool
    Tundra2 and Lil Steve[QUOTED] like this.
  28. Oct 18, 2021 at 11:20 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ive been worried about how late this plant decided to yield but this looks promising. At least 18 so far and the heart isn't fully developed yet, I may see as many as 36 if it goes well. Sounds like a lot but these are a small variety.
    NWPirate, bmf4069 and FrenchToasty like this.
  29. Oct 18, 2021 at 11:42 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    My banana plants have always died after producing banana's. Will yours do the same?
    Darkness[QUOTED] likes this.
  30. Oct 18, 2021 at 11:48 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    This is something I want to experiment with this time. Last year my plant stopped growing after and my mother in law said its dead, cut it before it rots. So I did. I had others.
    Recently I met an old Filipino guy and while looking through his garden I noticed a thick banana plant that was around 5' tall and had a cluster of bananas on it. No leaves at all. I got the impression he may be chopping the top off and keeping it alive to harvest again, but the language barrier kept his secret. I need to have my wife translate for me.
    Worst case, this plant produced almost a dozen other plants, and I have several types in my yard. If I have to cut this one down, no biggie.
    Jack McCarthy likes this.
