  1. Oct 13, 2021 at 10:23 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Anybody got the fix for Fox coil overs handy? I figure I’ve got better chance finding them in stock than I do anything else. The sequoia is needing a set, and I don’t really figure I’ll find king or ads in stock anywhere. Ads would be preference though
  2. Oct 13, 2021 at 10:26 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I've got a friend with an NA drag beetle that carries the front wheels as far as he wants. It gets rebuilt instead of oil changes.
    I guess the sliding scale of 'reliable' is the real determining factor in cost...with deference to the skill/experience subtable. :D
    The beetle we ran around in in HS was very mild and generally reliable...in the regard that it always got us home. (Not always firing on 4cyl tho)
    Agree to disagree, unless we're specifically talking about beetle engines. Even then, consider aircooled engines are all head-studded and oft more akin to radial engines than automotive engines. (architecture, not layout)
    The Porsche 930 came with 100hp/L from the factory and can be coaxed into significantly more power without opening the engine at all. The subsequent 964 turbo and 993tt made even more hp/L.
    The problem with FI and a beetle is packaging. The tight packaging constraints add additional challenges to dissipating/shedding all that heat. The pressure is NBD.
  3. Oct 13, 2021 at 10:46 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    My xb9r toes the line with 92hp @ 984cc. 11:1 cr makes alot of heat. The 1200’s only put out 103hp.
    wiki said the 930 made 300hp with 3300cc. And intercooled turbos help, but to a limit.
    like you said, torn down and rebuilt, instead of oil changed and probably running on alcohol or methanol.
    What do you think they could get out of this after an hour of heatsoak?(starts to sing just before 2:00)
    https://youtu.be/dLDQlydaqlI
    KarmaKannon and Jack McCarthy like this.
  4. Oct 13, 2021 at 11:02 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    This is where the beauty of modern technology can come in to play.
    With coatings and materials and modern management, durability is significantly improved. I'd be hard-pressed to speculate about actual output decreases with heat soak. Too many variables to consider.
    I can tell you if they convert that lil guy over to a 911 fan, it'll get much better at dissipating heat. The 11 blade fans move so much air. And being magnesium and not very wide, they don't cost too many horsetorques to keep spinning.
    Sirfive[QUOTED] likes this.
  5. Oct 13, 2021 at 11:55 AM
    Cummins3500
    Logan
    Never mind I found what I needed on the Fox coil overs. Now to find somebody with em in stock/ shortest wait time
  6. Oct 13, 2021 at 3:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Seen this on my commute.
    Darkness, bmf4069 and KarmaKannon like this.
  7. Oct 13, 2021 at 3:35 PM
    daveeasa
    David
    @memario1214 worked magic for me.
    Unfortunately I’m still blocked on UCA and rear everything.
    Cummins3500[QUOTED] likes this.
  8. Oct 13, 2021 at 3:40 PM
    Damn G he giving you the stinkeye. Wtf?
  9. Oct 13, 2021 at 3:44 PM
    Cummins3500
    Logan
    which coil overs you end going with?
  10. Oct 13, 2021 at 3:45 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Gotta get lucky once in a while!
    I absolutely can't promise anything, but if you PM me some part numbers I can certainly poke around and see if I can find anything :notsure:
  11. Oct 13, 2021 at 3:53 PM
    Cummins3500
    Logan
    Pm inbound
    daveeasa and FrenchToasty like this.
  12. Oct 13, 2021 at 3:57 PM
    daveeasa
    David
    I’m not super sure. At one point I had the 5 digits memorized. I’m vaguely thinking 864 for last 3? I’ll check.
    definitely not 864, hah. My memory does not work.
  13. Oct 14, 2021 at 11:05 AM
    Cummins3500
    Logan
    Hey if I ordered a set of kings I’ve found in stock for my wife’s sequoia, part # Code: 25001-138 will I be messing up? It’s to replace a spacer lift or should I go with part Code: 25001-138-EXT?
  14. Oct 14, 2021 at 11:10 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I found fox smoothies at downsouthmotorsports when nobody else had them. Worth a shot.
  15. Oct 14, 2021 at 11:11 AM
    alb1k
    Left Coast
    It's good
    get ext - same coilover with 1/4 more extension and 1/2", at the hub - but only with aftermarket UCAs
  16. Oct 14, 2021 at 11:13 AM
    alb1k
    Left Coast
    It's good
    or have them extended at rebuild time....
  17. Oct 14, 2021 at 11:25 AM
    Cummins3500
    Logan
    @alb1k thanks for the quick response. Headstrong Offroad came through clutch with the kings. Was able to get a set of coil overs ordered and should have em by next week
    alb1k and NWPirate like this.
  18. Oct 14, 2021 at 11:27 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Depends on a lot of things. I from scratch if you go big like that with a 2275cc you're in the ballpark of $3k if you assemble it yourself, starts around $5k for a done turn key. Mine is estimated at 170 hp at the crank.
    Of course, that doesn't include a clutch, a trans that can handle that, or brakes that can stop you. Add about an extra $2k for that.
    I suppose if not a purist you could do the Subaru motor swap and have a 300hp monster thats totally reliable for 80k miles. Not sure what the cost would be there.
  19. Oct 14, 2021 at 12:32 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    And you have to take up vaping.
    #totalcost
    bmf4069 and Darkness[QUOTED] like this.
  20. Oct 14, 2021 at 12:42 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    For the subie motor? That's a show stopper there for me. My bug causes cancer as is. It should come with one of those Surgeon General warning labels that California puts on everything.
    Jack McCarthy and chrisb[QUOTED] like this.
  21. Oct 14, 2021 at 3:49 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    So this fork was on top of my cheese curds. Guess this means they were fresh.
    Also, I saw this in the parking lot. I genuinely don't understand why someone would put three drink packets in the door seal...
    Darkness, bmf4069, chrisb and 2 others like this.
  22. Oct 14, 2021 at 6:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Work is having me clean some stuff up again. Found three of these huge cam gears. Note: XL gloves
    I thought the timing belt was hard! This has got to be a royal PITA
    Darkness, bmf4069 and NWPirate like this.
  23. Oct 14, 2021 at 6:29 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    That's why I keep a pair of Titanium Sporks in the glove box. After all, it's not tactical barbecue unless you're eating it with a Titanium Spork. :hungry:
    Bikeric, Darkness, bmf4069 and 5 others like this.
  24. Oct 14, 2021 at 6:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I keep a fork, and spoon in the car for work from the house.
    Randy Morton[QUOTED] likes this.
  25. Oct 14, 2021 at 6:35 PM
    I've spooned in my truck, but never forked in it.
  26. Oct 14, 2021 at 6:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Done plenty of both over the years. One more than the other. Depends on how many drive in movie theaters I go to.
    Darkness likes this.
  27. Oct 14, 2021 at 6:52 PM
    As long as the truck ain't forkin' you, guess it's cool?
  28. Oct 14, 2021 at 6:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Been there too.
  29. Oct 14, 2021 at 7:32 PM
    NWPirate
    Zach
    WA
    You should try forking on the freeway, that's exciting. :D
    Darkness and bmf4069 like this.
  30. Oct 14, 2021 at 10:22 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
