  1. Aug 27, 2021 at 9:58 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Motion seconded.
  2. Aug 27, 2021 at 10:52 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I noticed recently my air doesn't seem to be blowing as cold as I remember. Going to give this test a shot later. I find the instructions don't really make sense. Specifically the point in yellow. How can that be either fine, or not fine?
    Is it saying that item 6 is ideal?
  3. Aug 27, 2021 at 11:04 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Chances are its just the age of the o-rings around the dryer which need to be replaced. I had the dye put in to see where mine had a slow leak. A recharge showed it to be 1/2 full.
  4. Aug 27, 2021 at 11:07 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm not familiar with the AC system. Are these on the compressor? How hard were they to replace?
  5. Aug 27, 2021 at 11:28 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    does it sound kinda like a harmonica every time you take your foot off?? mine does. and did it work?
  6. Aug 27, 2021 at 11:45 AM
    Jack McCarthy
    Bill
    North of Boston
    To do it yourself (which i havent done yet), you would have to pay to discharge the system, work on it for a day to replace the dryer (item in front of radiator with viewport) and then recharge it back up. Not every garage will do that for you, so ask around.
    Thats assuming thats the only location of the slow leak. You could pay to charge it with the dye to see the leaks with an IR light. (thats all I've done)
    FirstGenVol[QUOTED] likes this.
  7. Aug 27, 2021 at 1:42 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    that would have to just be a live stream. Its a dime fest out here.
  8. Aug 27, 2021 at 2:26 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I design multi story steel structures all day long. I can take a tiny little soil sample and tell you everything about its geography and it’s precise bearing capacity. I can even calculate the storm water runoff of a piece of developed vs. undeveloped land down to a gnats ass.
    Air conditioning is wizardry to me. It’s a dark art and anyone who tries to convince me otherwise is a practitioner of black magic.
    That being said, I did recharge my system recently with the help of my neighbor who has all the tools. It took us 3 tries and quite a few extra cans of refrigerant. He even explained his dark art in terms that I could almost understand. My point is, I’ll do my own 4wd swap; The next time this system needs a recharge, the Toyota dealership is getting my business.
  9. Aug 27, 2021 at 3:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    When in the "Test Conditions"....you want no bubbles when compressor is engaged. "None" is not good if if Item 3 is present...."Sufficient" means it's making water(drain tube at firewall) and the Low Side plumbing, passenger side by head lights is cold to the touch...."too much" can cause no bubbles but Item 4 would be present.
    Yes on # 6
  10. Aug 27, 2021 at 5:32 PM
    shifty` Dead heads and frog legs. Mmm... cake mix!
    Not trying to convince you, but it's just a closed system pressurized with gas. The gas is compressed and expanded, causing it to collect and release heat, basically.
    I think that's the best general explanation I was ever given.
  11. Aug 27, 2021 at 6:19 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    So we’re kind sol on options for outer tre’s right? OEM considered the best option? I had read that saneiki 555’s we’re fine as long as you got the made in Japan ones. Trouble is I haven’t found a way to verify which ones you get. Some come from Japan, some come from Taiwan.
  12. Aug 27, 2021 at 7:36 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Glamping with the parents. A little warm out so no front cap window tonight. Cicadas are singing, the fire is burning, and the beer is flowing.
    NWPirate, RUSTYNUTS, Glock 40 and 6 others like this.
  13. Aug 27, 2021 at 7:45 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    That’s actually a really good way of explaining it!
    Refrigeration doesn’t cool anything, it technically removes the heat from the air or whatever, then carries that heat to the compressor and then goes thru a change of state where it can dissipate that heat from cooler air over the condenser and turn back into a sub cooled liquid which is ready for the next change of state at the evaporator where it starts all over!
  14. Aug 27, 2021 at 7:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Phase change is a beautiful thing
    bmf4069 and FrenchToasty[QUOTED] like this.
  15. Aug 27, 2021 at 8:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Do any of y'all have desiccant packages for storage? I need a few, and not really sure what I need to look for. I found a "reusable" set. Unsure on longevity of "reusable" if thats even a thing with silica gel stuffs.
    wisedry 50 Gram [6PACKS] Rechargeable Silica Gel Desiccant Packets Fast Reactivate Desiccant Bags Orange to Green indicating for Air Dryer Food Grade: Amazon.com: Industrial & Scientific
    Any advice welcome.
  16. Aug 27, 2021 at 8:58 PM
    FrenchToasty
    Mo
    Bone stock
    What R you storing?
    Haha my mom is crazy and saves everything, I can mail you a pretzel container full of them!!!!
    chrisb, GODZILLA and Tundra2[QUOTED] like this.
  17. Aug 27, 2021 at 9:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just wanted some for the pew pew boxes, and pew pews themselves. Also for the car since I left the windurs down during a helluva warshin today.
    I'll pay for shipping if you can send a whole butt load of em
  18. Aug 27, 2021 at 9:48 PM
    FrenchToasty
    Mo
    Bone stock
    Haha I’ll see what stockpile I can send!
    It’s late, but a ozone machine/deionizer machine is a great investment for cars and especially if you live where it’s damp.
    I got a less than 100$ one from big gurl and use it often in the shweaty summer months, of specifically the other day when I forgot to take salsa out of the back seat to sell to coworkers-the electrician still wanted it.
  19. Aug 27, 2021 at 9:53 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Anyone know of a good source for the outer skids on our BGT's? Mine only has the large center skid. Getting ready to replace the splash shields in the fender wells and want to do it all at once.
  20. Aug 27, 2021 at 9:56 PM
    empty_lord
    05 rollover special
    The two side plastic pieces? I thought I was the only one that actually wanted to run those
  21. Aug 27, 2021 at 9:58 PM
    Desert Dog
    Yes, those. No, I want them too. Haha!
    NUDRAT[OP] likes this.
  22. Aug 28, 2021 at 4:47 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I keep those bad boys anytime I buy something that they come in. I toss them in my toolbox, ammo boxes, storage cabinets, basically everywhere.
    It gets so humid here, and my garage is sorta air-conditioned (the garage is under the bedrooms and adjacent the basement and another level), that I can get condensation inside my toolbox if I open the garage door and leave it open. So there are desiccant packs just everywhere.
    If T2 doesn't take em all, I'll gladly take some as well. (I actually want to put a small pack in each gauge of the 911..among other places.)
  23. Aug 28, 2021 at 5:52 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Moog makes em. They're good for everything but the LBJs.
  24. Aug 28, 2021 at 5:54 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Listen here wizard, don't push your black magic on us simple folk. We may grab our torches and pitchforks.
  25. Aug 28, 2021 at 5:57 AM
    FrenchToasty
    Mo
    Bone stock
    Crazy round earther I know!
  26. Aug 28, 2021 at 6:05 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I lived where the closest city was Montreal. That definitely would have been a clean truck up there.
    But that other hole - right next to the one he patched. WTH? Guess annual inspection wouldn't see the hole hidden by the radiator.
    Jack McCarthy likes this.
  27. Aug 28, 2021 at 6:08 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I've found if you use the pitchfork for a torch, you have a free hand for your refreshment of choice...or another pitchfork.
    YMMV
    bmf4069[QUOTED] and FrenchToasty like this.
  28. Aug 28, 2021 at 7:50 AM
    des2mtn
    SW
    Tonto cover
    Gobble gobble
    MS22, NWPirate and Darkness like this.
  29. Aug 28, 2021 at 7:59 AM
    Jack McCarthy
    Bill
    North of Boston
    Here's the black magic book @shifty` uses....:spy:
    shifty`, CodyP, Darkness and 3 others like this.
  30. Aug 28, 2021 at 8:10 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Ive got a whole shelf of nerd books. Read most of em before i learned engineers arent fabricators.
